1. Re: Show FPS in info panel on Premiere Pro
shooternz Oct 7, 2013 1:36 PM (in response to GM55A)Real time means "realtime".
CC is showing plyaback speed in fps ..not realtime.
2. Re: Show FPS in info panel on Premiere Pro
GM55A Oct 7, 2013 1:45 PM (in response to shooternz)So let's forget the 'realtime' moniker and answer the question if you can.
MT
3. Re: Show FPS in info panel on Premiere Pro
petergaraway Oct 7, 2013 3:06 PM (in response to GM55A)We don't disply fsp during playback as AE does. But you can try the following:
From the Program monitor or Source monitor wing menu you can enable the 'Show Dropped Frame Indicator'. This will let you know if your dropping frames and how many (by hovering over the yellow dot). If the dot stays green during playback you dropped no frames and are getting real time playback.
Hope this is helpful.
Peter Garaway
Adobe
Premiere Pro
4. Re: Show FPS in info panel on Premiere Pro
shooternz Oct 7, 2013 2:25 PM (in response to GM55A)So let's forget the 'realtime' moniker and answer the question if you can.
Playback is same as the Sequence Setting. It wont vary.
Why do you need to see it displayed? (just asking).
5. Re: Show FPS in info panel on Premiere Pro
GM55A Oct 7, 2013 2:44 PM (in response to petergaraway)Thanx Peter and I was aware of that but I wanted to see if there was something in PPro similar to the AEX info that shows playback FPS.
Mac
