The material sent by C F McBlob was kindly sent but does not work. I downloaded the correct zip file, installed Flash player on this machine, and still get messages from web sites that Flash Player is needed. This computer has win 7 32 bit Enterprise edition; the computer I have that works with flash player is WIn7 32 bit professional edition. Is there a difference? The control panel information is that the plugin is not installed. Do I need to turn off the McAfee firewall in order to install this?
Can you post the contents of the FlashInstall.log file in C:\Windows\system32\Macromed\Flash ?
How to copy the file and paste it in to this forum? Copy - paste does not work, as the paste command does not appear in this box when I right-click on it (paste is grayed out)
Sorry it took so long. Busy weekend. Control-V works even though the "Paste" option on the menu is grayed out.
Call: 397
Safety Check
Call: 79
Call: 886
File: overwriteflag=1, allowskipfilesflag=2, name="C:\Users\nellem\AppData\Local\Temp\nskA9E7.tmp\UserInfo.dll"
File: wrote 4096 to "C:\Users\nellem\AppData\Local\Temp\nskA9E7.tmp\UserInfo.dll"
CheckAdminPermissions Name = SYSTEM
Call: 886
File: skipped: "C:\Users\nellem\AppData\Local\Temp\nskA9E7.tmp\UserInfo.dll" (overwriteflag=1)
CheckAdminPermissions Account Type = Admin
Jump: 111
Call: 111
Call: 37
GetWindowsVersion -
CheckSupportedPlatform - OS=
Call: 403
CheckFPPermissions
Call: 37
GetWindowsVersion -
Call: 886
File: overwriteflag=1, allowskipfilesflag=2, name="C:\Users\nellem\AppData\Local\Temp\nskA9E7.tmp\fpinstall.dll"
File: wrote 8704 to "C:\Users\nellem\AppData\Local\Temp\nskA9E7.tmp\fpinstall.dll"
ObjectExistsAndIsOwnedBySomeoneElse = 0
Jump: 431
End Safety Check
File: overwriteflag=4, allowskipfilesflag=2, name="Flash9f.ocx"
File: wrote 2991488 to "C:\Windows\system32\Macromed\Flash\Flash9f.ocx"
File: overwriteflag=4, allowskipfilesflag=2, name="FlashUtil9f.exe"
File: wrote 218496 to "C:\Windows\system32\Macromed\Flash\FlashUtil9f.exe"
End Main Section
Section: ""
Start Post Section
Call: 448
CallUninstallers
Call: 886
File: overwriteflag=1, allowskipfilesflag=2, name="C:\Users\nellem\AppData\Local\Temp\nskA9E7.tmp\NSISArray.dll"
File: wrote 17920 to "C:\Users\nellem\AppData\Local\Temp\nskA9E7.tmp\NSISArray.dll"
Call: 886
File: overwriteflag=1, allowskipfilesflag=0, name="C:\Users\nellem\AppData\Local\Temp\nskA9E7.tmp\NSISArray.dll"
File: skipped: "C:\Users\nellem\AppData\Local\Temp\nskA9E7.tmp\NSISArray.dll" (overwriteflag=1)
Call: 886
Call: 886
Call: 886
Call: 886
Call: 886
Call: 886
Call: 886
Call: 886
Call: 886
Call: 886
Call: 886
Call: 886
Call: 886
Call: 886
Call: 886
Call: 886
Call: 886
Call: 886
Call: 886
Call: 886
Call: 886
Call: 886
Call: 886
Call: 886
Call: 886
Call: 886
Call: 886
Call: 886
Call: 886
Call: 886
Call: 886
Call: 886
Call: 886
Call: 886
Call: 886
Call: 886
Call: 886
Call: 886
Call: 886
Call: 886
Call: 886
Jump: 759
Call: 886
Jump: 758
Call: 886
Jump: 758
Call: 886
Jump: 758
Call: 886
Jump: 758
Call: 886
Jump: 758
Call: 886
Jump: 758
Call: 886
Jump: 758
Call: 886
Jump: 758
Call: 886
Jump: 758
Call: 886
Jump: 758
Call: 886
Jump: 758
Call: 886
Jump: 758
Call: 886
Jump: 758
Call: 886
Jump: 758
Call: 886
Jump: 758
Call: 886
Jump: 758
Call: 886
Jump: 758
Call: 886
Jump: 758
Call: 886
Jump: 758
Call: 886
Jump: 758
Call: 886
Jump: 758
Call: 886
Jump: 758
Call: 886
Jump: 758
Call: 886
Jump: 758
Call: 886
Jump: 758
Call: 886
Jump: 758
Call: 886
Jump: 758
Call: 886
Jump: 758
Call: 886
Jump: 758
Call: 886
Jump: 758
Call: 886
Jump: 758
Call: 886
Jump: 758
Call: 886
Jump: 758
Call: 886
Jump: 758
Call: 886
Jump: 758
Call: 886
Jump: 758
Call: 886
Jump: 758
Call: 886
Jump: 758
Call: 886
Jump: 758
Delete: "C:\Windows\system32\Macromed\Flash\Flash.ocx"
Delete: "C:\Windows\system32\Macromed\Flash\Flash6.ocx"
Delete: "C:\Windows\system32\Macromed\Flash\Flash6a.ocx"
Delete: "C:\Windows\system32\Macromed\Flash\Flash7.ocx"
Delete: "C:\Windows\system32\Macromed\Flash\Flash7a.ocx"
Delete: "C:\Windows\system32\Macromed\Flash\Flash7b.ocx"
Delete: "C:\Windows\system32\Macromed\Flash\Flash7c.ocx"
Delete: "C:\Windows\system32\Macromed\Flash\Flash8.ocx"
Delete: "C:\Windows\system32\Macromed\Flash\Flash8a.ocx"
Delete: "C:\Windows\system32\Macromed\Flash\Flash8b.ocx"
Delete: "C:\Windows\system32\Macromed\Flash\Flash8c.ocx"
Delete: "C:\Windows\system32\Macromed\Flash\Flash8d.ocx"
Delete: "C:\Windows\system32\Macromed\Flash\Flash8e.ocx"
Delete: "C:\Windows\system32\Macromed\Flash\Flash9.ocx"
Delete: "C:\Windows\system32\Macromed\Flash\Flash9a.ocx"
Delete: "C:\Windows\system32\Macromed\Flash\Flash9b.ocx"
Delete: "C:\Windows\system32\Macromed\Flash\Flash9c.ocx"
Delete: "C:\Windows\system32\Macromed\Flash\Flash9d.ocx"
Delete: "C:\Windows\system32\Macromed\Flash\Flash9e.ocx"
Delete: "C:\Windows\system32\Macromed\Flash\GetFlash.exe"
Delete: "C:\Windows\system32\Macromed\Flash\GetFlash.exe.manifest"
Delete: "C:\Windows\system32\Macromed\Flash\UninstFl.exe"
Delete: "C:\Windows\system32\Macromed\Flash\FlashUtil9a.exe"
Delete: "C:\Windows\system32\Macromed\Flash\FlashUtil9b.exe"
