cfhttp problem reading file
Mar 26, 2007 Mar 26, 2007
Hi there,
The code below works fine on my local host computer and databse setup.
cfhttp will read my file fine and output the number of rows.
When i attempt to run this code on my web host's CF and MS II's server i get
a - HTTP 500 - Internal server error in Internet Explorer and a blank page
in firefox.
Does anybody know why this would be happenning. I've heard cfhttp has some
bugs but i couldnt find a solution after looking at various blogs on the
matter. Not sure if its timing out or what?
<cfsetting requesttimeout="900">
<cfhttp method="get" textqualifier=" " firstrowasheaders="no" delimiter="|"
name="test" columns="OrderNo, Line, seq, AccountNo, Shipment, Invoice,
PurchaseOrder, Completed, OrderDate, ShipmentDate, Backorder, Product,
QtyOrdered, QtyShipped, QtyInvoiced, Price, Carrier, Connote, Delivery1,
Delivery2, Delivery3, Delivery4, Delivery5, Delivery6, Delivery7, expected"
url=" http://xxxxxx.com/xxx/zzzzz.txt">
Read in <cfoutput>#test.RecordCount#</cfoutput> records
Advanced techniques
518
Guest
Mar 27, 2007 Mar 27, 2007
You need </CFHTTP> after your <CFHTTP>.
Heres my complete code what im trying to achieve. In IE i get a http 500
internal error and in firefox i get a blank page. im strating to think it
may be a database permission problem although i have made sure my user has
full permissions on the order_history table.
any ideas whta im doing wrong?
<cfquery name="delete" datasource="#client.dsn#"
username="#client.username#" passWord="#client.password#">
delete from order_history
</cfquery>
<cfhttp timeout="900" method="get" textqualifier=" " firstrowasheaders="no"
columns="OrderNo,Line,seq,AccountNo,Shipment,Invoice,PurchaseOrder,Completed,OrderDate,ShipmentDate,Backorder,Product,QtyOrdered,QtyShipped,QtyInvoiced,Price,Carrier,Connote,Delivery1,Delivery2,Delivery3,Delivery4,Delivery5,Delivery6,Delivery7,expected"
delimiter="|" name="test" url=" http://xxxxxxxx.com/prms/ordhist1.txt">
</cfhttp>
<cfloop query="test">
<cfquery name="insert" datasource="#client.dsn#"
INSERT INTO order_history
(OrderNo, Line, seq, AccountNo, Shipment, Invoice, PurchaseOrder, Completed,
OrderDate, ShipmentDate, Backorder, Product, QtyOrdered, QtyShipped,
QtyInvoiced, Price, Carrier, Connote, Delivery1, Delivery2, Delivery3,
Delivery4, Delivery5, Delivery6, Delivery7, expected)
VALUES (
<cfqueryparam value='#test.OrderNo#' cfsqltype="cf_sql_integer">,
<cfqueryparam value='#test.Line#' cfsqltype="cf_sql_integer">,
<cfqueryparam value='#test.seq#' cfsqltype="cf_sql_integer">,
<cfqueryparam value='#test.AccountNo#' cfsqltype="cf_sql_integer">,
<cfqueryparam value='#test.shipment#' cfsqltype="cf_sql_integer">,
<cfqueryparam value='#test.invoice#' cfsqltype="cf_sql_integer">,
<cfqueryparam value='#test.purchaseorder#' cfsqltype="cf_sql_varchar"
maxlength="20">,
<cfqueryparam value='#test.completed#' cfsqltype="cf_sql_varchar"
maxlength="12">,
<cfqueryparam value='#test.orderdate#' cfsqltype="cf_sql_varchar"
maxlength="12">,
<cfqueryparam value='#test.shipmentdate#' cfsqltype="cf_sql_varchar"
maxlength="12">,
<cfqueryparam value='#test.backorder#' cfsqltype="cf_sql_varchar"
maxlength="10">,
<cfqueryparam value='#test.product#' cfsqltype="cf_sql_varchar"
maxlength="20">,
<cfqueryparam value='#test.qtyordered#' cfsqltype="cf_sql_integer">,
<cfqueryparam value='#test.qtyshipped#' cfsqltype="cf_sql_integer">,
<cfqueryparam value='#test.qtyinvoiced#' cfsqltype="cf_sql_integer">,
<cfqueryparam value='#test.price#' cfsqltype="cf_sql_varchar"
maxlength="15">,
<cfqueryparam value='#test.carrier#' cfsqltype="cf_sql_varchar"
maxlength="20">,
<cfqueryparam value='#test.connote#' cfsqltype="cf_sql_varchar"
maxlength="20">,
<cfqueryparam value='#test.delivery1#' cfsqltype="cf_sql_varchar"
maxlength="150">,
<cfqueryparam value='#test.delivery2#' cfsqltype="cf_sql_varchar"
maxlength="100">,
<cfqueryparam value='#test.delivery3#' cfsqltype="cf_sql_varchar"
maxlength="100">,
<cfqueryparam value='#test.delivery4#' cfsqltype="cf_sql_varchar"
maxlength="100">,
<cfqueryparam value='#test.delivery5#' cfsqltype="cf_sql_varchar"
maxlength="100">,
<cfqueryparam value='#test.delivery6#' cfsqltype="cf_sql_varchar"
maxlength="100">,
<cfqueryparam value='#test.delivery7#' cfsqltype="cf_sql_varchar"
maxlength="100">,
<cfqueryparam value='#test.expected#' cfsqltype="cf_sql_varchar"
maxlength="12">)
</cfquery>
</cfloop>
FINISHED!!
"jdeline" <jdeline@deline.com> wrote in message
news:eub244$lc$1@forums.macromedia.com...
Guest
Mar 28, 2007 Mar 28, 2007
I presume you have double-checked the data types of all columns and that the CFSQLTYPEs are correct. I seem to remember that there was a problem with CFSQLTYPE in an earlier version of ColdFusion. What version and platform are you using?
i'll check it out using MX7 on a II's server
news:eudm61$e7m$1@forums.macromedia.com...
>the
> are
> you using?
Advocate ,
Mar 29, 2007 Mar 29, 2007
What result are you getting if you perform a <cfump> of your CFHTTP variables?
Thanks for help guys it seems to be a file size problem.
the text file I was reading was 25mb and cfhttp seems to die, as it loads it
into a query set.
Under 20mb and my code seems to work ok.
"insuractive" <webforumsuser@macromedia.com> wrote in message
news:euh4ml$1mq$1@forums.macromedia.com...
> variables?
Guest
Mar 30, 2007 Mar 30, 2007
Check out the DFxChange at http://www.cfxchange.com/?content=tagdetails&area=gallery&subarea=details&tag=200&querystring=. I've used this custom tag before and it seems to handle large files quite nicely.
Documentation
