i have 1/2 of my company on the 11.8.800.94 from the enterprise .msi install (Software distribution) this version has no installer GUID with a install size of 16.9MB
the other half of the company is on the website .exe version of 11.8.800.94, this version has an installer GUID with a install size of 6.00MB
i would like to know the difference between both and why the enterprise .msi has no install GUID, this makes it hard for admins to do a software distribution with no GUID from an enterprise .msi.
sounds odd.. an msi ought to have a ProductCode, unless you mean something else
check it with orca (which is burried somewhere in a sub installation of Platform SDK, or use a script, there are several around that can check in the msi's installer database)
or check it's registration in the registry (various locations)
I looked around a bit, and in the enterprise I work, we just download the msi from website here, and asure only that version is deployed.
downloading several versions, you could check it's digital signature (looks like june 21) aside it's size if the name differs
this is what I have at the moment (bytes, name):
18,124,181 flashplayer11_8r800_94_mac.dmg
17,737,608 flashplayer11_8r800_94_win.exe
18,834,944 flashplayer11_8r800_94_win.msi
17,139,080 flashplayer11_8r800_94_winax.exe
18,231,296 flashplayer11_8r800_94_winax.msi
17,139,080 install_flash_player_11_active_x.exe
18,231,296 install_flash_player_11_active_x.msi
233,289 uninstall_flashplayer11_8r800_94_mac.dmg
815,496 uninstall_flashplayer11_8r800_94_win.exe
... 6MB? one would think that one was missing half (32bit-64bit).. like a repackaged installer
when a new version of flash is available i get it from http://www.adobe.com/products/flashplayer/distribution3.html
i use Specops for deployment. in my deployments i target windows installer GUID's for upgrades.
looking at prog's and features you can see 2 different installs:
this install (16.9MB) with a GUID is the *.msi package from http://www.adobe.com/products/flashplayer/distribution3.html (Plugin)
the first 6MB install is direct from http://get2.adobe.com/flashplayer/.....just to confirm what im saying i just installed it on my VM and got the same 6MB install and no GUID.
looking at all digital signatures for the .msi packages it lists ‎Friday, ‎June ‎21, ‎2013 7:16:27 PM
im not sure if im getting the wrong package from adobe or why is the web installer different from the enterprise deployment .msi?
i guess this has baffeled everyone that works at adobe? no answers?
Looks like screenshots from Programs and Features
I have never looked into that, as those numbers were never an issue.
There is some algorithm that defines Size based on installed package.
But rarely those figures present the actual occupied disk space of the installed software.
Possibly, I didn't check this, the flash installers register differently. MS Office for example uses 1 entry (PROPLUS) under the Uninstall key to display its presence on the system, but has many MSI packages installed. Those are labeled with the SystemComponent value set to '1', so you don't see them in the control panel.
So the end result might be the same installed source, but you see different installed sizes.
