2 Replies Latest reply on Sep 18, 2013 12:24 AM by Steven Madwin
    Multiple Signatures Adobe Pro
    crclaunch
      We are having a problem adding multiple signatures to our PDF using Adobe Pro, when we used version 6 or 7 we do not have any problems.  Is there a new process in added multiple signature?
        • 1. Re: Multiple Signatures Adobe Pro
          Sabian Zildjian Level 4
          Starting with version 9 of Adobe Acrobat/Adobe Reader you MUST have the digital signature fields in the document first.  If you don't Acrobat 9.x and later lock the document from further editing so you will not be able to add more digital signatures without a pre-existing digital signature field.  Acrobat 8 and earlier did not require this.
          • 2. Re: Multiple Signatures Adobe Pro
            Steven Madwin Adobe Employee
            Hi crclaunch,
            Let's start with which version of Acrobat Pro are you using? Next, tell me a little about the PDF file you are trying to sign, does it have existing signature fields and if you select the File > Properties menu item , then select the Security tab are there any restrictions? Finally, since you said "we are having" I presume there are multiple users in play, are they all using Acrobat or are some of them using Reader?
            Steve
