This issue has reared its ugly head again. See old post:
http://forums.adobe.com/thread/507750?
The script has worked great, however now our client is using Acrobat X and cannot get the script to install in that version.
Does anyone know if a new script is available for the newer versions of Acrobat?
Solved! Go to Solution.
Total Likes
The script was indeed updated, but in Joel's new blog.
http://blog.practicalpdf.com/2013/08/introducing-the-practicalpdf-fix-form-utility/
Hope this helps.
Total Likes
I don't use OS X, but I found this post here that might be helpful for you.
http://khkonsulting.com/2013/06/preview-app-killer-of-pdf-files/#more-787
Thank you. Yes, the article that you provided does address the very issue that we are facing. However, unfortunately we do not have access to the recipients' Mac settings.
The script that this article referenced is the one that we have been using and it worked very well. Unfortunately, it does not seem to work with the newer versions of Acrobat. Essentially, we are looking for an updated script?
Total Likes
Hope this helps.
Total Likes
Thank you! This is exactly what we needed.
Total Likes
