Assuming it all works OK on a server, then the issue is that
while MOW works OK with the help itself, the external links do not
work.
First, under IE6 you had to change IE settings to allow the
help to run in the first place and that tweak is, I believe, what
would have allowed the external links to work. So in theory whilst
RH6's MOW allows the help to run, the same settings need to be
tweaked in IE7 for the external links. Does that make sense and
have you checked that out?
Second, I wonder if a FlashHelp output would be better? I
haven't used and would appreciate others coming in but given the
multiple locations your help will be used from, perhaps that would
be a better format.
