Hi Michelle. I have imported HTML files quite often and have
never experienced crashing or error messages. And you can select
multiple files to bring in all at once - so I wonder exactly what
you are experiencing. Using the Import option, you are presented
with the typical Select Files window to identify the files you want
to import. You can hold down your Shift or Ctrl keys to select
multiple files. Try importing a group of say, 10 HTML files at
once. Select them all, and let it go - you may see a message about
style sheets already existing, which asks if you want to overwrite
the one in your project. Once you make that decision, the import
should happen and the results will be displayed in a popup window.
If you crash instead, is there any other clue to what's going
on? Error messages?
If importing 10 files at a time works, try 20 files the next
time. Then more if still successful. If you are already trying to
select multiple files (that isn't clear from your post), I don't
know how many you are trying to batch together but you may be
hitting a memory ceiling somewhere, especially if the HTML files
contain large graphics.
HTH,
Laurin
UniFund, LLC
