1. Re: Installed typekit fonts disappear in InDesign after restart.
Liz, Typekit Support Sep 16, 2013 9:14 AM (in response to Marcy McGuire)Hi Marcy,
I'm sorry that you ran into trouble with this. Would you please check which version of the Creative Cloud application you're running? You can find this by clicking the gear on the app, then choosing Preferences > Account.
And have you tried signing out of the Creative Cloud application and signing back in, instead of removing the fonts? That may also get the fonts to sync to your machine again, and would be an easier workaround while we figure out what is happening here.
You can post your answers here in the forum, or email us at support@typekit.com if you would rather. Thanks!
-- liz
2. Re: Installed typekit fonts disappear in InDesign after restart.
Marcy McGuire Sep 16, 2013 9:28 AM (in response to Liz, Typekit Support)Version 1.112.232 on OS 10.7.5. I'll try signing off and in later today and let you know if this works.
3. Re: Installed typekit fonts disappear in InDesign after restart.
Marcy McGuire Sep 16, 2013 11:38 AM (in response to Marcy McGuire)Yes signing off and then signing back in worked. Easier than removing and then redoing the fonts. But still not ideal.
4. Re: Installed typekit fonts disappear in InDesign after restart.
Liz, Typekit Support Sep 16, 2013 1:33 PM (in response to Marcy McGuire)Thank you for trying that, Marcy. Would you please send over your recent Creative Cloud log files, so we can look into why the fonts are not active after you reboot?
On OS X, they are in the directory:
$HOME/Library/Application Support/Adobe/CoreSync/CoreSync-yyyy-MM-dd.log
Please email them as attachments to support@typekit.com, and our engineering team will take a look. Thank you,
-- liz
5. Re: Installed typekit fonts disappear in InDesign after restart.
digikomm Sep 20, 2013 5:38 AM (in response to Marcy McGuire)Dear Typekit Support
I do have the exact same problem here. Also OS 10.7.5 + version 1.112.232 of CreativeCloud.
Is there already a solution?
Greetings
thomas
6. Re: Installed typekit fonts disappear in InDesign after restart.
Steve Werner Sep 20, 2013 7:53 AM (in response to digikomm)Use the Typekit support email address referenced above.
7. Re: Installed typekit fonts disappear in InDesign after restart.
Liz, Typekit Support Sep 20, 2013 8:03 AM (in response to digikomm)Hi Thomas,
Sorry to hear that you are seeing the same problem! We are still working on this issue; would you please send your recent log files to support@typekit.com ?
On OS X:
* Open the Finder
* under the Go menu, select "Go To Folder"
* in the windows that opens, type: /Users/(username)/Library/Application Support/Adobe/CoreSync/
Note that you need to replace "(username)" with your own account name.
(Or if you are comfortable working from the Terminal, cd to $HOME/Library/Application Support/Adobe/CoreSync/)
Thank you,
-- liz
8. Re: Installed typekit fonts disappear in InDesign after restart.
digikomm Sep 20, 2013 8:27 AM (in response to Liz, Typekit Support)Hi Liz
i've just sended my logfiles to the support team.
Note:
I do have a second installation on my macbook pro with the same account and versions (os 10.7.5., cloud 1.1.2.232) where everything works just fine.
Could the hardware or the access rights causes the problem? I do have only problems on my iMac (system+programm running on a SSD-Disk).
Greetings
thomas
9. Re: Installed typekit fonts disappear in InDesign after restart.
Liz, Typekit Support Sep 20, 2013 1:23 PM (in response to digikomm)Thanks, Thomas. I have your email and will ask the engineering team to take a look at the logs. We will follow up with you over email when we have some more info!
Best,
--liz
10. Re: Installed typekit fonts disappear in InDesign after restart.
VCOR Oct 17, 2013 2:16 PM (in response to Liz, Typekit Support)I'm getting the same problem, but running Windows 7 SP1, so it's not an OS specific issue. If I open Creative Cloud and login first, then the fonts are available to inDesign when a document is opened, which is a minor hassle. Hope it gets resolved!
InDesign CC v9.1 x64, latest update available.
