I'm really frustrated by this error. I was using flash builder 4.5 with no issues; I was able to get my first flash project on my android device. I updated my flash builder to 4.6 - and as a part of this process was told to uninstall the previous (Flash Builder 4.5) version. I installed, imported my old project - made a few reference changes and was able to get the desktop simulator to work with Flash Builder 4.6.
Now, I want my new project to run on my android and test with a gps sensor. I export release build - go through the steps I went through before and instead of it working; I get an error that my dx tool failed. No mention of what failed within the dx tool, just that it failed and I can't be helped. I rebooted my computer, same issue. I created a new project with nothing but just the stock project - still nothing worked. I uninstalled, rebooted, reinstalled, created a new project and I'm still not working. How can I fix this and get back up and running?
I attached a screenshot of my error.
This was resolved after a ton of work and looking into the root of the issue. Basically, I had a corrupted install of JRE that was related to an attempt to install Tomcat. If anyone else has this issue, try uninstalling JRE and reinstalling a clean copy.
By the way, this seems to be an issue with the signing process. I have created several new provisioning certificates and still no luck. I can export with the sign later option, and no problem.
New information. The log is spitting out this error:
!ENTRY com.adobe.flexbuilder.project 4 43 2012-03-01 18:56:44.039
!MESSAGE dx tool failed:
!STACK 0
java.lang.Exception
at com.adobe.flexbuilder.project.internal.FlexProjectCore.createErrorStatus(FlexProjectCore.java:1019)
at com.adobe.flexbuilder.util.logging.GlobalLogImpl.log(GlobalLogImpl.java:66)
at com.adobe.flexbuilder.util.logging.GlobalLog.log(GlobalLog.java:52)
at com.adobe.flexbuilder.multisdk.apollo.export.AIRAPKPackager.create(AIRAPKPackager.java:190)
at com.adobe.flexide.multiplatform.android.exportrelease.AndroidExportReleaseHandler.doPackage(AndroidExportReleaseHandler.java:234)
at com.adobe.flashbuilder.project.multiplatform.ui.exportrelease.MultiPlatformExportReleaseVersionManager.doExport(MultiPlatformExportReleaseVersionManager.java:198)
at com.adobe.flexbuilder.exportimport.releaseversion.ui.ExportReleaseVersionWizard$1.run(ExportReleaseVersionWizard.java:208)
install latest jre from oracle
Go to Program Files Adobe Flash Builder into jre/bin
run javacpl.exe(administor)
open java tab and select wiew
next windows uncheck 1.6
check 1.7
reopen flash builder
and rleas build app
ı try this and finaly no problem
Thx a lot . You saved my time. it worked for me!
I have do all the check fellow your guide !
But why whe same error still occured .
I have upgraded the newest version for JRE and re-open flash builder again !
below is my snap of JRE
would you like help me more about this issue ?
other word , I really need your help for this problem !
thanks a lot !
restarting flex would help.
actual, I done all the steps , then re-start flash builder, still appeard that error .......
can anybody have idea about that situation ?
Your post hav helped me a lot. I have saved a hell lot of time. thx a lot and keep posting.
