6 Replies Latest reply: Oct 10, 2014 12:18 AM by moszapy1 RSS
    RH10 not creating XML files in whxdata
    MAHorniak Community Member
      We converted from RH7 to RH10 earlier this year, and our application uses the XML files in whxdata to connect help buttons to topics.  It seems that RH10 is not creating these XML files, which is breaking this functionality.
      Some searching indicates that these files should be created when the primary WebHelp layout is being built.  I can't find any settings anywhere that indicates whether or not they should be created.
      Is this a consequence of the conversion, or does RH10 not create these files anymore?
        • 1. Re: RH10 not creating XML files in whxdata
          Captiv8r CommunityMVP
          Hi there
          First off, it always helps to check the basics. Are you certain you are looking at the correct location?
          Assuming you are, look at the properties for the single source layout. Specifically, the Navigation section on the left side and the "Optimize Speed for" option on the right side.
          Click the image below for a larger and clearer view
          As far as I'm aware, this is the specific setting that determines whether your navigational elements are broken into smaller chunks.
          Lastly, I'm a bit confused. To my knowledge, only the navigational elements (TOC, Index, Glossary and Search) are affected and XML data created for these. I'm rather surprised to hear that your development team is somehow using the XML files created for these in order to establish context sensitive help.
          Cheers... Rick
          • 2. Re: RH10 not creating XML files in whxdata
            I'm not sure what practice established using the XML files, but I know that they could not connect the help topics if there was not an index entry for the topic.
            I have checked all of these settings, and they do not change the output.
            I should clarify, though, that there are files being generated, just not the ones that we would prefer.  See the screenshot below.xmlstuff.png
            • 3. Re: RH10 not creating XML files in whxdata
              Ahhh forgot about that. Yep, the dev team renamed them all from .XML to the .JS. Not sure why.
              You might consider submitting a bug report as this affects you.
              http://www.adobe.com/go/wish
              Cheers... Rick
              • 4. Re: RH10 not creating XML files in whxdata
                moszapy1 Community Member
                Hi MAHorniak,
                Yes, for better output experience RoboHelp is creating JS instead of XML. If you still need XML compatible with older RH version, we can provide you a script which can convert index JS file back to XML format. You can download the VBScript file from https://workspaces.acrobat.com/?d=kSpoteg40Fi*Z3*f0QNTxg
                How to use:
                1. Download script to some local folder where you have write access.
                2. Run script and give path of whidata0_xml.js which can be found in whxdata folder in your generated WebHelp output.
                3. Click OK to complete the conversion operation
                Result: File named whidata0.xml will be created at <MyDocuments>\RoboHelp_xml.
                The generated XML file is ready for your workflows
                Thanks and Regards,
                Mohd Sameer.
                Adobe RH team
                • 5. Re: RH10 not creating XML files in whxdata
                  Amit Agarwal Adobe Employee
                  Since workspaces.acrobat.com is retiring soon, placing the (above) refered file here itself:
                  Set objFSO = CreateObject("Scripting.FileSystemObject")
                  Set wshshell = CreateObject("WScript.Shell")
                  Documents = wshShell.SpecialFolders("MyDocuments")
                  startWriting=false
                  sCurPath = Documents+"\RoboHelp_XML"
                  if not objFSO.folderexists(sCurPath) then
                            objFSO.CreateFolder(sCurPath)
                  end if
                  xmlfilePath=sCurPath+"\whidata0.xml"
                  bThrowUI=1
                  strMyXML=""
                  message="Provide full path of whidata0_xml.js file"+vbcr+"eg. C:\output\whidata0_xml.js"
                  title="Index JS to XML convertor"
                  if WScript.Arguments.count=1 then
                  jsFilePath= WScript.Arguments(0)
                  bThrowUI=0
                  end if
                  if bThrowUI=1 then
                  jsFilePath = InputBox(message, title, new_build,6000 ,5000)
                  end if
                  if jsFilePath="" then
                  msgbox "Action cancelled"
                  Wscript.quit
                  else
                  if not objFSO.fileexists(xmlfilePath) then
                            objFSO.CreateTextfile(xmlfilePath)
                  end if
                  if not objFSO.FileExists(jsFilePath) then
                            msgbox("Specified JS file could not be found")
