Show 1 reply
1. Re: Flex 4.0 HMAC.hash binary data
Yuriy Belenko Oct 13, 2013 8:30 AM (in response to richardchristie)I've solved this problem by adding self-made function in HMAC Class:
/** * Performs the HMAC hash algorithm using string. * This function equals php "hash_hmac" function when "raw_output" parameter is set to true. * @param secret The secret key * @param message The message to hash * @param algorithm Hash object to use * @return raw binary data as ByteArray */ public static function getRawHash(secret:String, message:String, algorithm:Object = null):ByteArray { var hexHash:String = hash(secret, message, algorithm); var hashBinary:ByteArray = new ByteArray(); for (var i:uint = 0; i < hexHash.length; i += 2) { var c:String = hexHash.charAt(i) + hexHash.charAt(i + 1); hashBinary.writeByte(parseInt(c, 16)); } return hashBinary; }After, if you neen "base64" string you can do something like that:
private function createHashForSign(secretKey:String, message:String):String { var hash:ByteArray = HMAC.getRawHash(secretKey, message, SHA1); var baseEncoder:Base64Encoder = new Base64Encoder(); baseEncoder.encodeBytes(hash, 0, hash.length); return baseEncoder.toString(); }