Delete: "C:\Windows\system32\Macromed\Flash\FlashUtil9c.exe"
Delete: "C:\Windows\system32\Macromed\Flash\FlashUtil9d.exe"
Delete: "C:\Windows\system32\Macromed\Flash\FlashUtil9e.exe"
End Call Uninstallers
Register Player
Registration Successful
WriteRegStr: "HKEY_LOCAL_MACHINE\SOFTWARE\Macromedia\FlashPlayerActiveX\Components" "Main"="1"
WriteRegStr: "HKEY_LOCAL_MACHINE\SOFTWARE\Macromedia\FlashPlayerActiveX" "Path"="C:\Windows\system32\Macromed\Flash"
created uninstaller: 9625, "C:\Windows\system32\Macromed\Flash\uninstall_activeX.exe"
WriteRegStr: "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\ShockwaveFlash" "DisplayVersion"="9.0.124.0"
WriteRegStr: "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX" "DisplayName"="Adobe Flash Player ActiveX"
WriteRegStr: "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX" "DisplayVersion"="9.0.124.0"
WriteRegStr: "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX" "Publisher"="Adobe Systems Incorporated"
WriteRegStr: "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX" "URLInfoAbout"="http://www.adobe.com/go/getflashplayer"
WriteRegStr: "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX" "VersionMajor"="9"
WriteRegStr: "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX" "VersionMinor"="0"
WriteRegStr: "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX" "HelpLink"="http://www.adobe.com/go/flashplayer_support/"
WriteRegStr: "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX" "URLUpdateInfo"="http://www.adobe.com/go/flashplayer/"
Call: 886
File: overwriteflag=1, allowskipfilesflag=0, name="C:\Users\nellem\AppData\Local\Temp\nskA9E7.tmp\System.dll"
File: skipped: "C:\Users\nellem\AppData\Local\Temp\nskA9E7.tmp\System.dll" (overwriteflag=1)
Call: 886
WriteRegStr: "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX" "DisplayIcon"="C:\Windows\system32\Macromed\Flash\uninstall_activeX.exe"
WriteRegStr: "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX" "UninstallString"="C:\Windows\system32\Macromed\Flash\uninstall_activeX.exe"
WriteRegStr: "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX" "RequiresIESysFile"="4.70.0.1155"
WriteRegDWORD: "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX" "NoModify"="0x00000001"
WriteRegDWORD: "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX" "NoRepair"="0x00000001"
WriteRegDWORD: "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\ActiveX Compatibility\{D27CDB6E-AE6D-11CF-96B8-444553540000}" "Compatibility Flags"="0x00000000"
WriteRegStr: "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings\Accepted Documents" "Flash"="application/x-shockwave-flash"
WriteRegStr: "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Active Setup\Installed Components\{D27CDB6E-AE6D-11CF-96B8-444553540000}" ""="Adobe Flash Player"
WriteRegStr: "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Active Setup\Installed Components\{D27CDB6E-AE6D-11CF-96B8-444553540000}" "ComponentID"="Flash"
WriteRegBin: "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Active Setup\Installed Components\{D27CDB6E-AE6D-11CF-96B8-444553540000}" "IsInstalled"="01 00 00 00"
WriteRegStr: "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Active Setup\Installed Components\{D27CDB6E-AE6D-11CF-96B8-444553540000}" "Version"="9.0.124.0"
WriteRegStr: "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Active Setup\Installed Components\{D27CDB6E-AE6D-11CF-96B8-444553540000}" "Locale"="EN"
WriteRegStr: "HKEY_CURRENT_USER\SOFTWARE\Macromedia\FlashPlayer" "FlashPlayerVersion"="9.0.124.0"
End Post Section
Delete: DeleteFile("C:\Users\nellem\AppData\Local\Temp\nskA9E7.tmp\fpinstall.dll")
Delete: DeleteFile("C:\Users\nellem\AppData\Local\Temp\nskA9E7.tmp\NSISArray.dll")
Delete: DeleteFile on Reboot("C:\Users\nellem\AppData\Local\Temp\nskA9E7.tmp\NSISArray.dll")
Delete: DeleteFile("C:\Users\nellem\AppData\Local\Temp\nskA9E7.tmp\System.dll")
Delete: DeleteFile("C:\Users\nellem\AppData\Local\Temp\nskA9E7.tmp\UserInfo.dll")
RMDir: RemoveDirectory("C:\Users\nellem\AppData\Local\Temp\nskA9E7.tmp\")
I think I posted the wrong file. The one I just found - which I believe you asked for - is full of the same error message in hundreds of lines, to wit: (The bottom of the file contains a different error code in about a dozen lines). I am sorry - a novice error.
=O====== M/11.6.602.180 2013-03-28+03-12-16.740 ========
0000 00000010 "C:\ProgramData\Adobe\AIH.6b01902f938b298960e5a599fe4acdfbec0178d3\install_flash_player_ax.exe" -install -iv 8 -au 1
0001
0002
0003
0004 00000020 C:\Windows\system32\FlashPlayerCPLApp.cpl
0005
0006 00000018
0007
0008 00000013 C:\Windows\system32\Macromed\Flash\Flash32_11_6_602_180.ocx
0009 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_6_602_180_ActiveX.exe
0010 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_6_602_180_ActiveX.dll
0011 00000023 C:\Windows\system32\Macromed\Flash\activex.vch
0012 00000019 C:\Windows\system32\FlashPlayerCPLApp.cpl
0013 00000021 C:\Windows\system32\Macromed\Flash\FlashPlayerUpdateService.exe