                            Wscript.quit
                  end if
                  Set objFile = objFSO.OpenTextFile(jsFilePath, 1)
                  set writefile=objFSO.OpenTextFile(xmlfilePath,2)
                  Do Until objFile.AtEndOfStream
                      strCharacters = objFile.Read(1)
                            bSkip=false
                      if strcomp(strCharacters,"<")=0 then
                            startWriting=true
                            end if
                            if startWriting=true then
                                      if strcomp(strCharacters,"\")=0 then
                                                bSkip=true
                                      end if
                                      if strcomp(strCharacters,">")=0 and NOT bSkip then
                                                strMyXML=strMyXML+strCharacters+vbcrlf
                                      end if
                                      if not strcomp(strCharacters,">")=0 and NOT bSkip then
                                                'writefile.strCharacters
                                      end if
                            end if
                  Loop
                  length=len(strMyXML)
                  writefile.Writeline Left(strMyXML,length-2)
                  writefile.close
                  if bThrowUI=1 then
                  msgbox "Required xml file successfully created at "+sCurPath
                  end if
                  end if
                  ~Amit Agarwal
                  • 6. Re: RH10 not creating XML files in whxdata
                    We have updated the script to recursively convert all RH10/11 js inside whxdata and resource folder in to XML format. The steps to use the script is as follows:
                    2)      - Double click on the script.
                    3)      -  Provide path of whxdata folder of RH10/11 output. All the js files will be converted to XML and will be placed in My Document\RoboHelp_XML. Now copy all the XML thus created and place it inside                   whxdata folder of RH10/11 output. If any message to override file is thrown then select not to override. Also, Keep all original js files intact.
                    4)      - Provide path of resource folder of RH10/11 output. Resource js will be converted to XML and will be placed in My Document\RoboHelp_XML. Copy this XML and place it inside resource folder of RH11      output. If any message to override file is thrown then select not to override. Keep all original js files intact.
                    ------------------------------------------------------------------------------------------ --------- Script starts----------------------------------------------------------------------------------- ----------------------------------------------------
                    startWriting=false
                    end if
                    set objsCurPath=objFSO.GetFolder(sCurPath)
                    for each oldFilePath in objsCurPath.Files
                      objFSO.DeleteFile(oldFilePath)
                    next
                    bThrowUI=1
                    strMyXML=""
                    message="Provide full folder path where js files are present"+vbcr+"eg. C:\output\whxdata"
                    title="Robohelp output JS to XML convertor"
                      bThrowUI=0
                    end if
                    if bThrowUI=1 then
                      jsFolderPath = InputBox(message, title, new_build,6000 ,5000)
                    end if
                    if jsFolderPath="" then
                      Wscript.quit
                    else
                      if not objFSO.FolderExists(jsFolderPath) then
                      msgbox("Specified JS folder could not be found")
                      Wscript.quit
                      end if
                      set jsFolder=objFSO.GetFolder(jsFolderPath)
                      for each jsFilePath in jsFolder.Files
                      strMyXML=""
                      startWriting=false
                      if lcase(objFSO.getExtensionName(jsFilePath.path))="js" then
                      xmlfilePath=sCurPath+"\"+Left(jsFilePath.name,Len(jsFilePath.name)-7)+".xml"
                      end if
                      bSkip=false
                      startWriting=true
                      end if
                      bSkip=true
                      end if
                      end if
                      end if
                      end if
                      Loop
                      writefile.close
                      end if
                      next
                    end if
                    if bThrowUI=1 then
                    end if
                    ------------------------------------------------------------------------------------------ --------- Script ends------------------------------------------------------------------------------------- --------------------------------------------------
                    Thanks and Regards,
                    Mohd Sameer.
                    Adobe RH team
