1. Re: CSS Styles Panel frustrations
Jon Fritz II Sep 9, 2013 6:26 AM (in response to eriqc)You can't bring back the old one as it stands now. Filing an official request for it here may help though:
https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform
It is something that has come up a lot recently.
Here is some info on working with it: http://helpx.adobe.com/dreamweaver/using/css-designer.html
If you want it to be a bit more compact, you can get away from the two column space eater by dragging th right edge of theCSS Designer window to the left until the columns stack instead. Not the greatest "fix", but better than the two column beast in my opinion.
EDIT: You can also click the heading of each sub section within the panel to minimize them individually if you aren't using them. Again, not the best "fix" but better than filling half your screen with css attributes.
