10 Replies Latest reply: Sep 10, 2013 8:15 AM by AMULI RSS
    using conditional code with animate
    phillip-j Community Member
      Hi, I am trying to do something similar to this (generic html file with jquery):
      $(document).ready(function () {
      $( "#expand" ).click(function() {
        $( "#myname" ).animate({ "height": "+=50px" });
        $( ".myname" ).animate({ "top": "+=50px" });
      $( "#contract" ).click(function(){
        $( "#myname" ).animate({ "height": "-=50px" });
        $( ".myname" ).animate({ "top": "-=50px" });
      So, when #expand is clicked an item #myname is expanded and some class .myname items move down. Clicking #contract reverses this.
      My edge code for a click on symbol named "r1" is below.
      (Similar code exists for symbol "r2")
      When I click r1 that symbol expands and the other items in class r1 all move down, OK.
      Next, if I click another symbol, ie r2, the r1 symbol must first contract before r2 can expand.
      This does not work. The item r1 does not contract -- but the class r1 does move up. I do not understand that.
      //close a playing symbol, then play the clicked symbol
      sym.$(playing).animate ({'height':'-=100px'}); // ... does not work
      sym.$("."+playing).animate ({'top':'-=100px'}); // ... does work
      //r1.click
      //is any symbol is playing?
      var playing = sym.getComposition().getStage().getVariable("myGlobal");
      // nothing is playing
      if (playing == "nothing") {
      //set the global to show which was clicked
      sym.getComposition().getStage().setVariable("myGlobal", "r1");
      // play the clicked symbol
      sym.$(playing).animate ({'height':'+=100px'});
      sym.$("."+playing).animate ({'top':'+=100px'});
      // do nothing if I am playing already
      else if (playing == "r1"){
      else {
      //update the global to which was clicked
      sym.getComposition().getStage().setVariable("myGlobal", "r1"); // this would use a different value if a different symbol was clicked
      Apologies for long post
      phillip-j
        • 1. Re: using conditional code with animate
          resdesign CommunityMVP
          Hey Phil, can you post your file?
          • 2. Re: using conditional code with animate
            folder unzips to "web"
            https://app.box.com/s/uxr8pthh4gcytmo7ge3a
            this is the web export - is that OK?
            • 3. Re: using conditional code with animate
              Yes - I will look at it shortly!
              • 4. Re: using conditional code with animate
                AMULI Community Member
                Hi Phillip,
                See the following thread, where a solution for such a problem is detailled and where you'll find a link to download an example file :
                http://forums.adobe.com/message/5410456#5410456
                Gil
                • 5. Re: using conditional code with animate
                  Gil is right. I looked at your file and I believe you need to rethink your approach.
                  • 6. Re: using conditional code with animate
                    Thanks Gil, I will not be at my desktop untill later to look at your sample in detail. Looking forward to it,
                    Phillip
                    • 7. Re: using conditional code with animate
                      I see how the event target is passed to the stage and the function is called. Thanks for that example. When a symbol is clicked I use
                      //click on Stage_r13_r1
                      sym.tracking(e);
                      In your file you play the symbol using sym.getSymbol(current).play(0). In my context, I want to animate the symbol (via ID name) - and then also animate several other symbols (via class name).
                      So, I am going to make use of the event target like this: sym.$("#myId");
                      On my stage I have:
                      sym.tracking = function(e)
                         myID = e.target.getAttribute("ID").split("_")[1];
                         var myIDFormat = '\'#' + myID + '\'';
                         sym.$(myIDFormat).animate({'height':'+=100px'}); //this line does not work
                      I cannot get the function to animate the element.
                      • 8. Re: using conditional code with animate
                        Hi Phillip,
                        Did you check via console.log( myIDFormat); that you use the good ID ?
                        Then, is this element with ID myIDFormat actually in the Stage symbol, or in another so you need sym.getSymbol('<parentSymbolName>').$(myIDFormat).animate() ?
                        Test with hide() and show() before animate().
                        Gil
                        • 9. Re: using conditional code with animate
                          Gill, thanks for your follow-up.
                          So, to animate the symbol or play it I can use:
                             mySymbolName = "'" + myID + "'";
                             sym.$(myID).animate({'top':'+=100px'}); //this works,no quotes
                             // also works with quotes - sym.$(mySymbolName).animate({'top':'+=100px'});
                             sym.getSymbol(mySymbolName).play(0); //this works, needs quotes
                          So I can address it as $(myID) or $(mySymbolName) and then animate in this context (with or without quotes)
                          However, while the value of myID is  - smBox - I cannot address it as $(smBox)
                          sym.$(smBox).animate({'top':'+=100px'}); //this does not work
                          Does the fact that the variable myID was made from the attribute of an object make it functionally different than the equivalent text? It seems to me that $(myID) ought not to work, but does.
                          Also, how do I view the console log?
                          • 10. Re: using conditional code with animate
                            Hi Phillip,
                            Thank you for your feedback (I do not clearly understand the reason why some of your animate() statements work and others don't. I am busy for the moment, but I want to elucidate that later, it's interesting).
                            Personnally, I use Firebug : https://getfirebug.com/whatisfirebug
                            Once you have installed that plugin, you activate it via the top right button with a bug icon (see screen capture : it's orange once activated).
                            Then select the Console tab to view the results of your console.log() statements and any warnings.
                            Another useful tab is Script, where after selecting <yourProject>_edgeAction.js in the files menu, you can define a breakpoint by clicking the line number of a statement. And from then, like with any debugger, go on executing step by step, and inspect variable values in the Spy pane on the right.
                            Chrome or Safari developer tools have similar features.
                            Gil