0014 00000012
=X====== M/11.6.602.180 2013-03-28+03-12-18.725 ========
=O====== M/11.6.602.180 2013-04-02+23-05-22.888 ========
0000 00000010 "C:\ProgramData\Adobe\AIH.1a2459d74f054078fbdaa435cdf3c62bcddab460\install_flash_player_ax.exe" -install -iv 8 -au 0
0001
=X====== M/11.6.602.180 2013-04-02+23-05-23.037 ========
=O====== M/11.6.602.180 2013-04-02+23-13-05.441 ========
0001 00000020 C:\Windows\system32\FlashPlayerCPLApp.cpl
0002 00000013 C:\Windows\system32\Macromed\Flash\Flash32_11_6_602_180.ocx
0003 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_6_602_180_ActiveX.exe
0004 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_6_602_180_ActiveX.dll
0005 00000023 C:\Windows\system32\Macromed\Flash\activex.vch
0006 00000019 C:\Windows\system32\FlashPlayerCPLApp.cpl
0007
0008
0009 00000021 C:\Windows\system32\Macromed\Flash\FlashPlayerUpdateService.exe
0010
0011 00000012
=X====== M/11.6.602.180 2013-04-02+23-13-08.939 ========
=O====== M/11.6.602.180 2013-04-25+16-38-35.790 ========
0000 00000010 "C:\Windows\System32\Macromed\Flash\FlashUtil32_11_6_602_180_ActiveX.exe" -update activex
0001
=X====== M/11.6.602.180 2013-04-25+16-38-45.092 ========
2013-4-28+0-14-0.714 [error] 1223 1058
2013-4-28+1-14-0.457 [error] 1223 1058
2013-4-28+8-4-54.170 [error] 1223 1058
2013-4-28+17-44-50.640 [error] 1223 1058
2013-4-28+18-14-0.173 [error] 1223 1058
2013-4-28+19-14-0.349 [error] 1223 1058
2013-4-28+20-14-0.287 [error] 1223 1058
2013-4-28+21-14-0.209 [error] 1223 1058
2013-4-29+1-3-57.203 [error] 1223 1058
2013-4-29+1-3-57.328 [error] 1223 1058
2013-4-29+1-14-0.245 [error] 1223 1058
2013-4-29+8-2-34.779 [error] 1223 1058
2013-4-29+8-14-0.151 [error] 1223 1058
2013-4-29+9-14-0.138 [error] 1223 1058
2013-4-29+17-48-7.686 [error] 1223 1058
2013-4-29+18-14-0.198 [error] 1223 1058
2013-4-29+20-20-31.326 [error] 1223 1058
2013-4-29+21-22-1.970 [error] 1223 1058
2013-4-29+22-14-0.196 [error] 1223 1058
2013-4-30+8-18-18.967 [error] 1223 1058
2013-4-30+16-42-7.437 [error] 1223 1058
2013-4-30+17-14-0.15 [error] 1223 1058
2013-4-30+18-14-0.194 [error] 1223 1058
2013-4-30+19-14-0.347 [error] 1223 1058
2013-4-30+20-14-0.219 [error] 1223 1058
2013-4-30+21-14-0.213 [error] 1223 1058
2013-4-30+22-14-0.36 [error] 1223 1058
2013-4-30+23-14-0.198 [error] 1223 1058
2013-5-1+0-14-0.201 [error] 1223 1058
2013-5-1+1-14-0.309 [error] 1223 1058
2013-5-1+8-24-55.390 [error] 1223 1058
2013-5-1+9-14-0.267 [error] 1223 1058
2013-5-1+10-14-0.972 [error] 1223 1058
2013-5-1+11-14-0.166 [error] 1223 1058
2013-5-1+12-19-3.939 [error] 1223 1058
2013-5-1+18-21-58.30 [error] 1223 1058
2013-5-1+19-14-0.200 [error] 1223 1058
2013-5-1+20-14-0.249 [error] 1223 1058
2013-5-2+8-48-56.281 [error] 1223 1058
2013-5-2+16-0-9.125 [error] 1223 1058
2013-5-2+16-14-0.38 [error] 1223 1058
2013-5-2+17-14-0.199 [error] 1223 1058
2013-5-2+18-14-0.293 [error] 1223 1058
2013-5-2+20-35-19.578 [error] 1223 1058
2013-5-2+22-30-30.797 [error] 1223 1058
2013-5-2+23-14-0.155 [error] 1223 1058
2013-5-3+0-14-0.191 [error] 1223 1058
2013-5-3+0-14-0.224 [error] 1223 1058
2013-5-3+1-14-0.294 [error] 1223 1058
2013-5-3+8-44-3.403 [error] 1223 1058
2013-5-3+15-15-39.628 [error] 1223 1058
2013-5-3+16-14-0.192 [error] 1223 1058
2013-5-3+17-14-0.193 [error] 1223 1058
2013-5-3+20-3-54.107 [error] 1223 1058
2013-5-3+20-14-0.234 [error] 1223 1058
2013-5-3+21-14-0.195 [error] 1223 1058
2013-5-4+0-52-54.617 [error] 1223 1058
2013-5-4+1-14-0.189 [error] 1223 1058
2013-5-4+8-27-26.527 [error] 1223 1058
2013-5-5+14-43-56.232 [error] 1223 1058
2013-5-5+15-14-0.462 [error] 1223 1058
2013-5-5+17-53-0.404 [error] 1223 1058
2013-5-5+18-14-0.194 [error] 1223 1058
2013-5-5+20-43-20.734 [error] 1223 1058
2013-5-6+2-10-3.984 [error] 1223 1058
2013-5-6+2-14-1.919 [error] 1223 1058
2013-5-6+3-15-41.706 [error] 1223 1058
2013-5-6+4-14-1.325 [error] 1223 1058
2013-5-6+5-14-0.334 [error] 1223 1058
2013-5-6+6-14-0.337 [error] 1223 1058
2013-5-6+8-21-47.160 [error] 1223 1058
2013-5-6+16-18-0.775 [error] 1223 1058
2013-5-6+17-14-0.360 [error] 1223 1058
2013-5-6+20-23-0.811 [error] 1223 1058
2013-5-6+21-50-21.827 [error] 1223 1058
2013-5-6+22-14-0.143 [error] 1223 1058
2013-5-6+23-14-0.155 [error] 1223 1058
2013-5-7+0-14-0.150 [error] 1223 1058
2013-5-7+8-51-47.826 [error] 1223 1058
2013-5-7+18-14-0.188 [error] 1223 1058
2013-5-7+19-36-3.796 [error] 1223 1058
2013-5-7+20-14-0.223 [error] 1223 1058
2013-5-7+21-14-0.155 [error] 1223 1058
2013-5-7+22-33-44.687 [error] 1223 1058
2013-5-7+23-14-0.151 [error] 1223 1058
2013-5-8+0-14-0.147 [error] 1223 1058
2013-5-8+1-14-0.144 [error] 1223 1058
2013-5-8+3-42-25.748 [error] 1223 1058
=O====== M/11.6.602.180 2013-05-08+03-42-42.639 ========
0001
=X====== M/11.6.602.180 2013-05-08+03-42-46.376 ========
2013-5-8+4-14-0.146 [error] 1223 1058
2013-5-8+17-14-0.248 [error] 1223 1058
2013-5-8+18-14-0.189 [error] 1223 1058
2013-5-8+19-14-0.288 [error] 1223 1058
2013-5-8+20-14-0.151 [error] 1223 1058
2013-5-8+21-14-38.764 [error] 1223 1058
2013-5-8+22-18-5.519 [error] 1223 1058
2013-5-8+23-14-0.392 [error] 1223 1058
