1. Re: Combining Advanced Actions in CP6
Lilybiri Sep 11, 2013 10:20 AM (in response to rygaar)Hello,
The work flow in the conditional advanced actions is a bit different from normal progamming languages. You have the possibility to create And/OR conditions, and to have a sequence of Decisions (the Untitled buttons at the top) with different conditions in each decision. But you have to know that Captivate will always evaluate all the decisions, and in sequence. So I mostly recommend for complicated situations to make a flow chart with the logic before creating the action.
No, you can use only one action per trigger. But it is possible to combine all in one conditional action. To mimick a standard action, you use a condition that is always fulfilled like "If 1 is equal to 1"
It is not possible to call an advanced action from another action, no subroutines. There are also no loops, no arrays.
I have lot of examples on my blog for use cases of advanced actions: http://blog.lilybiri.com
Your example is pretty easy:
Decision 1 "Excellent"
IF cpQuizInfoPointsscored is greater or equal to 5
Apply Effect ..... to the appropriate shape
Decision 2 "Average"
IF cpQuizInfoPointsscored is greater or equal to 3 AND
cpQuizInfoPointsscored is less than 5
Decision 3 "Low"
IF cpQuizInfoPointsscored is less than 3
2. Re: Combining Advanced Actions in CP6
rygaar Sep 11, 2013 12:06 PM (in response to Lilybiri)Thanks Lilybiri!
3. Re: Combining Advanced Actions in CP6
Lilybiri Sep 11, 2013 12:09 PM (in response to rygaar)Did you try it out? More questions?
4. Re: Combining Advanced Actions in CP6
rygaar Sep 12, 2013 9:44 PM (in response to Lilybiri)Yes it worked, that's why I got so excited.
I have a lot of questions but I like to try figuring stuff out on my own first, so as not to spam the forums. One particularly tricky problem is that I can't figure out how to change the z-index (layer order) of an object from a Master slide. For instance if I have a smartshape on the master slide, and I would like it to appear above certain objects but under other objects on the regular slides, I get stuck (since the master slide object does not show up on the timeline for regular slides). If I can't figure it out, maybe I'll start a new thread about it.
Thanks again for your help; I knew there had to be an easy solution to the if--elseif--else structure because otherwise the advanced action scripts would be too limiting. As a bonus, you told me how to combine standard and conditional actions in the same script.
5. Re: Combining Advanced Actions in CP6
RodWard Sep 12, 2013 9:58 PM (in response to rygaar)Any objects you add to Master slides can be set to appear on top of the objects on the slides to which the master is attached, or they will be underneath as a background, but you cannot have some objects on the master do one thing and other objects do another. Think of the master slide objects as either being in the background or the foreground but not both.
6. Re: Combining Advanced Actions in CP6
rygaar Sep 12, 2013 10:25 PM (in response to RodWard)Thank you RodWard.
