Whphost.js. My TOC, Index, and Search buttons do not function in WebHelp RH9
Sep 10, 2013 Sep 10, 2013
I've read posts about this issue but I have not received a satisfactory answer as to why this occurs or how to fix it.
Note that this problem occurs regardless of the complexity of the project. When the project is first generated (DHTML > Pure HTML is selected), I first receive a script/ActiveX warning....
After I accept the option to allow Blocked Content, the TOC no longer appears and the Search, Index, and Glossary buttons no longer function.
When I click the Error icon on the lower left corner of the page, the following appears:
Note that this error was not encountered in RH 8. My system is Windows 7 and my browsers are IE8 and Mozilla (Firefox ESR 17.0.7).
I would appreciate any guidance regarding this situation.
Thank you.
768
Sep 11, 2013 Sep 11, 2013
So do you see this error on both IE and FF? IF so, it would suggest that not all resource files (whphost.js or whutils.js) are copied to the output.
Greet,
Willam
William. Thank you for quick response.
Currently the error exists in both in IE and FF.
Both the whphost.js and whutils.js file can be found in the output folder.
Regards.
DW
Sep 20, 2013 Sep 20, 2013
Strange. Can you try the following:
1. Remove the entire output folder.
2. Remove the entire SSL folder. (if not the same as 1)
3. Regenerate the project.
This makes sure that any corrupted file at least gets regenerated.
Also, what happens when you generate one of the example projects? Do you see the same issue?
Last, do you use any custom scripts or DHTML effects other than drop-downs?
Greet,
Willam
William. Thanks for your note. I tried generating several times including wiping out the SSL folder. Even when I tried creating a new project from scratch (or worked with the sample projects), the same thing happened.
Update. Since my last writing, the problem has been resolved. It's a long torturous story, but here is the Cliff Notes version.
After being completely frustrated, my Desktop Support group uninstalled RH9 and I downloaded and installed a RoboHelp 10 trial and the problem was no longer present. I got back full functionality of the TOC, Keyword, and Search. Because I couldn't purchase a licensed RH 10 version until at least December, I uninstalled RH 10 and reinstalled the RH 9 using install files from the Company server. Low and behold full functionality returned. I guess the reason I didn't reinstall RH 9 from the beginning is because I read that reinstalling RH didn't take care of the problem.
In any case, the moral of this sad story for those who encounter this situation is to first reinstall RH. It also wouldn't hurt if Adobe would post an article regarding a fix to this.
Regards.
RoboHelp Documentation
Download Adobe RoboHelp