2013-5-9+1-19-34.873 [error] 1223 1058
2013-5-9+4-38-27.117 [error] 1223 1058
2013-5-9+5-14-0.188 [error] 1223 1058
2013-5-9+8-58-39.530 [error] 1223 1058
2013-5-9+9-34-0.531 [error] 1223 1058
2013-5-9+15-44-7.983 [error] 1223 1058
2013-5-9+16-14-0.264 [error] 1223 1058
2013-5-9+17-14-0.198 [error] 1223 1058
=O====== M/11.6.602.180 2013-05-24+17-48-22.788 ========
=X====== M/11.6.602.180 2013-05-24+17-52-15.368 ========
=O====== M/11.7.700.202 2013-05-24+17-55-16.653 ========
0000 00000010 "C:\Windows\system32\Macromed\Flash\FlashUtil32_11_7_700_202_ActiveX.exe" -refreshIEElevationPolicies
=X====== M/11.7.700.202 2013-05-24+17-55-16.703 ========
=X====== M/11.7.700.202 2013-05-24+17-55-16.704 ========
=O====== M/11.7.700.202 2013-05-24+17-55-15.624 ========
0000 00000010 "C:\ProgramData\Adobe\AIH.6810efccffb736f7296828e7ec7199847d106aa9\install_flash_player_ax.exe" -install -iv 10
0002
0003 00000018
0004
0005 00000013 C:\Windows\system32\Macromed\Flash\Flash32_11_7_700_202.ocx
0006 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_7_700_202_ActiveX.exe
0007 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_7_700_202_ActiveX.dll
0008 00000023 C:\Windows\system32\Macromed\Flash\activex.vch
0009 00000019 C:\Windows\system32\FlashPlayerCPLApp.cpl
0010
0011
0012 00000021 C:\Windows\system32\Macromed\Flash\FlashPlayerUpdateService.exe
0013
0014
0015
0016 00000012
=X====== M/11.7.700.202 2013-05-24+17-55-19.860 ========
2013-5-24+18-14-59.490 [error] 1223 1058
2013-5-24+19-14-0.247 [error] 1223 1058
2013-5-24+20-16-19.47 [error] 1223 1058
2013-5-25+0-48-18.69 [error] 1223 1058
2013-5-25+1-14-0.809 [error] 1223 1058
2013-5-25+2-14-11.457 [error] 1223 1058
2013-5-25+5-35-2.525 [error] 1223 1058
2013-5-25+6-18-4.876 [error] 1223 1058
2013-5-25+8-54-23.991 [error] 1223 1058
2013-5-25+9-22-23.870 [error] 1223 1058
2013-5-25+10-14-5.253 [error] 1223 1058
2013-5-25+11-14-0.535 [error] 1223 1058
2013-5-25+12-14-0.194 [error] 1223 1058
2013-5-25+13-19-44.468 [error] 1223 1058
2013-5-25+14-14-0.162 [error] 1223 1058
2013-5-25+15-20-17.145 [error] 1223 1058
2013-5-25+16-40-41.953 [error] 1223 1058
2013-5-25+17-14-0.43 [error] 1223 1058
2013-5-25+18-14-0.179 [error] 1223 1058
2013-5-25+19-14-0.257 [error] 1223 1058
2013-5-25+20-14-0.174 [error] 1223 1058
2013-5-25+21-14-0.200 [error] 1223 1058
2013-5-25+22-14-0.205 [error] 1223 1058
2013-5-25+23-14-0.200 [error] 1223 1058
2013-5-26+0-14-0.232 [error] 1223 1058
2013-5-26+1-14-0.187 [error] 1223 1058
2013-5-26+8-26-43.296 [error] 1223 1058
2013-5-26+16-57-20.716 [error] 1223 1058
2013-5-26+17-14-0.178 [error] 1223 1058
2013-5-26+18-14-0.201 [error] 1223 1058
2013-5-26+19-14-0.296 [error] 1223 1058
2013-5-26+20-27-15.437 [error] 1223 1058
2013-5-27+8-32-6.404 [error] 1223 1058
2013-5-27+9-14-0.443 [error] 1223 1058
2013-5-27+10-14-0.149 [error] 1223 1058
2013-5-27+11-14-0.43 [error] 1223 1058
2013-5-27+17-6-38.247 [error] 1223 1058
2013-5-27+17-14-0.189 [error] 1223 1058
2013-5-27+18-14-0.272 [error] 1223 1058
2013-5-27+19-14-0.202 [error] 1223 1058
2013-5-27+20-14-0.149 [error] 1223 1058
2013-5-27+21-14-0.271 [error] 1223 1058
2013-5-27+22-14-0.197 [error] 1223 1058
2013-5-27+23-14-0.196 [error] 1223 1058
2013-5-28+0-14-0.193 [error] 1223 1058
2013-5-28+1-14-0.687 [error] 1223 1058
2013-5-28+2-14-0.191 [error] 1223 1058
2013-5-28+3-14-0.193 [error] 1223 1058
2013-5-28+8-33-31.826 [error] 1223 1058
2013-5-28+17-38-22.842 [error] 1223 1058
2013-5-28+18-14-0.205 [error] 1223 1058
2013-5-28+19-14-0.177 [error] 1223 1058
2013-5-28+20-14-0.198 [error] 1223 1058
2013-5-28+21-14-0.175 [error] 1223 1058
2013-5-28+21-14-0.222 [error] 1223 1058
2013-5-28+22-14-0.299 [error] 1223 1058
2013-5-28+23-14-0.193 [error] 1223 1058
2013-5-29+0-14-0.632 [error] 1223 1058
2013-5-29+1-14-0.196 [error] 1223 1058
2013-5-29+2-14-0.183 [error] 1223 1058
2013-5-29+3-14-0.201 [error] 1223 1058
2013-5-29+8-17-52.780 [error] 1223 1058
2013-5-29+8-17-52.905 [error] 1223 1058
2013-5-29+18-10-58.328 [error] 1223 1058
2013-5-29+18-14-0.42 [error] 1223 1058
2013-5-29+19-14-0.225 [error] 1223 1058
2013-5-29+20-14-0.187 [error] 1223 1058
2013-5-29+21-14-0.229 [error] 1223 1058
2013-5-29+22-14-0.201 [error] 1223 1058
2013-5-29+23-14-0.188 [error] 1223 1058
2013-5-30+0-14-0.265 [error] 1223 1058
2013-5-30+1-14-0.199 [error] 1223 1058
2013-5-30+2-14-0.717 [error] 1223 1058
2013-5-30+3-14-0.220 [error] 1223 1058
2013-5-30+4-40-56.842 [error] 1223 1058
2013-5-30+5-32-22.562 [error] 1223 1058
2013-5-30+6-14-0.169 [error] 1223 1058
2013-5-30+8-10-27.688 [error] 1223 1058
2013-5-30+8-58-23.499 [error] 1223 1058
2013-5-30+9-36-2.749 [error] 1223 1058
2013-5-30+15-13-50.655 [error] 1223 1058
2013-5-30+15-14-0.15 [error] 1223 1058
2013-5-30+16-14-0.225 [error] 1223 1058
2013-5-30+17-14-0.188 [error] 1223 1058
2013-5-30+18-14-0.191 [error] 1223 1058
2013-5-30+19-14-0.194 [error] 1223 1058
2013-5-30+20-42-42.251 [error] 1223 1058
2013-5-30+22-41-53.92 [error] 1223 1058
2013-5-30+23-14-0.200 [error] 1223 1058
2013-5-31+0-14-0.433 [error] 1223 1058
2013-5-31+1-14-0.186 [error] 1223 1058
