1. Re: Receiving 2-channel mono L and R stems - how to export as Stereo?
JSS1138 Oct 3, 2013 7:05 PM (in response to Creatively Bankrupt)dual-channel mono.
That's something of an oxymoron, isn't it? Mono by definition is one channel. Stereo by definition is two. So if you have two channels...
Or are you saying that both channels are centered, instead of the expected left and right?
2. Re: Receiving 2-channel mono L and R stems - how to export as Stereo?
Creatively Bankrupt Oct 4, 2013 3:00 PM (in response to JSS1138)A stereo track should have individual levels for each channel.
My two mono tracks L and R each have their own levels, as expected. But when exporting from Premiere as stereo, it is centering the two channels, giving the appearance of a dual mono track, with both L and R having identical levels.
I am trying to figure out how to export a stereo file from Premiere that mainstains the individual L and R levels that the two mono channels originally had.
3. Re: Receiving 2-channel mono L and R stems - how to export as Stereo?
Bill Hunt Oct 4, 2013 3:47 PM (in response to Creatively Bankrupt)I would look at splitting that Dual-Mono into discrete files. Audition can do this easily.
Then Import those two Mono Audio files, and in Audio Mixer, Pan the desired one to full Left, and the other to full Right. That should get you close. If you do not go FULL Left & Right, you will get a bit of Phantom Center, which is usually not an undesired situation.
Good luck,
Hunt
4. Re: Receiving 2-channel mono L and R stems - how to export as Stereo?
Creatively Bankrupt Oct 4, 2013 3:51 PM (in response to Bill Hunt)I have the original delivered audio as discrete L and R mono channels. The dual-mono is happening when I export, where what I really want is a stereo track.
My exports are constantly being flagged as mono from clients, any time I start with delivered individual mono audio stems, then export those 2 individual channels as a stereo wav/aif/etc.
5. Re: Receiving 2-channel mono L and R stems - how to export as Stereo?
Bill Hunt Oct 4, 2013 4:52 PM (in response to Creatively Bankrupt)Excellent. I had missed that aspect - sorry.
As you have Imported your discrete Mono (1-channel) Clips into your Project, drag them to separate Audio Tracks.
Then go to Audio Mixer, and Pan one Left and one Right.
If your Master is set to Stereo (2-channel), you should then get the mix-down to that, with Export.
Hope that I am not missing something else, but will apologize in advance, if I am.
Good luck,
Hunt
6. Re: Receiving 2-channel mono L and R stems - how to export as Stereo?
Ann Bens Oct 5, 2013 8:57 AM (in response to Creatively Bankrupt)Could you upload a small file?
7. Re: Receiving 2-channel mono L and R stems - how to export as Stereo?
JSS1138 Oct 5, 2013 11:52 PM (in response to Creatively Bankrupt)I am trying to figure out how to export a stereo file from Premiere that mainstains the individual L and R levels that the two mono channels originally had.
Be sure to send each tracks output to only one side in the Mixer window.
8. Re: Receiving 2-channel mono L and R stems - how to export as Stereo?
Creatively Bankrupt Oct 7, 2013 3:44 PM (in response to Bill Hunt)Bill and Jim - you guys rock!
It seems so simple and obvious in hindsight too - but adjusting the mixer for each mono track to only be active on their intended speaker solved my problem.
Thanks again!
