I want to create a pdf that pulls in event details from a RSS feed. (I’m fairly new to Livecycle Designer ES)
http://www.eventfulreg.com/index.php/feeds/ff3065b338db9a7ccd616911540bdea2
The pdf will have a table with a number of rows containing event details..
Eg..
Event, | Location | Description | Date |
Event 1 | Belfast | An event | 1 October 2013 |
Event 2 | Dublin | 3 Octover 2013 |
How can I do this?
Do I need a WSDL file or XSLT or XSD file?
Thank you for your time,
Ollie.
Total Likes
Hi Ollie,
There is a GET function available in the FormCalc language. I tend to stick with JavaScript, so use a method of calling FormCalc functions described here, http://blogs.adobe.com/formfeed/2009/02/calling_formcalc_functions_fro.html.
So we can now get the feed, load up our data connection and bind our form fields to it, like;
var feed = FormCalc.Function.Get("http://www.eventfulreg.com/index.php/feeds/ff3065b338db9a7ccd616911540bdea2");
if (feed !== "")
$data.loadXML(feed, true, true)
xfa.form.remerge();
Assuming the binding on your form fields is correct you will get the contents of the feed displayed in your form. Here is a sample https://workspaces.acrobat.com/?d=iFgpUjUbXk5gobAVWRoBVg.
You might find that Reader throws up some warning messages so it might not be the best user experience.
Hope this helps
Bruce
Total Likes