2013-5-31+2-14-0.189 [error] 1223 1058
2013-5-31+3-14-0.192 [error] 1223 1058
2013-5-31+8-54-4.857 [error] 1223 1058
2013-5-31+17-21-45.124 [error] 1223 1058
2013-5-31+18-14-0.189 [error] 1223 1058
2013-5-31+19-14-0.190 [error] 1223 1058
2013-5-31+20-14-0.240 [error] 1223 1058
2013-5-31+21-14-0.190 [error] 1223 1058
2013-5-31+22-14-0.192 [error] 1223 1058
2013-6-1+0-33-24.154 [error] 1223 1058
2013-6-1+1-14-0.358 [error] 1223 1058
2013-6-1+2-14-0.189 [error] 1223 1058
2013-6-1+3-14-0.566 [error] 1223 1058
2013-6-1+8-50-19.493 [error] 1223 1058
2013-6-1+9-14-0.190 [error] 1223 1058
2013-6-1+10-14-0.52 [error] 1223 1058
2013-6-1+11-14-0.40 [error] 1223 1058
2013-6-1+12-14-0.42 [error] 1223 1058
2013-6-1+13-14-0.45 [error] 1223 1058
2013-6-1+14-14-0.63 [error] 1223 1058
2013-6-1+15-14-0.35 [error] 1223 1058
2013-6-1+16-14-0.38 [error] 1223 1058
2013-6-1+17-14-0.37 [error] 1223 1058
2013-6-1+18-14-0.109 [error] 1223 1058
2013-6-1+19-14-0.188 [error] 1223 1058
2013-6-1+20-14-0.191 [error] 1223 1058
2013-6-1+21-14-0.200 [error] 1223 1058
2013-6-1+22-14-0.187 [error] 1223 1058
2013-6-1+23-14-0.174 [error] 1223 1058
2013-6-2+4-39-2.374 [error] 1223 1058
2013-6-2+19-14-0.195 [error] 1223 1058
2013-6-2+20-14-0.182 [error] 1223 1058
2013-6-2+21-14-0.201 [error] 1223 1058
2013-6-3+5-0-47.608 [error] 1223 1058
2013-6-3+17-14-0.263 [error] 1223 1058
2013-6-3+18-14-0.186 [error] 1223 1058
2013-6-3+19-14-0.206 [error] 1223 1058
2013-6-3+20-14-0.243 [error] 1223 1058
2013-6-3+21-14-0.199 [error] 1223 1058
2013-6-3+23-0-59.545 [error] 1223 1058
2013-6-3+23-14-0.189 [error] 1223 1058
2013-6-4+0-14-0.236 [error] 1223 1058
2013-6-4+1-14-0.197 [error] 1223 1058
2013-6-4+2-14-0.200 [error] 1223 1058
2013-6-4+3-14-0.187 [error] 1223 1058
2013-6-4+17-14-0.233 [error] 1223 1058
2013-6-4+18-14-0.267 [error] 1223 1058
2013-6-4+19-14-0.192 [error] 1223 1058
2013-6-4+20-21-38.14 [error] 1223 1058
2013-6-4+21-14-0.188 [error] 1223 1058
2013-6-4+22-14-0.558 [error] 1223 1058
2013-6-4+23-14-0.173 [error] 1223 1058
2013-6-5+0-14-0.187 [error] 1223 1058
2013-6-5+1-14-0.181 [error] 1223 1058
2013-6-5+2-14-0.199 [error] 1223 1058
2013-6-5+3-14-0.202 [error] 1223 1058
2013-6-5+14-52-55.551 [error] 1223 1058
2013-6-5+15-14-0.221 [error] 1223 1058
2013-6-5+16-14-0.192 [error] 1223 1058
2013-6-5+17-14-0.195 [error] 1223 1058
2013-6-5+19-12-49.108 [error] 1223 1058
2013-6-5+19-14-0.15 [error] 1223 1058
2013-6-5+20-14-0.196 [error] 1223 1058
2013-6-5+21-14-0.198 [error] 1223 1058
2013-6-5+22-14-0.201 [error] 1223 1058
2013-6-5+23-14-18.952 [error] 1223 1058
2013-6-6+0-14-0.213 [error] 1223 1058
2013-6-6+1-14-0.325 [error] 1223 1058
2013-6-6+2-14-4.88 [error] 1223 1058
2013-6-6+17-11-45.76 [error] 1223 1058
2013-6-6+17-14-0.16 [error] 1223 1058
2013-6-6+18-14-0.292 [error] 1223 1058
2013-6-6+19-14-0.193 [error] 1223 1058
2013-6-6+20-14-0.196 [error] 1223 1058
2013-6-6+21-14-0.199 [error] 1223 1058
2013-6-7+5-9-57.249 [error] 1223 1058
2013-6-11+17-14-1.981 [error] 1223 1058
2013-6-11+18-14-7.399 [error] 1223 1058
2013-6-11+19-14-0.350 [error] 1223 1058
2013-6-11+20-14-0.197 [error] 1223 1058
2013-6-11+23-19-40.530 [error] 1223 1058
2013-6-12+0-14-6.124 [error] 1223 1058
2013-6-12+1-14-0.203 [error] 1223 1058
2013-6-12+2-14-0.314 [error] 1223 1058
2013-6-12+3-14-0.196 [error] 1223 1058
2013-6-12+3-14-0.230 [error] 1223 1058
2013-6-12+4-14-0.194 [error] 1223 1058
2013-6-12+18-14-0.597 [error] 1223 1058
2013-6-12+19-14-0.192 [error] 1223 1058
2013-6-12+20-14-0.196 [error] 1223 1058
2013-6-12+21-14-0.172 [error] 1223 1058
2013-6-12+22-14-0.356 [error] 1223 1058
2013-6-12+23-14-0.176 [error] 1223 1058
2013-6-12+23-14-0.223 [error] 1223 1058
2013-6-13+0-14-0.193 [error] 1223 1058
2013-6-13+1-14-0.194 [error] 1223 1058
2013-6-13+1-14-0.225 [error] 1223 1058
2013-6-13+2-14-0.197 [error] 1223 1058
2013-6-13+3-14-0.231 [error] 1223 1058
2013-6-13+10-0-26.912 [error] 1223 1058
2013-6-13+10-14-0.204 [error] 1223 1058
2013-6-13+11-14-0.284 [error] 1223 1058
2013-6-13+12-14-0.194 [error] 1223 1058
2013-6-13+13-14-0.196 [error] 1223 1058
2013-6-13+16-15-52.328 [error] 1223 1058
2013-6-13+17-14-0.173 [error] 1223 1058
2013-6-13+18-14-0.266 [error] 1223 1058
2013-6-13+19-14-0.221 [error] 1223 1058
2013-6-13+20-23-42.562 [error] 1223 1058
2013-6-13+22-42-35.578 [error] 1223 1058
2013-6-13+23-14-0.195 [error] 1223 1058
2013-6-14+0-14-0.195 [error] 1223 1058
2013-6-14+1-14-0.267 [error] 1223 1058
2013-6-14+2-14-0.208 [error] 1223 1058
2013-6-14+3-14-0.195 [error] 1223 1058
2013-6-14+4-14-0.197 [error] 1223 1058
2013-6-14+16-24-41.375 [error] 1223 1058
2013-6-14+17-14-0.744 [error] 1223 1058
2013-6-14+18-14-0.193 [error] 1223 1058
2013-6-14+19-14-0.231 [error] 1223 1058
2013-6-14+20-14-0.191 [error] 1223 1058
2013-6-14+21-14-0.252 [error] 1223 1058
2013-6-14+22-14-1.982 [error] 1223 1058
2013-6-14+23-14-0.300 [error] 1223 1058
2013-6-15+0-14-0.193 [error] 1223 1058
2013-6-15+1-14-0.199 [error] 1223 1058
2013-6-15+2-14-0.179 [error] 1223 1058
2013-6-15+3-14-0.197 [error] 1223 1058
2013-6-15+4-14-0.356 [error] 1223 1058
