Working happily in Design view using RH 10, and from one moment to the next the Design View display changed. The font display has changed to a truncated style and the word wrap has disappeared.
I tried rebooting and then reinstalling and no luck in getting rid of the issue.
The output is fine and as expected, so I am presuming that it isn't the CSS. Which I haven't edited for eons anyway so it really shouldn't be that anyway.
This is happening on all my help projects - each with a different CSS - so it can't be the css unless RH did some sort of strange global change behind the scenes without my knowledge.
Any thoughts on how to get Design View to display normally would be much appreaciated,
Tannis
Check the zoom setting. It used to be on the toolbar near the font and style information. It may be more than 100% (used to be a problem with older versions, and I don't have a newer version to check if it's been fixed).
Brilliant! You were right. It was a zoom issue. I never use zoom so not sure how it happened, but doesn't matter. It is fixed now.
Thank you,
Tannis
Hi there
One possible suspect you may be unaware of is pressing and holding the Ctrl key as you rotate the wheel of a mouse. There may be a keyboard shortcut that would do this too.
Cheers... Rick
