5 Replies Latest reply: Oct 11, 2013 1:45 PM by Ned Murphy RSS
    .autoSize
    Ron Colmen Community Member
      This is my code. I need to add couple of extra spacees at the end of message.text  How?
      h = _root.createEmptyMovieClip("h", 5);
      h.attachMovie("tray_mc", "tray_mc", 10);
      h.tray_mc.message.autoSize=true;
      h.tray_mc.message.text = "test";
        • 1. Re: .autoSize
          Ned Murphy CommunityMVP
          If you need extra spaces then add them when you assign the text...
          h.tray_mc.message.text = "test  ";
          or
          h.tray_mc.message.text = "test" + "  ";;
          • 2. Re: .autoSize
            That doesn't not work. It ignores the spaces at the end
            shows clearly whe I add a border to the tf.
            h.tray_mc.message.border=true;
            • 3. Re: .autoSize
              It does work.  You asked how to add spaces to the end of ther text and that is adding spaces to the end of the text.
              If you want to add extra empty textfield space after the text the same holds true.  If it is not working for you I can't explain why but it works for me.
              • 4. Re: .autoSize
                You're correct.
                Instead of using the textfield form the library (attachMovie), I used .createTextField to create 'message' and it worked. I don't know why the textfield in attachMovie() did not show spaces, but I've got my answer.
                Thanks ned!
                • 5. Re: .autoSize
                  You're welcome Ron.  I recreated what I could make of your first posting and that worked for me, using the attachMovie approach... so something is amiss... but if you have a working solution that's all you really need.
