1. Re: Bizarre audio sync issues
Richard M Knight Oct 8, 2013 7:13 AM (in response to Lone Lobo)Are you sure the lower third is video only
2. Re: Bizarre audio sync issues
Lone Lobo Oct 8, 2013 7:30 AM (in response to Richard M Knight)My graphics guy says there is no audio imbedded at all. However, when I import I see the small box in the lower right corner of the icon view indicating audio and when I open it in the source monitor it shows the icons indicating I can drag video and/or audio. However, there IS no audio. At least no waveform. And the AE comp is being created with no video or audio component.
3. Re: Bizarre audio sync issues
Lone Lobo Oct 8, 2013 8:22 AM (in response to Lone Lobo)I found that the AE comps were at 25 frames per second. When I changed that to match my timeline of 29.97fps most of the out of sync problems disappeared. I would have thought that Premiere would warn or convert frame rates to match the timeline rather than getting really really confused.
Thanks for the help guys!
4. Re: Bizarre audio sync issues
JSS1138 Oct 8, 2013 8:41 AM (in response to Lone Lobo)Premiere Pro only warns you for the first clip you add that doesn't match the sequence. After that it's up to the editor to get things right.
