1. Re: Adjustment Layers causing clips to stutter Premiere Pro CC
Vinay Dwivedi Oct 7, 2013 8:18 PM (in response to AzzieScott)Hi AzzieScott,
Thanks for your post. Have you tried rendering the project?
Also, try to export the part of the clip where you notice this issue and check whether exported file has the same issue or not.
Vinay
2. Re: Adjustment Layers causing clips to stutter Premiere Pro CC
AzzieScott Oct 7, 2013 8:32 PM (in response to Vinay Dwivedi)Vinay, I have done that as a troubleshoot option. I even set my in and out points just for a few clips that the issue was happening and when I played back my exported clips they play fine, but while in PP they are choppy at the same spot. When I disable the adjustment layer the clips play fine with no issues. And yes I have rendered the whole project, I have even cleared the cache and tried resetting the preferences. Its something with the adjustment layer.
3. Re: Adjustment Layers causing clips to stutter Premiere Pro CC
Vinay Dwivedi Oct 7, 2013 8:41 PM (in response to AzzieScott)Hi AzzieScott,
Thanks for the reply. Have you tried changing the preset applied to the adjustment layer? Please mention the source of the files you are using in your project.
Vinay
4. Re: Adjustment Layers causing clips to stutter Premiere Pro CC
AzzieScott Oct 7, 2013 8:45 PM (in response to Vinay Dwivedi)I downloaded the preset from the Internet. I cant remember what site I got it from. It was a while ago. Do you think that has something to do with it? A compatibility issue?
5. Re: Adjustment Layers causing clips to stutter Premiere Pro CC
Vinay Dwivedi Oct 7, 2013 8:55 PM (in response to AzzieScott)Hi AzzieScott,
Thanks for the reply. Adjustment layer having dip to black applied on it works fine almost with all the formats supported by Premiere Pro. I'm not sure about the preset as it may be an issue with the interpretation of that preset done by Premiere Pro or may be a compatibility issue . Please provide me the details, if possible, so that it can be tested.
Vinay
6. Re: Adjustment Layers causing clips to stutter Premiere Pro CC
AzzieScott Oct 7, 2013 9:28 PM (in response to Vinay Dwivedi)I can send you the presets and maybe you can test them yourself and see the issue im having. Can you provide an email address?
7. Re: Adjustment Layers causing clips to stutter Premiere Pro CC
shooternz Oct 7, 2013 10:00 PM (in response to AzzieScott)Make your 2.35 in Premiere Titler.
I assume its just a Mask.
8. Re: Adjustment Layers causing clips to stutter Premiere Pro CC
AzzieScott Oct 7, 2013 10:43 PM (in response to shooternz)Yes. I just did it as a title and seems to work fine.
9. Re: Adjustment Layers causing clips to stutter Premiere Pro CC
AzzieScott Oct 8, 2013 8:12 AM (in response to Vinay Dwivedi)Vinay, I found where I downloaded the presets from, it was actually from this adobe forum. here's a link to the thread and you can download them and take a look.
10. Re: Adjustment Layers causing clips to stutter Premiere Pro CC
Vinay Dwivedi Oct 8, 2013 8:15 AM (in response to AzzieScott)Hi AzzieScott,
Thanks for the link. Please mention, the types of footage you have in your project. If possible, please mention the make and model of the camera if you have captured the footage.
Vinay
11. Re: Adjustment Layers causing clips to stutter Premiere Pro CC
AzzieScott Oct 8, 2013 8:18 AM (in response to Vinay Dwivedi)The footage is from a Canon 5D III 1920x1080 transcoded to ProRes
12. Re: Adjustment Layers causing clips to stutter Premiere Pro CC
AzzieScott Oct 8, 2013 8:22 AM (in response to Vinay Dwivedi)I've did some troubleshooting and I have realized its something to do with the preset applied to the adjustment layer, because when I disable the FX of the preset in the adjustment layer the footage plays fine.
13. Re: Adjustment Layers causing clips to stutter Premiere Pro CC
JSS1138 Oct 8, 2013 8:47 AM (in response to AzzieScott)The preset is just a simple Crop effect. Sounds like you just don't have hardware acceleration turned on and the system can't handle the load.
The fact that it exports fine means this is not something you really need to worry too much about.
14. Re: Adjustment Layers causing clips to stutter Premiere Pro CC
AzzieScott Oct 8, 2013 8:51 AM (in response to JSS1138)What is hardware acceleration and how do I turn this on? My system can surly handle this I have a 8 core mac pro, SSD drives installed and 22gigs of ram. I have a ATI Radeon 5770 graphics card and I selected the mercury playback GPU option and it makes no difference weather im using the GPU or software only.
15. Re: Adjustment Layers causing clips to stutter Premiere Pro CC
AzzieScott Oct 8, 2013 8:54 AM (in response to JSS1138)yes, I understand but it is a factor because if im review the video with a client and it keeps stuttering and skipping, its not a ideal way to work. Even though it doesn't export that way I cant work efficiently if its stuttering.
16. Re: Adjustment Layers causing clips to stutter Premiere Pro CC
JSS1138 Oct 8, 2013 8:54 AM (in response to AzzieScott)I selected the mercury playback GPU option
That's hardware acceleration. Try turning that off if you have it on. There are cases where having it on causes an error with an effect.
17. Re: Adjustment Layers causing clips to stutter Premiere Pro CC
AzzieScott Oct 8, 2013 8:57 AM (in response to JSS1138)ok I figured the hardware acceleration was the GPU option, but I did that as well and it still gives me the problem for some reason.
18. Re: Adjustment Layers causing clips to stutter Premiere Pro CC
JSS1138 Oct 8, 2013 9:01 AM (in response to AzzieScott)I cant work efficiently if its stuttering.
Try this instead. It's just a graphic I made for the job.
19. Re: Adjustment Layers causing clips to stutter Premiere Pro CC
AzzieScott Oct 8, 2013 9:06 AM (in response to JSS1138)ok, thanks Jim I will try that.
20. Re: Adjustment Layers causing clips to stutter Premiere Pro CC
Vinay Dwivedi Oct 8, 2013 9:45 AM (in response to AzzieScott)Hi AzzieScott,
I tested the Clip (.mov Transcoded to prores)with the same Preset 2.35 on my windows machine and everything worked fine. Even i tried diffrent dissoves on the clip and on the adjustment layer.
21. Re: Adjustment Layers causing clips to stutter Premiere Pro CC
AzzieScott Oct 8, 2013 10:27 AM (in response to Vinay Dwivedi)The issue happens intermittently and also note I have a 4min timeline of clips. Can you create a 3 to 4min timeline of different clips, add a mixture of transitions, then apply an adjustment layer above the clips on another video track above the clips and extend it across the whole timeline, apply the preset to the adjustment layer and play your time line from beginning to end.
