Looping over cfset tag
Guest
Mar 19, 2007 Mar 19, 2007
Hey Guys,
I am having a problem with cfloop. What I am trying to do is calculate points on an Oline March Madness Pool. I need to evaluate if the user picks are equal to the game winners. I can do it if I manually type each pick # and each game # but I would much rather loop over a cfset tag since there are 63 picks and games. You can check out my code below to get a better idea of what I am trying to do. While I know I can't include the #'s on the right side of the cfset tag in this way I included them anyways to better illustrate where I would like to loop it. Is there a way to do this, or will I have to manually set each pick?
Advanced techniques
575
So which lines are causing problems and what kind of problems do you have.
"Yes, I can see some issues, but before I jump and and fully analyze
your code, I would like to here more from you."
Guest
I am having an issue at the nested cfloop tag. I cannot get the csfet tag to loop. It keep getting the error:
Invalid CFML construct found on line 27 at column 46.
ColdFusion was looking at the following text:
<cfif getGames.game#l# EQ userPoints[#userID#]["pick#l#"]>
I'm going to guess this is line 27 or very near it.
Your actual <cfset> line looks fine to me assuming all the relevant keys
exist when they need to exist. I would have written it something like:
<cfset userPoints[userID]["pick" & i] = variables["pick" & i]>
The if statement should probably look like this:
<cfif getGames["game" & i] EQ userPoints[userID]["pick" & i]>
All your index variables are the letter "i" and not the number "1"
aren't they? I don't believe a singe number is a valid CF variable name.
Guest
This is driving me crazy!!
Dan I will be trying your method but now I have to figure this out.
How do you loop over cfset tag expressions? While I can loop over the name of it ok I can NEVER loop over the expression.
For Example this wouldn't work:
<cfset picks = structNew()>
<cfloop index="i" from="1" to="5">
<cfset picks["pick#i#"] = form.pick#i#>
</cfloop>
In trying to do this I am told that I can't use either the # or ? in the expression. Why is this? It is maddening when you have set up a structure.
Am I doing something wrong? Is there another way to do this?
The left side of your expression is just fine, it is the right that is
wrong! :-)
Try something like:
<cfset picks["pick#i#] = form["pick#i#]>
OR my preferred:
<cfset picks["pick" & i] = form["pick" & i]>
This would be a lot easier if you had a table that looked like this:
playerID, GameID, Pick, Result
Then all you would have to do is
select playerID, count(playerID) points
from yourtable
where pick = result
Guest
Dan,
Thank you very much for your response. However, I would need to change the amount of points given in the second round to 2 instead of 1. Then in round 3 I would need to add 3 points instead of 1. Would this incremental point system work with your method?
If you add a round_number field, you could do something like this
select playerId, sum(points) total_points
from (
select playerID, round_number, count(playerID) * round_number points
from yourtable
where pick = result
group by playerID, round_number ) temp
group by playerID
It would get a bit more complicated if you wanted to display those with no points, but not much.
Advocate ,
Try Form["Pick#i#"] instead of Form.pick#i#
Documentation
