encrypt the password
Mar 21, 2007 Mar 21, 2007
Hi. I am writing an app which stores usernames/passwords into a database table.
I have the form for admin to add the new user by enter the username and passord on the form. The question is how can I encrypt the password provided by the user before insert it into the table and then compare it when the userlogin.
thanks
Advanced techniques
937
Explorer , Mar 21, 2007 Mar 21, 2007
Here what I test so far but it dosent work.
<cfoutput>
<cfset myAlgorithm = "CFMX_COMPAT">
<cfset thekey = "#form.username#">
<cfset encrypted=encrypt("Form.password, theKey, myAlgorithm")>
#encrypted#
</cfoutput>
You can use the coldfusion functions Encrypt & Decrypt. Check out for the column length that might be required. Every time you compare the password use Decrypt function and then compare with the input given by the user.
If you need to write your own algorithm too, you can write and use it.
<cfoutput>
#encrypted#
</cfoutput>
that line is not valid, try this
<cfset encrypted=encrypt(Form.password, theKey, myAlgorithm)>
I am working in CFMX 6 and the same function works fine. In MX 6 we don't have the option of the algorithms but I would recommend using DES.
I got the encrypt part working and inserted it into the table but don't know how to compared it when user login.
<cfquery name="get_password" datasource="#ds#">
select password
from user_tbl
</cfquery>
<cfoutput query="get_password">
<cfset comparison = Compare(FORM.password, password)>
</cfoutput>
<cfquery datasource="#ds#" name="Login">
SELECT username, password
FROM user_tbl
WHERE
username = '#form.username#'
AND
password = '#comparison#'
</cfquery>
SELECT Decrypt(password, form.username, "CFMX_COMPAT") FROM user_tbl WHERE username = '#form.username#'
</cfquery>
<cfif Login.RecordCount GT 0 AND Compare(Login.password, form.password) EQ 0>
Valid login
</cfif>
You have to use the same key & algorithm to decrypt and do the comparison.
SELECT password FROM user_tbl WHERE username = '#form.username#'
</cfquery>
<cfif Login.RecordCount GT 0>
<cfif Compare( Decrypt(Login.password, form.username, "CFMX_COMPAT"), form.password) EQ 0>
Valid login
</cfif>
</cfif>
Thanks but i am not really understand this line of code:
here is my code
</cfquery>
<cfset password = '#form.password#'>
<cfset key = 5>
<cfset encrypted ="#encrypt(password ,key)#">
<cfset Decrypted ="#Decrypt(encrypted,key)#">
and password ='#Decrypted#'
</cfquery>
Count:<cfoutput>#Login.recordcount#</cfoutput> it returns 0 even i enter the correct username and password
thanks
Since you used it in the code during encryption, I did the same to decrypt. Now I am completely confused with your code, please post the code you used to encrypt the password in your database. The same logic will go in the above line.
Mar 22, 2007 Mar 22, 2007
Enclosed two pages of insert and loginpage of how to encrypted and decrypted but it didn't work.
You have encrypted and decrypted the password means you still have the plain text password. Try the below one first, if it didn't work try the next part
<!--- login.cfm --->
<cfset key = 5>
and password ='#encrypted#'
</cfquery>
<cfif Login.recordcount gt 0>
valid
<cfelse>
not valid
</cfif>
<!--- login1.cfm --->
<cfset isUserAuthenticated = false>
<cfset key = 5>
</cfquery>
<cfset decrypted ="#decrypt(Login.password, key)#">
<cfif Compare(decrypted, Form.password) eq 0>
<cfset isUserAuthenticated = true>
</cfif>
</cfif>
it worked. thank you very much for your patient and your help.
Documentation
