I assigned the Map IDs and associated the project with that Map ID file.
In the CSH Test, I chose Offline and navigated to a file. In the Map Number field, I browsed to the Map ID file and clicked on the dropdown arrow to locate the corresponding Map ID. I then clicked OK and nothing happened.
Is this happening on the same project that you are having issue loading? If so, the problems could be related. Hold fire on testing your CSH until we have the other issue fixed. Then try again and let us know how you get on.
I am having the same issue with the CSH Test tool. I've tried it with Mapped Topics that I know are working on our system and I still don't see any output. Is this feature broken?
RoboColum(n), that fixed the problem. Thanks!
