SELECT Auto Complete
Engaged ,
Sep 19, 2013 Sep 19, 2013
I have a SELECT dropdown on the form and would like to have a function while user type then the dropdown will get the most close record for user to select.
I tried to look on the internet, but no luck, It seems that CFSelect does not have this option.
Any information is great appreciated,
Iccsi,
701
Guide , Sep 19, 2013 Sep 19, 2013
Iccsi,
AutoComplete widgets typically don't use SELECT elements; they usually build off of a standard text input box.  While I strongly discourage using <CFINPUT> (or any of the built-in ColdFusion UI tags), it does have an "autosuggest" attribute that triggers the type of behaviour you are looking for.  However, I would recommend looking at using jQueryUI's "autocomplete" widget, TwitterBootstrap's "typeahead" widget, or any number of other JavaScript/CSS AutoComplete solutions.
HTH,
-Carl V.
Guide ,
Iccsi,
HTH,
-Carl V.
Engaged ,
Thanks a million for the information and help,
Iccsi,
Engaged ,
Sep 20, 2013 Sep 20, 2013
I use jQuery auto complete, it works, but the font size it too big for my application. I tried to find the property to modify it, notr luck.
I use CFQuery for the select output, the dropdown becomes slow, do I need use cfc function to get data using JSON format to help performance?
I have onchange event on the dropdown box, it does not trigger onchange event when I have jQuery auto complete.  Is it normal that auto complete and onchange event has conflct?
Thanks again for helping,
Iccsi,
Documentation
