Show 4 replies
1. Re: Selecting a clip's in and out point
joe bloe premiere Sep 23, 2013 12:03 PM (in response to Lone Lobo)Set or remove sequence In and Out points
Set sequence In and Out points around a selection
"In a Timeline panel, select one or more clips, or a gap, in the sequence.
Choose Marker > Mark Selection. This sets sequence In and Out points
that match the selection’s In and Out points." -
2. Re: Selecting a clip's in and out point
Lone Lobo Sep 23, 2013 12:21 PM (in response to joe bloe premiere)Thanks!!!!!!!
3. Re: Selecting a clip's in and out point
Kevin-Monahan Sep 23, 2013 1:22 PM (in response to Lone Lobo)Hi Lone Lobo,
You can also use Mark Clip. You don't need to select the clip, just the track needs to be selected. There's a select In to Out command in Premiere Pro CC, as well, however you have to set it.
Kevin
4. Re: Selecting a clip's in and out point
JSS1138 Sep 23, 2013 4:50 PM (in response to Lone Lobo)Hit the / key.
