display times
Guest
Mar 23, 2007 Mar 23, 2007
i have a diary system, which shows times on a page ie
08:00
09:00
10:00 ect
these are displayed from my table as users.starttime to a users.endtime using a increment column = 60
what i need to do is if a diary entry is inserted into my diary table as
DiaryDate = 2007-04-12
DiaryTime = 08:00:00
DiaryuserID = 1
DiaryWith = paul
DiaryPeriod = 120
i need to display the record above in 2 time slots, as the diaryperiod is 120mins ie
08:00 paul
09:00 paul
10:00
but this could change if the increment in my users table gets altered by the user.
any ideas
Advanced techniques
1.5K
Guest
Mar 24, 2007 Mar 24, 2007
One way to do this is to have a database table that contains the columns the fields you describe above. Query the database, sorting on DiaryDate, DiaryTime.
If you get a data/time match when displaying the time slots, output the DiaryWith value.
Guest
yes thats exactly what i have now but the problem is, i have
08:00
08:30
09:00 etc displayed on the page,
a user enters a new appt using these form fields, which gets put into my database.
DiaryuserID = 1
DiaryWith = paul
Duration = 90
the duration is 90 mins so i need to display it against 3 time slots
08:00 paul
08:30 paul
09:00 paul
Guide ,
JohnGree,
If you know the duration and the interval, then you can calculate the number of time slots used for each appointment.
Duration / Interval = Number of time slots
90 / 30 => Number of time slots => 3
Can't you simply use that number in your output loop to display the name "Paul" 3 times (ie number of time slots)?
08:00 paul
08:30 paul
09:00 paul
Guest
ok thanks that sounds good, how would i add that loop to my current code below ie
if i cfset display = Duration / Interval
how would i add #display# to the loop?
<cfset steptime = getevents.starttime>
<cfloop condition="DateCompare(StepTime, getevents.EndTime) LT 1">
<cfquery name="GetClients" datasource="#application.ds#">
SELECT *
FROM Diary_Table C
INNER JOIN USERS_Table f
ON C.DiaryPlayerID = f.PlayerID
WHERE C.DiaryDate = '#session.SHORTDATE#' AND C.DiaryTime = <cfqueryparam value="#steptime#" cfsqltype="CF_SQL_TIMESTAMP">
</cfquery>
<cfoutput>
<tr bordercolor="##000066">
<td>#TimeFormat(StepTime, "hh:mm")#<cfset StepTime = dateadd("n", getevents.Increment, StepTime)></td>
<td><cfoutput>#GetClients.name#</cfoutput></td>
<td>#GetClients.DiaryWith#</td>
</tr></cfoutput>
</cfloop>
Guide ,
With that loop, the first suggestion might be simpler coding. But try a QoQ inside the loop to reduce database hits. I confess I'd do it differently, but thats probably more complex than what you need here.
[UPDATE] Fixed query typo: DateAdd(n, Duration-1, DiaryTime) AS EndTime [/UPDATE]
Guest
Mar 25, 2007 Mar 25, 2007
hi i have tried that but i get this error below i am using mysql
Error Executing Database Query.
Column not found: Unknown column 'n' in 'field list'
The error occurred in D:\inetpub\vhosts\golfprodiary.com\httpdocs\CalendarCurrent.cfm: line 30
SELECT PlayerFirstName, PlayerSurname, DiaryWith, DiaryTime AS StartTime,
DateAdd(n, Duration, DiaryTime) AS EndTime
FROM Diary_Table C
INNER JOIN users f ON C.DiaryPlayerID = f.PlayerID
WHERE C.DiaryDate = <cfqueryparam value="#session.SHORTDATE#" cfsqltype="CF_SQL_TIMESTAMP">
</cfquery>
Guide ,
Its probably the DateAdd function. The syntax can vary depending on the database. Check your database documentation.
