1. Re: Flash cs6 debugger won't stop on breakpoints - productivity killer bug
saariko May 22, 2013 1:40 AM (in response to saariko)Adobe representative?
2. Re: Flash cs6 debugger won't stop on breakpoints - productivity killer bug
Santanu Karar Sep 23, 2013 10:53 PM (in response to saariko)This is shamefully distasteful. Adobe should concentrate more on product Q/A than its cloudscope releases. Debug in Flash CS6 fully broken.
3. Re: Flash cs6 debugger won't stop on breakpoints - productivity killer bug
Amy Blankenship Sep 26, 2013 9:03 AM (in response to saariko)Are you sure that you are connecting the debugger to the most recent swf? I had this problem yesterday, because there was a redirect in the asp code that was hard-coded to load the swf from a different server. I didn't notice the issue until I looked really hard at what I was seeing in the console. So double-check to make sure the path you see at the top when the debugger launches is the same as where you expect your swf to be.
4. Re: Flash cs6 debugger won't stop on breakpoints - productivity killer bug
Santanu Karar Sep 26, 2013 9:08 PM (in response to Amy Blankenship)Hi Amy, thanks for showing concern. No, there were no such scenario with my SWF since I had created a new AIR type of project with Flash CS6 installed. I don't know how really we can explain this problem (debugging) with a newly installed software; but simply the debugger never worked with the installation, so I just removed and moved to MacOS where it was working at least.
I am not sure even if the Flash CS has some dependencies - if I consider its the issue with my PC (installation).
