Before anything, I have read the different threads on the
potential reason why RH6 crashes when compiling with a conditional
build expression but none of these reasons seem to apply to my
problem.
I manage over 60 different RH projects so I have not tested
on all of them, but just one of them till now seems to be causing
problems.
The original project was an RH X5 project and just has just
four different conditional build tags: print, online, DVD and
internet. These build tags were indeed applied to some tables but
none of which had merged cells.
When I compile wihout using any build expressions, everything
works fine (independantly of the layout), when I specify a build
tag, RH6 systematically crashes (again independantly of the
layout).
After having made a back-up of the project, I went through
each topic, removing a build tag when I saw one a compiled. If it
crashed again, I just continued to the next build tag, deleted and
compiled. I hopefully thought by working recursively like this I
would find the area in the project where a build was causing RH6 to
crash. Hopeful thinking indeed because I ended up removing all the
biuld tags in the project but RH6 still crashed when compiling with
a build expression but with no build tags in any topics.
I then did another back-up and simply deleted all the build
tags from the project tab. I compiled and no crash (normal because
no build expression was then possible). I then recreated one of the
default build tags (print), did not apply it to any topic and tried
generating my project with the build expression "print"... and
bam-kadaboom! It crashed again.
I then proceeded to recreate a new RH6 project and imported
all the files from my RH5 project. Here again, no positive outcome.
I feel like I have tried everything and nothing seems to be
working with this particular project (again I have other projects
with over 30 build tags and they are working fine).
Does anybody have any idea what might be causing the problem?
Many thanks for any valuable advice.
Chris.
PS:
1. Another thing that seemed wierd to me, I even deleted the
rhbuildtag.apj file to see what would happen, and funny enough RH6
when I opened it still referenced the build tags. Is there another
project file that defines the build tags?
2. Nothing to do with this problem; but I saw that RH6, when
importing files from a RH X5 project, does not keep the topic title
as defined in the orginal file. Instead, the topic names are
renamed with the actual htm file name without the .htm extension.
Is this a known issue?