2013-6-15+5-14-0.187 [error] 1223 1058
2013-6-15+19-32-54.562 [error] 1223 1058
2013-6-15+20-14-0.189 [error] 1223 1058
2013-6-15+21-14-3.906 [error] 1223 1058
2013-6-15+22-14-2.720 [error] 1223 1058
2013-6-16+16-45-29.28 [error] 1223 1058
2013-6-16+17-14-0.658 [error] 1223 1058
2013-6-16+18-14-0.345 [error] 1223 1058
2013-6-16+19-14-0.192 [error] 1223 1058
2013-6-16+20-14-0.195 [error] 1223 1058
2013-6-16+21-14-0.198 [error] 1223 1058
2013-6-16+22-14-0.200 [error] 1223 1058
2013-6-16+23-14-0.187 [error] 1223 1058
2013-6-17+16-54-11.30 [error] 1223 1058
2013-6-17+17-14-2.390 [error] 1223 1058
2013-6-17+18-14-0.146 [error] 1223 1058
2013-6-17+19-14-0.32 [error] 1223 1058
2013-6-17+20-14-0.190 [error] 1223 1058
2013-6-17+21-14-0.349 [error] 1223 1058
2013-6-17+22-14-0.189 [error] 1223 1058
2013-6-17+23-14-0.195 [error] 1223 1058
2013-6-18+0-14-0.195 [error] 1223 1058
2013-6-18+1-14-0.198 [error] 1223 1058
2013-6-18+2-14-0.201 [error] 1223 1058
2013-6-18+10-0-22.139 [error] 1223 1058
2013-6-18+10-14-0.33 [error] 1223 1058
2013-6-18+11-14-0.35 [error] 1223 1058
2013-6-18+12-14-0.22 [error] 1223 1058
2013-6-18+15-45-28.361 [error] 1223 1058
2013-6-18+16-14-0.104 [error] 1223 1058
2013-6-18+17-14-0.200 [error] 1223 1058
2013-6-18+18-14-0.195 [error] 1223 1058
2013-6-18+19-14-0.197 [error] 1223 1058
2013-6-18+20-14-0.193 [error] 1223 1058
2013-6-18+21-14-0.196 [error] 1223 1058
2013-6-18+22-14-0.199 [error] 1223 1058
2013-6-18+23-14-0.201 [error] 1223 1058
2013-6-19+16-15-21.265 [error] 1223 1058
2013-6-19+17-14-0.206 [error] 1223 1058
2013-6-19+18-14-0.193 [error] 1223 1058
2013-6-19+19-14-0.198 [error] 1223 1058
2013-6-19+20-14-0.196 [error] 1223 1058
2013-6-19+21-14-0.199 [error] 1223 1058
2013-6-19+22-14-0.186 [error] 1223 1058
2013-6-19+23-25-43.937 [error] 1223 1058
2013-6-20+0-14-0.193 [error] 1223 1058
2013-6-20+1-14-0.189 [error] 1223 1058
2013-6-20+2-14-0.347 [error] 1223 1058
2013-6-20+3-14-0.192 [error] 1223 1058
2013-6-20+16-18-38.936 [error] 1223 1058
2013-6-20+17-14-0.386 [error] 1223 1058
2013-6-20+18-14-0.311 [error] 1223 1058
2013-6-20+19-14-0.189 [error] 1223 1058
2013-6-20+20-36-50.264 [error] 1223 1058
2013-6-20+21-14-0.188 [error] 1223 1058
2013-6-20+22-14-0.197 [error] 1223 1058
2013-6-20+23-14-0.200 [error] 1223 1058
2013-6-21+0-14-0.203 [error] 1223 1058
2013-6-21+4-33-22.920 [error] 1223 1058
2013-6-21+5-14-0.194 [error] 1223 1058
2013-6-21+6-14-0.197 [error] 1223 1058
2013-6-21+7-14-0.200 [error] 1223 1058
2013-6-21+15-24-19.609 [error] 1223 1058
2013-6-21+15-31-39.405 [error] 1226 1062
=O====== M/11.7.700.224 2013-06-21+15-31-18.610 ========
0000 00000010 "C:\Users\nellem\AppData\Local\Temp\{DEC962C7-C7CC-40C6-B3BB-495D7EF53D38}\InstallFlashPlayer.exe" -iv 4
0002
0003
0004
0005
0006 00000013 C:\Windows\system32\Macromed\Flash\Flash32_11_7_700_224.ocx
0007 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_7_700_224_ActiveX.exe
0008 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_7_700_224_ActiveX.dll
0009 00000023 C:\Windows\system32\Macromed\Flash\activex.vch
0010 00000019 C:\Windows\system32\FlashPlayerCPLApp.cpl
0011
0012
0014
0015
0016
0017 00000012
=X====== M/11.7.700.224 2013-06-21+15-31-48.125 ========
=O====== M/11.7.700.202 2013-06-21+15-29-24.141 ========
0000 00000010 "C:\Windows\System32\Macromed\Flash\FlashUtil32_11_7_700_202_ActiveX.exe" -update activex
0001 00000011 1
=X====== M/11.7.700.202 2013-06-21+15-31-48.172 ========
2013-6-21+16-14-0.376 [error] 1223 1058
2013-6-21+17-14-0.191 [error] 1223 1058
2013-6-21+18-14-0.194 [error] 1223 1058
2013-6-21+19-19-32.736 [error] 1223 1058
2013-6-21+20-14-0.212 [error] 1223 1058
2013-6-21+21-14-0.203 [error] 1223 1058
2013-6-21+22-14-0.237 [error] 1223 1058
2013-6-21+23-14-0.333 [error] 1223 1058
2013-6-22+0-15-12.92 [error] 1223 1058
2013-6-22+1-14-0.187 [error] 1223 1058
2013-6-22+2-14-0.190 [error] 1223 1058
2013-6-22+3-14-0.208 [error] 1223 1058
2013-6-22+17-58-37.189 [error] 1223 1058
2013-6-22+18-14-0.314 [error] 1223 1058
2013-6-22+19-14-0.302 [error] 1223 1058
2013-6-22+20-14-0.690 [error] 1223 1058
2013-6-22+21-16-50.338 [error] 1223 1058
2013-6-23+19-23-45.640 [error] 1223 1058
2013-6-23+20-14-0.361 [error] 1223 1058
2013-6-23+21-14-0.269 [error] 1223 1058
2013-6-23+22-14-0.256 [error] 1223 1058
2013-6-23+23-14-0.257 [error] 1223 1058
2013-6-24+0-14-0.260 [error] 1223 1058
2013-6-24+1-14-0.278 [error] 1223 1058
2013-6-24+2-14-0.172 [error] 1223 1058
2013-6-24+3-14-0.65 [error] 1223 1058
2013-6-24+3-14-0.284 [error] 1223 1058
2013-6-24+18-14-0.221 [error] 1223 1058
2013-6-24+19-14-0.252 [error] 1223 1058
2013-6-24+20-14-0.284 [error] 1223 1058
2013-6-24+21-14-0.307 [error] 1223 1058
2013-6-24+22-14-0.257 [error] 1223 1058
2013-6-24+23-14-0.279 [error] 1223 1058
2013-6-25+0-14-0.278 [error] 1223 1058
2013-6-25+1-14-0.249 [error] 1223 1058
2013-6-25+2-14-0.970 [error] 1223 1058
2013-6-25+16-45-16.904 [error] 1223 1058
2013-6-25+17-14-0.258 [error] 1223 1058
2013-6-25+18-14-0.480 [error] 1223 1058
2013-6-25+19-14-0.249 [error] 1223 1058
2013-6-25+20-40-8.0 [error] 1223 1058