11. Re: Installed typekit fonts disappear in InDesign after restart.
Marcy McGuire Oct 17, 2013 2:43 PM (in response to VCOR)I was told by typekit support the issue is a conflict with Suitcase Fusion 5, which disables the fonts after restart. Complicated, hey? I hope everyone works together to resolve the issue.
12. Re: Installed typekit fonts disappear in InDesign after restart.
Liz, Typekit Support Oct 17, 2013 3:07 PM (in response to VCOR)Hi VCOR,
The Creative Cloud desktop application does need to be running in order for the fonts to be synced to your machine. If you quit the app, they won't be available until you start it up again.
I just wanted to check that this is the behavior you are seeing? Please let me know if I misunderstood, so I can pass the details on to the team.
-- liz -
13. Re: Installed typekit fonts disappear in InDesign after restart.
VCOR Oct 17, 2013 3:37 PM (in response to Liz, Typekit Support)I think we're talking the same thing. I assume when you say "Creative Cloud desktop app" it is just labeled as "Creative Cloud" when you run it from Windows. Yes, it works fine if I launch it once before opening a document that uses a Typekit font. I wouldn't normally run it, as it doesn't seem to be needed for anything else (other than updates).
I'm not sure what Suitcase Fusion 5 is, but I assume it might be something installed by Adobe as part of the CC suite? I don't see it in Task Manager.
14. Re: Installed typekit fonts disappear in InDesign after restart.
Ken G. Rice Oct 17, 2013 5:40 PM (in response to VCOR)Suitcase Fusion 5 is not Adobe software - http://www.extensis.com/suitcase-fusion/.
The Creative Cloud application does several things: installs desktop applications, notifies you of and installs updates, handles Typekit fonts, handles file syncing, and connects with Behance.
15. Re: Installed typekit fonts disappear in InDesign after restart.
_lemoos_ Apr 5, 2014 4:22 AM (in response to Marcy McGuire)I have the same Problem on OSX 10.8
My synced Fonts disappear and neither logging out and logging back in nor unsync and syncing Fonts again is working.
Is there a Solution for that?
16. Re: Installed typekit fonts disappear in InDesign after restart.
Liz, Typekit Support Apr 7, 2014 3:19 PM (in response to _lemoos_)Hi lemoos,
I'm sorry that you ran into trouble with this. Would you please send your recent sync log files to support@typekit.com so that we can look into the problem?
Thank you,
-- liz
On OS X:
* Open the Finder
* in the window that opens, type: /Users/(username)/Library/Application Support/Adobe/CoreSync/
Remember to replace "(username)" with your own account name.
On Windows:
C:\Users\user name\AppData\Roaming\Adobe\CoreSync\
Attach the 3 or 4 most recent CoreSync-yyyy-MM-dd.log files to an email. Please don't send a zip file, as they often get flagged as spam.
17. Re: Installed typekit fonts disappear in InDesign after restart.
vumhoang Jun 12, 2014 7:36 PM (in response to Liz, Typekit Support)Do we have this problem fixed yet since I have to launch Creative Cloud app before opening any Adobe apps to get the fonts to work?
18. Re: Installed typekit fonts disappear in InDesign after restart.
towelboy02 Jul 15, 2014 10:05 AM (in response to vumhoang)I have the same issue. Everytime i restart computer, the typekit fonts won't sync when opening an indesign file. I would have to remove font and add it back for it to work. I've also tried signing out of adobe creative cloud and that works as well. Please fix issue!
19. Re: Installed typekit fonts disappear in InDesign after restart.
David__B Jul 15, 2014 5:21 PM (in response to towelboy02)Vumhoang and Towelboy02,
Could you collect the referenced logs like Lemoos and send them to support@typekit.com also.
- Dave
20. Re: Installed typekit fonts disappear in InDesign after restart.
Jonibean Oct 30, 2014 10:05 AM (in response to Marcy McGuire)I am having this problem as well, only on my iMac, it seems to be ok on my laptop. I was using Suitcase Fusion 4 yesterday, and installed Suitcase Fusion 5 today, but no change. Today I turned typekit on and off in creative cloud and it seemed to fix them.
21. Re: Installed typekit fonts disappear in InDesign after restart.
Ben Trissel Oct 30, 2014 10:35 AM (in response to Jonibean)Hi jonibean,
If you continue to have problems, please send an email to support@typekit.com and we will work to resolve the issue.
-Ben
