Using RH v 10 on win 7.
I want the ordered lists in my topic to be left aligned (no indent). I look in my CSS file under OL and set left to 0px. Numbers are still indented. here's the HTML code for OL:
<ol style="list-style: decimal;">
In the CSS file, there is no style by this name (decimal). where is RH picking up this style?
My project is set to use my desired CSS file and i see the correct styles in styles list.
I see no style by name of "decimal"
Where else should i look? I assume this is a special RH numbering feature.
If i simply use <ol> for my tag there is no numbering in design view.
You must set the margin of the ol and li elements, for exaple:
ol {
margin-left: 0;
ol li {
margin-left: 0;
The decimal tells RH which numbering to use. You can remove it there and add the following to the OL in the CSS:
Greet,
Willam
