I have RH9. I inherited a project. The skin for one module (Radiant) does not match the skins for other modules in the project (Example Hospital Help).
I tried to edit the skin, but it made no difference. I then copied the !SkinSubFolder! from Hospital to Radiant. It made no difference.
I don't know what to do next to get them to match.
Any help is greatly appreciated.
Vicki
Take a look at the video linked below for an example of what I'm expecting to see.
Cheers... Rick
Hi there
Have you enabled Section 508? If so, you get that unwanted look.
Cheers... Rick
One step further. I inherited this, I don't know what Section 508 is or how I disable it. Could you help Rick?
Hello again
What might be helpful here would be if you could record a brief demonstration of walking through your settings. You could do that by using Screenr. ( http://www.screenr.com )
We could then view the settings and possibly tell you where things are going south.
Cheers... Rick
I had all of 4 hours of training on RoboHelp.
I will do a Screenr, but let me know what I should capture.
From the Project Setup, the skin-just the one we are using?
From File: Project Settings?
Anything else?
Sorry for my lack of knowledge. I've been looking in the RoboHelp for the Web book, but can't find the answers I need!
I appreciate the help,
Vicki
Cheers... Rick
Thank you, thank you, thank you!!!!
You solved my problem!
Once I knew where the properties were and checked them, I saw that it was not pulling the correct skin.
Even thought I had it in the SKIN section, it was pulling the default.
Problem is solved.
I so appreciate your taking the time to help out a learner!
Vicki
