7 Replies Latest reply on Mar 22, 2007 6:57 AM by Newsgroup_User
    Automatic back to start of video
    Swarfega
      When a video I created has played its duration how do I get the video to go back to the start again ,but not play. I have created a play/ pause button that has the following actionscript:
      on (release){
      ns.pause("Cashel.flv");
      What must I do to amend this actionscript?
        • 1. Re: Automatic back to start of video
          Devendran Level 1
          just use
          ns.pause() (i hope your "ns = NetStream")
          or
          ns.stop()
          • 2. Re: Automatic back to start of video
            Swarfega Level 1
            I did this and it made no difference, unless I misinterpreted ur reply:
            on (release){
            ns.stop("Cashel.flv");
            • 3. Re: Automatic back to start of video
              Devendran Level 1
              Hi Don't pass any arguments inside these functions.
              my_ns.pause();
              //For first time it will pause if you use it second time it will play. if you wish to pass argument you have to pass a boolean value
              use this one to Rewind
              my_ns.seek(0)
              or use
              my_ns.close() to close the stream for more help you can refer flash help
              • 4. Automatic back to start of video
                Swarfega Level 1
                OK I did this:
                on (release){
                ns.pause();
                ns.seek(0);
                I press play and it plays, but it doesn't pause - just goes back to the start and waits for me to press play again. But yes when it finishes I can press play and it plays. Help me with the problem!
                • 5. Re: Automatic back to start of video
                  Devendran Level 1
                  Hi
                  What you want to do?
                  When pressed Play It should play?
                  when pressed pasue it should pause?
                  or do you want to loop the video?
                  • 6. Automatic back to start of video
                    Swarfega Level 1
                    When I'm hoping top achieve is that I press play it will play and when I press it again it will pause. It's the one button. When the duation of the film is over, I want it to return to the start of the movie, so it will play for the beginning when I press play again.
                    • 7. Re: Automatic back to start of video
                      Level 7
                      Swarfega,
                      It depends entirely on how the video has been presented in the Flash
                      Player. The FLVPlayback Component, for example, features a complete event
                      (this is listed under the VideoPlayer class's Event summary -- the
                      FLVPlayback class wraps a VideoPlayer instance).
                      (I hope I didn't sound tedious when asking for more information last
                      time, but this should help illustrate why good communication is important.
                      I can think of at least four completely different way to present an FLV to
                      the user, and each has its own unique class members [properties, methods,
                      and events].)
                      > actionscript:
                      > on (release){
                      Aha. This gives us a hint that you're dealing with a different
                      approach, which means you're not using the FLVPlayback Component. The ns
                      variable suggests you're using NetStream.
                      As an aside, I see you're passing in the nave of your FLV to the pause()
                      method, but the NetStream.pause() method only accepts a Boolean
                      (true/false). Since you want this button to be a toggle -- which I remember
                      from your other post -- you shouldn't actually be putting *anything* between
                      the parentheses.
                      Here's a tutorial on determining the end of a NetStream play.
                      http://www.wildform.com/support/tutorials/loopingFLVs/
                      David Stiller
                      Adobe Community Expert
                      Dev blog, http://www.quip.net/blog/
                      "Luck is the residue of good design."
