I have Photo Shop Elements 2 paid for by buying camera. but Windows 7 does not seem to accept it.
I tried to download a free one but even this will not download. Please help.
from bagtay
Hi bagtay,
You can try this :
If you want to install CS2 it should be in a 32-bit OS environment like Windows XP. But Windows 7 has a solution for this.
1. Right-click on the installer file (.exe file)
2. Select Properties then go to the Compatibility tab.
3. Put a check on the “Run this program in compatibility mode for” then select the previous OS which do you think it worked. For your case select Windows XP with any Service Pack.
4. Then under Privilege Level, place a check on “Run this program
...Copy link to clipboard
Hi bagtay,
You can try this :
4. Then under Privilege Level, place a check on “Run this program as administrator”
5. Click Apply then OK.
Note: Effective December 13, Adobe disabled the activation server for CS2 products and Acrobat 7 because of a technical glitch.If the software title you have purchased is affected by the activation server being shut down, but is not available for download in the previously referenced pages, then please contact our support team at http://www.adobe.com/support/chat/ivrchat.html. Please be aware our support team will not be able to provide assistance for downloading or installing the Creative Suite 2 software.
Please go through this :
http://forums.adobe.com/thread/1195856
http://forums.adobe.com/thread/1114930
Rajshree
goedenavond heb je ook een download link voor de elemwnt 2 mijn cd is stuk en ik wil hem op mijn nwe pc hebben
had hem op usb stick gezet maar vw de krassen er op heeft die niet gepakt
bij voorbaat dank
The CS2-CS3-CS4 activation servers have been removed from service
-https://helpx.adobe.com/creative-suite.html?promoid=19SCDRQK
-So even if you have a disc or saved download, CS2-CS3-CS4 are completely dead
