I am working on a large Robohelp 7 HTML project (3,280 files in db), that was cloned from an existing project. Whenever I open it, it hangs at "Loading DB Info..." for an hour or more. It's CPU Usage swells to 50-60% of CPU capacity, and the Memory Usage will stay bloated at 185MB (vs. about 4MB for the old source project)
Also, when I "Save All" the first time each day, it hangs up for an hour or two. After that, "Save All" (and everything else) functions normally...
I notice that the cloned project now has 2 .cpd files (and 2 corresponding .brs files)--a normal-sized one (4MB) carrying the old source project's name, and another humonguous .cpd file (85MB) with the new cloned project's name. Could this be a symptom or cause of my opening and saving problems?
The bloated CPD may very well be causing a slow project. You can safely delete the CPD files (RoboHelp will create a new one when you reopen the project.)
If you want to be sure, make a backup of the CPD files just as a precaution.
Greet,
Willam
Just to add to what Willam has said, can you tell us what you mean by "cloned". I ask because it is not normal to have two of any project file in the same directory. Whilst deleting the CPD files may solve this issue, I wonder if you'll get other issues further down the line.
"Cloned" isn't a very good description... I created the new project by copying the entire DB of the old source project, then renamed the new project.
Define DB. You can create a new project by copying the whole project but if you are only copying parts nothing would surprise me.
Peter,
Thanks for the help… I had copied an entire project—I was leary of just copying parts.
Deleting the .cpd files fixed all of my problems it seems…
Cheers,
Jamie
