Hi Lon
In case Lori's suggestion wasn't what you were looking for,
you may also be seeing a feature of RoboHelp HTML. This feature
allows selection of alternate HTML editors if you so choose. Well,
actually it's the default.
What RoboHelp HTML does is looks at the meta tag inside the
HTML code to see which editor created the file. In your case, it
may be sensing Word and instead of opening the HTML topic in the
RoboHelp HTML WYSIWYG editor, it opens Word.
If I've understood this correctly, here is the fix. Within
RoboHelp HTML, click Tools > Options... > HTML Editors tab.
Ensure RoboHelp WYSIWYG is the default editor. It should be as
that's the default. Now look near the bottom of the dialog. You
should see two options. One labeled "Auto-select Editor" and
another labeled "Use Default Editor". My guess is that Auto-select
is configured as it's normally the default. So choose "Use Default
Editor", click OK and you should be set. Unless, of course, I've
misunderstood the situation.
Cheers... Rick