2013-6-25+21-14-0.258 [error] 1223 1058
2013-6-25+22-14-0.250 [error] 1223 1058
2013-6-25+23-14-0.258 [error] 1223 1058
2013-6-26+0-14-0.284 [error] 1223 1058
2013-6-26+1-14-0.280 [error] 1223 1058
2013-6-26+2-14-23.277 [error] 1223 1058
2013-6-26+3-14-0.254 [error] 1223 1058
2013-6-26+17-8-7.391 [error] 1223 1058
2013-6-26+17-14-0.252 [error] 1223 1058
2013-6-26+18-14-0.255 [error] 1223 1058
2013-6-26+19-14-0.280 [error] 1223 1058
2013-6-26+20-14-0.280 [error] 1223 1058
2013-6-26+21-14-0.300 [error] 1223 1058
2013-6-26+22-14-0.454 [error] 1223 1058
2013-6-26+23-14-0.267 [error] 1223 1058
2013-6-27+0-14-0.255 [error] 1223 1058
2013-6-27+1-14-0.325 [error] 1223 1058
2013-6-27+2-14-2.504 [error] 1223 1058
2013-6-27+3-14-0.298 [error] 1223 1058
2013-6-27+20-54-34.598 [error] 1223 1058
2013-6-27+21-14-0.259 [error] 1223 1058
2013-6-27+22-14-0.263 [error] 1223 1058
2013-6-27+23-14-0.285 [error] 1223 1058
2013-6-28+0-14-0.253 [error] 1223 1058
2013-6-28+1-14-0.475 [error] 1223 1058
2013-6-28+2-14-0.713 [error] 1223 1058
2013-6-28+3-14-0.388 [error] 1223 1058
2013-6-28+4-15-59.99 [error] 1223 1058
2013-6-28+15-13-9.680 [error] 1223 1058
2013-6-28+15-14-6.588 [error] 1223 1058
2013-6-28+16-14-0.271 [error] 1223 1058
2013-6-28+17-14-0.262 [error] 1223 1058
2013-6-28+18-14-0.347 [error] 1223 1058
2013-6-28+19-14-0.291 [error] 1223 1058
2013-6-28+20-14-0.260 [error] 1223 1058
2013-6-28+21-14-0.328 [error] 1223 1058
2013-6-28+22-14-0.419 [error] 1223 1058
2013-6-28+23-14-0.257 [error] 1223 1058
2013-6-29+0-14-0.262 [error] 1223 1058
2013-6-29+1-14-0.253 [error] 1223 1058
2013-6-29+2-14-0.257 [error] 1223 1058
2013-6-29+3-14-0.259 [error] 1223 1058
2013-6-29+22-10-35.467 [error] 1223 1058
2013-6-29+22-14-0.90 [error] 1223 1058
2013-6-29+23-14-0.470 [error] 1223 1058
2013-6-30+0-14-20.880 [error] 1223 1058
2013-6-30+1-14-1.610 [error] 1223 1058
2013-6-30+2-14-1.482 [error] 1223 1058
2013-6-30+3-14-0.284 [error] 1223 1058
2013-6-30+4-14-0.271 [error] 1223 1058
2013-6-30+5-14-2.697 [error] 1223 1058
2013-6-30+6-14-1.358 [error] 1223 1058
2013-6-30+7-14-0.284 [error] 1223 1058
2013-6-30+16-54-27.343 [error] 1223 1058
2013-6-30+17-14-0.283 [error] 1223 1058
2013-6-30+18-14-0.272 [error] 1223 1058
2013-6-30+19-14-0.299 [error] 1223 1058
2013-6-30+20-14-1.85 [error] 1223 1058
2013-6-30+21-14-0.261 [error] 1223 1058
2013-6-30+22-15-25.328 [error] 1223 1058
2013-6-30+23-14-0.265 [error] 1223 1058
2013-7-1+18-27-33.257 [error] 1223 1058
2013-7-1+19-14-0.86 [error] 1223 1058
2013-7-1+20-14-0.296 [error] 1223 1058
2013-7-1+21-14-0.269 [error] 1223 1058
2013-7-1+22-14-0.353 [error] 1223 1058
2013-7-1+23-14-0.262 [error] 1223 1058
2013-7-2+0-14-0.258 [error] 1223 1058
2013-7-2+1-14-0.271 [error] 1223 1058
2013-7-2+2-14-0.383 [error] 1223 1058
2013-7-2+3-14-0.277 [error] 1223 1058
2013-7-2+16-37-7.900 [error] 1223 1058
2013-7-2+17-14-0.332 [error] 1223 1058
2013-7-2+18-14-0.257 [error] 1223 1058
2013-7-2+19-14-0.275 [error] 1223 1058
2013-7-2+20-14-0.306 [error] 1223 1058
2013-7-2+21-14-0.215 [error] 1223 1058
2013-7-2+22-14-0.265 [error] 1223 1058
2013-7-2+23-14-0.321 [error] 1223 1058
2013-7-3+0-14-0.258 [error] 1223 1058
2013-7-3+1-14-0.261 [error] 1223 1058
2013-7-3+2-14-0.263 [error] 1223 1058
2013-7-3+3-14-0.274 [error] 1223 1058
2013-7-3+4-14-0.269 [error] 1223 1058
2013-7-3+17-2-14.780 [error] 1223 1058
2013-7-3+17-14-0.265 [error] 1223 1058
2013-7-3+18-14-0.240 [error] 1223 1058
2013-7-3+19-14-0.346 [error] 1223 1058
2013-7-3+20-14-0.271 [error] 1223 1058
2013-7-3+21-14-0.258 [error] 1223 1058
2013-7-4+18-18-8.433 [error] 1223 1058
2013-7-4+19-14-0.251 [error] 1223 1058
2013-7-4+20-14-0.268 [error] 1223 1058
2013-7-4+21-14-0.290 [error] 1223 1058
2013-7-4+22-14-0.883 [error] 1223 1058
2013-7-4+23-14-0.366 [error] 1223 1058
2013-7-5+0-14-0.260 [error] 1223 1058
2013-7-5+1-14-0.262 [error] 1223 1058
2013-7-5+3-35-5.229 [error] 1223 1058
2013-7-5+4-14-0.269 [error] 1223 1058
2013-7-5+16-14-0.276 [error] 1223 1058
2013-7-5+17-14-0.287 [error] 1223 1058
2013-7-5+18-14-0.258 [error] 1223 1058
2013-7-5+19-14-0.262 [error] 1223 1058
2013-7-5+21-18-6.546 [error] 1223 1058
2013-7-5+22-14-0.202 [error] 1223 1058
2013-7-5+23-14-0.252 [error] 1223 1058
2013-7-6+0-14-0.270 [error] 1223 1058
2013-7-6+1-14-0.261 [error] 1223 1058
2013-7-6+2-14-0.264 [error] 1223 1058
2013-7-6+17-33-9.636 [error] 1223 1058
2013-7-6+18-14-0.449 [error] 1223 1058
2013-7-6+19-14-6.269 [error] 1223 1058
2013-7-6+20-14-0.483 [error] 1223 1058
2013-7-7+21-58-56.848 [error] 1223 1058
2013-7-7+22-14-0.278 [error] 1223 1058
2013-7-7+23-14-0.220 [error] 1223 1058
2013-7-8+0-14-0.223 [error] 1223 1058
2013-7-8+1-14-0.260 [error] 1223 1058
2013-7-8+2-14-0.107 [error] 1223 1058
2013-7-8+3-14-0.63 [error] 1223 1058
2013-7-8+4-14-0.66 [error] 1223 1058
2013-7-8+16-2-49.136 [error] 1223 1058
2013-7-8+16-14-0.260 [error] 1223 1058
2013-7-8+17-14-0.263 [error] 1223 1058
2013-7-8+18-14-0.253 [error] 1223 1058
2013-7-8+19-14-0.253 [error] 1223 1058
2013-7-8+20-14-0.395 [error] 1223 1058
2013-7-8+21-14-0.225 [error] 1223 1058
