9 Replies Latest reply: Sep 9, 2013 2:37 AM by Michael@Vision RSS
    How to change variable frame rate to constant?
    CLCTV Community Member
      Hello,
      I am exporting a mpeg HDV file that has a constant frame rate to a H264 video (.mp4) video to upload to a web-base video player. I'm actually using the preset in Media Encoder "YouTube HD 720p 29.97".
      The online video web interface I use requires a constant frame rate. But when looking at the video in MediaInfo it shows the video file as a variable frame rate. After looking through the settings in Media Encoder I cannot find any option to correct that.  I see where you can change the frame rate and it is at 29.97. So you would think it would be constant but it is not. And it does not have any settings, that I can see, to change from variable to constant. I do see the bitrate settings, but that is not the issue.
      I also have Apple Compressor and that successfuly does a constant frame rate, but if possible I'd rather use Adobe Media Encoder. So does anybody know how to change this setting? Thank you
        • 1. Re: How to change variable frame rate to constant?
          JSS1138 CommunityMVP
          Mediainfo is wrong.  PP cannot export variable frame rates.
          Try Gspot instead.
          • 2. Re: How to change variable frame rate to constant?
            Well I tried Gspot and I couldn't find where it showed it it was a constant or variable frame rate. All it said was 30 fps (but it should be 29.97).
            So I tried Media Inspector and it also said "Frame rate mode: variable". It went into more detail and said minimum frame rate 29.970 fps and maximum frame rate: 30.00fps. I also tried the file I transcoded with Apple Compressor with Media Inspector and it read "Frame rate mode: Constant." So two codec readers, MediaInfo and Media Inspector, read that it is a variable frame rate coming from Adobe Media Encoder. The obvious answer will be, well then use Compressor, thing is I don't care for it otherwise and would much rather use Media Encoder if I can solve this issue. Below is the resuts from Media Inspector:
            * * * MediaInspector for Mac - Version 2.0, build 896
            * * * ©2012 by Diego Massanti
            * * * MediaInfo Lib by Jerome Martinez
            * * * Raw File Report for Encoder_CBR_NoAdv.mp4
            General
            Format                           : MPEG-4
            Format profile                   : Base Media / Version 2
            Codec ID                         : mp42
            File size                        : 150 MiB
            Duration                         : 3mn 56s
            Overall bit rate                 : 5 318 Kbps
            Encoded date                     : UTC 2012-10-03 23:09:47
            Tagged date                      : UTC 2012-10-03 23:09:52
            �TIM                             : 00:00:00:00
            �TSC                             : 30000
            �TSZ                             : 1001
            Video
            Format                           : AVC
            Format/Info                      : Advanced Video Codec
            Format profile                   : High@L3.1
            Format settings, CABAC           : Yes
            Format settings, ReFrames        : 3 frames
            Codec ID                         : avc1
            Codec ID/Info                    : Advanced Video Coding
            Duration                         : 3mn 56s
            Bit rate mode                    : Constant
            Bit rate                         : 5 000 Kbps
            Width                            : 1 280 pixels
            Height                           : 720 pixels
            Display aspect ratio             : 16:9
            Frame rate mode                  : Variable
            Frame rate                       : 29.970 fps
            Minimum frame rate               : 29.970 fps
            Maximum frame rate               : 30.000 fps
            Standard                         : NTSC
            Color space                      : YUV
            Chroma subsampling               : 4:2:0
            Bit depth                        : 8 bits
            Scan type                        : Progressive
            Bits/(Pixel*Frame)               : 0.181
            Stream size                      : 141 MiB (94%)
            Language                         : English
            Tagged date                      : UTC 2012-10-03 23:09:47
            Color primaries                  : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
            Transfer characteristics         : BT.709-5, BT.1361
            Matrix coefficients              : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
            Audio
            Format                           : AAC
            Format/Info                      : Advanced Audio Codec
            Format profile                   : LC
            Codec ID                         : 40
            Duration                         : 3mn 56s
            Bit rate mode                    : Variable
            Bit rate                         : 317 Kbps
            Maximum bit rate                 : 328 Kbps
            Channel(s)                       : 2 channels
            Channel positions                : Front: L R
            Sampling rate                    : 48.0 KHz
            Compression mode                 : Lossy
            Stream size                      : 8.96 MiB (6%)
            Language                         : English
            • 3. Re: How to change variable frame rate to constant?
              Hardly.
              http://www.eventdv.net/Articles/News/Feature/Tutorial-Encoding-H.264-Video-in-Adobe-Media- Encoder-CS5.5-and-Apple-Compressor-4-80446.htm
              The obvious answer is that more than one program is incorrectly reporting the frame rate.  Like I said, PP can't output variable frame rate video.  I'm not aware of any application that can.  Variable bitrates, sure.  But not frame rates.  Video is pretty much stuck to only one rate for any given stream.  Any application that's reading it as 'variable' simply isn't reading it correctly.
              • 4. Re: How to change variable frame rate to constant?
                Stan Jones CommunityMVP
                Not common, but it is out there. Here is a link to a description of how mediainfo tags it as variable framerate:
                http://sourceforge.net/projects/mediainfo/forums/forum/297610/topic/5551130
                • 5. Re: How to change variable frame rate to constant?
                  I completly agree Jim, I don't want Compressor to be the answer.
                  And Stan, your link shows that others are fustrated by this too.
                  I did a test were I changed the fps from 29.97 to 30fps. Then in Media Inspector it still showed a variable frame rate with the minimum being 30fps and the max being 30.030fps. So if it is true that it is creating a variable frame rate,  it is only .030 fps. Very minimal I would think?
                  But for me specifically, it is a problem, because we are using a company BrightCove to host our videos, and they are saying my videos have a variable frame rate and don't meet their suggested requiments. BrightCove is a company were you can upload a video file and they make multiple renditions to be able to play on multiple devices.
                  • 6. Re: How to change variable frame rate to constant?
                    I didn't read that link as frustration: the poster is using matroska files, which provide/allow variable frame rates, and he wanted to understand how Mediainfo was detecting them.
                    I did a quick test. Exported a short bit with the Youtube H264 p720 29.97 preset (the one you are using). Mediainfo reads it as variable frame rate with a nominal rate of 29.97, a min of 29.970, and a max of 30.000. Gspot reads is as 30.000 (not 29.97 as it should).
                    I don't know what to make of that.
                    • 7. Re: How to change variable frame rate to constant?
                      Elliott B. Community Member
                      A client sent me an MP4 file, which should be 23.976.  DaVinci Resolve 9 identifies it as 24.000, which is a problem.  MediaInfo says VFR, min: 23.976, max: 24.000.  To fix this, I transcoded to another codec using ffmbc, but I would like to know how to fix it without transcoding for the sake of both speed and quality.
                      • 8. Re: How to change variable frame rate to constant?
                        Rallymax-forum Community Member
                        It's caused by bad timestamp markers on each frame from the AME shipped h.264 encoder.
                        Grab a trial of x264pro and not only will it look better it'll be constant rate with the correct markers.
                        • 9. Re: How to change variable frame rate to constant?
                          Michael@Vision Community Member
                          I have a very similar problem. Were you ever able to get this resolved? Did x260Pro fix the problem for you?
                          I found that if I used MPEG Streamclip to export the movie, the FPS would say 'Constant', but if I used Handbrake, AME or Squeeze 9, the 'Frame rate mode' always said 'Variable' ! Regretfully, MPEG Streamclip doesn't allow me to choose a 'high' profile, so I had to look for a higher quality encoder.
                          In this case I am trying to export to Amazon, and they are flat out rejecting the file because of the 'variable' frame rate mode.