Guide ,
Guest
ok i have thr code below but nothing displays against the times ie
the page displys fine but no records get attached to the time slots
DATE_ADD('DiaryTime',INTERVAL Duration MINUTE) AS EndTime
FROM Diary_Table C
INNER JOIN SMS_Players_Table f ON C.DiaryPlayerID = f.PlayerID
</cfquery>
<cfquery name="GetAppointment" dbtype="query">
FROM GetClients
WHERE StartTime <= <cfqueryparam value="#steptime#" cfsqltype="CF_SQL_TIMESTAMP">
AND EndTime >= <cfqueryparam value="#steptime#" cfsqltype="CF_SQL_TIMESTAMP">
</cfquery>
<cfoutput>
<td bgcolor="##CCCCCC" class="StandBlack">#TimeFormat(StepTime, "hh:mm")#</td>
<td bgcolor="##CCCCCC" class="StandBlack">#GetAppointment.PlayerFirstName# #GetAppointment.PlayerSurname#</td>
<td bgcolor="##CCCCCC" class="StandBlack">#GetAppointment.DiaryWith#</td>
<td bgcolor="##CCCCCC"><div align="center"><cfif GetClients.PlayerSurname is not ''>
<a href="SMS_Recipients.cfm" onclick="newWin(this.href,350,250,'no','yes'); return false;"><img src="images/dtick.gif" width="15" height="17" border="0"></a>
</cfif></div></td>
<td bgcolor="##CCCCCC"><div align="center"> <cfif GetClients.PlayerSurname is not ''>
<a href="SMS_Schedule_Delete.cfm"><img src="images/dx.gif" width="15" height="17" border="0"></a>
</cfif></div></td>
</tr>
</cfoutput>
</cfloop>
Guide ,
What are the types of the DiaryDate and DiaryTime columns?
What is a sample of the values in those columns?
Guest
DiaryDate = 2007-03-24
DiaryTime = 11:00:00
Guide ,
What are the types of the DiaryDate and DiaryTime columns: Date, Timestamp.. ? Same for Getevents.EndTime
Guest
DiaryDate = DATE
DiaryTime = time
Getevents.EndTime = time
Guide ,
I'm not that familiar with MySQL functions. The documentation says Date_Add accepts a date or datetime value. I suspect passing in a "time" value is causing problems.
Without changing the column types, I could only get it to work using an ugly sequence of nested functions. I'm certain there is a cleaner way. You might post your question in the database forum. Someone more experienced with MySQL could provide a better answer to your question.
Guest
ok i have changed the DiaryTime to a DATETIME
but it still is not displaying?
Contributor ,
Hi, your code references a query called 'getevents' - can you post that query?
Also, have you checked the GetClients query is actually picking up data? try adding a cfdump of the GetClients query to confirm there is data there for the QofQ.
ie. add <cfdump var="#GetClients#"> after the GetClients query.
Guest
hi the query is below, i have tried all different dateadd functions from the mysql website but still no luck
FROM Diary_Table C
</cfquery>
Contributor ,
ok, thats the "getClients" query but where does "getevents" come from?
also see my note above re: cfdump.
cheers.
Guest
ok yes the cfdump works fine but i get
2007-03-24 11:30:00.0 as the ENDTIME is that correct
<CFQUERY datasource="#application.ds#" Name="getevents">
SELECT *
FROM SMS_Clubs_Table
WHERE ClubID = '#session.ClubLogin#'
</cfquery>
Guide ,
> could i change them all to datetime would that work
Since I'm not familiar with the nuances of time and date fields in MySQL I can only offer gueswork. You're better off getting advice from someone that uses MySQL.
Playing around with the original column types, the best I could come up with is
SELECT Name, DiaryWith, DiaryTime AS StartTime,
SEC_TO_TIME(TIME_TO_SEC(DiaryTime) + ((Duration-1) * 60)) AS EndTime
FROM Diary_Table C INNER JOIN USERS_Table f ON C.DiaryPlayerID = f.PlayerID
Good Luck
Guest
Mar 26, 2007 Mar 26, 2007
ok cf_dev2
that works, only one thing though if i have two entrys in my table for the same time but different appointments, i need to show them like this
11:00 paul
John
12:00 jeff
at the min it only shows paul, do you know how i can do this
Guide ,
If you won't have empty values, try the ValueList() function. Use a line break as the delimiter.
Documentation