2013-7-8+22-14-0.252 [error] 1223 1058
2013-7-8+23-14-0.294 [error] 1223 1058
2013-7-9+0-14-0.252 [error] 1223 1058
2013-7-9+1-14-0.253 [error] 1223 1058
2013-7-9+2-14-0.255 [error] 1223 1058
2013-7-9+3-14-0.270 [error] 1223 1058
2013-7-9+15-14-0.245 [error] 1223 1058
2013-7-9+16-14-0.272 [error] 1223 1058
2013-7-9+17-14-0.228 [error] 1223 1058
2013-7-9+18-14-0.245 [error] 1223 1058
2013-7-9+19-14-0.259 [error] 1223 1058
2013-7-9+20-14-0.317 [error] 1223 1058
2013-7-9+21-14-0.316 [error] 1223 1058
2013-7-9+22-14-0.255 [error] 1223 1058
2013-7-9+23-14-0.246 [error] 1223 1058
2013-7-10+0-14-0.267 [error] 1223 1058
2013-7-10+1-14-0.255 [error] 1223 1058
2013-7-10+2-14-0.246 [error] 1223 1058
2013-7-10+16-14-0.278 [error] 1223 1058
2013-7-10+17-14-1.44 [error] 1223 1058
2013-7-10+18-14-0.336 [error] 1223 1058
2013-7-10+19-14-0.251 [error] 1223 1058
2013-7-10+21-34-5.199 [error] 1223 1058
2013-7-10+22-14-0.258 [error] 1223 1058
2013-7-10+23-14-0.256 [error] 1223 1058
2013-7-11+0-14-0.250 [error] 1223 1058
2013-7-11+10-0-28.192 [error] 1223 1058
2013-7-11+10-14-0.575 [error] 1223 1058
2013-7-11+11-14-0.274 [error] 1223 1058
2013-7-11+12-14-0.261 [error] 1223 1058
2013-7-11+13-14-0.217 [error] 1223 1058
2013-7-11+15-44-20.685 [error] 1223 1058
2013-7-11+16-14-0.273 [error] 1223 1058
2013-7-11+17-14-0.257 [error] 1223 1058
2013-7-11+18-14-0.254 [error] 1223 1058
2013-7-11+19-14-0.245 [error] 1223 1058
2013-7-11+20-14-0.233 [error] 1223 1058
2013-7-11+21-14-0.254 [error] 1223 1058
2013-7-11+22-14-0.273 [error] 1223 1058
2013-7-11+23-14-0.385 [error] 1223 1058
2013-7-12+0-14-0.311 [error] 1223 1058
2013-7-12+1-14-0.237 [error] 1223 1058
2013-7-12+2-14-0.255 [error] 1223 1058
2013-7-12+3-14-0.258 [error] 1223 1058
2013-7-12+4-16-0.439 [error] 1223 1058
2013-7-12+17-14-0.307 [error] 1223 1058
2013-7-12+18-14-0.565 [error] 1223 1058
2013-7-12+19-14-0.256 [error] 1223 1058
2013-7-12+20-14-0.258 [error] 1223 1058
2013-7-12+21-27-45.439 [error] 1223 1058
=O====== M/11.7.700.224 2013-07-12+21-43-56.129 ========
0000 00000010 "C:\Windows\System32\Macromed\Flash\FlashUtil32_11_7_700_224_ActiveX.exe" -update activex
0001
=X====== M/11.7.700.224 2013-07-12+21-44-02.989 ========
=O====== M/11.8.800.94 2013-08-06+14-46-34.227 ========
0000 00000010 "C:\Windows\system32\Macromed\Flash\FlashUtil32_11_8_800_94_ActiveX.exe" -refreshIEElevationPolicies
=X====== M/11.8.800.94 2013-08-06+14-46-34.286 ========
=O====== M/11.8.800.94 2013-08-06+14-46-31.314 ========
0000 00000010 "C:\Users\nellem\AppData\Local\Adobe\AIH.37995c13545288fd47f7ec6e5eb0e1c62c12939b\install_flash_player_ax.exe" -install -iv 8
0002 00000013 C:\Windows\system32\Macromed\Flash\Flash32_11_8_800_94.ocx
0003 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_8_800_94_ActiveX.exe
0004 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_8_800_94_ActiveX.dll
0007
0008
0010
0011
0012
0013 00000012
=X====== M/11.8.800.94 2013-08-06+14-46-37.381 ========
=O====== M/11.8.800.94 2013-08-06+23-38-24.353 ========
0000 00000010 "C:\Windows\system32\Macromed\Flash\FlashUtil32_11_8_800_94_ActiveX.exe" -maintain activex
=X====== M/11.8.800.94 2013-08-06+23-38-28.736 ========
=O====== M/11.8.800.94 2013-08-06+23-42-14.240 ========
0001
=X====== M/11.8.800.94 2013-08-06+23-42-14.398 ========
=O====== M/11.8.800.94 2013-08-06+23-43-20.904 ========
0001
=X====== M/11.8.800.94 2013-08-06+23-43-21.063 ========
=O====== M/11.8.800.94 2013-08-06+23-43-23.776 ========
0001
=X====== M/11.8.800.94 2013-08-06+23-43-23.963 ========
=O====== M/11.8.800.94 2013-08-06+23-43-31.958 ========
0007
0008
0010
0011
0012
0013 00000012
=X====== M/11.8.800.94 2013-08-06+23-43-35.551 ========
2013-9-20+2-14-2.596 [error] 1223 1058
2013-9-20+3-14-0.431 [error] 1223 1058
2013-9-20+18-14-0.193 [error] 1223 1058
2013-9-20+19-14-0.305 [error] 1223 1058
2013-9-20+20-14-0.276 [error] 1223 1058
2013-9-20+23-31-19.905 [error] 1223 1058
2013-9-21+0-14-0.274 [error] 1223 1058
2013-9-21+1-14-0.277 [error] 1223 1058
2013-9-21+2-14-0.279 [error] 1223 1058
2013-9-21+18-19-31.716 [error] 1223 1058
2013-9-21+19-14-0.563 [error] 1223 1058
2013-9-21+20-14-7.23 [error] 1223 1058
2013-9-21+21-14-0.622 [error] 1223 1058
2013-9-21+22-14-4.134 [error] 1223 1058
2013-9-22+18-21-18.958 [error] 1223 1058
2013-9-22+19-14-0.324 [error] 1223 1058
2013-9-22+20-14-0.298 [error] 1223 1058
2013-9-22+21-14-0.264 [error] 1223 1058
2013-9-22+22-14-0.298 [error] 1223 1058
2013-9-22+23-14-0.285 [error] 1223 1058
2013-9-23+5-1-25.855 [error] 1223 1058
2013-9-23+20-14-0.317 [error] 1223 1058
2013-9-23+21-14-0.304 [error] 1223 1058
2013-9-23+22-14-0.343 [error] 1223 1058
2013-9-23+23-14-0.289 [error] 1223 1058
2013-9-24+0-14-0.295 [error] 1223 1058
2013-9-24+1-14-0.267 [error] 1223 1058
2013-9-24+2-14-0.269 [error] 1223 1058
2013-9-24+3-14-0.271 [error] 1223 1058
2013-9-24+4-14-0.274 [error] 1223 1058
2013-9-24+19-30-29.95 [error] 1223 1058
2013-9-24+20-14-0.279 [error] 1223 1058
2013-9-24+21-14-0.252 [error] 1223 1058
2013-9-24+22-14-0.249 [error] 1223 1058
2013-9-24+23-14-0.274 [error] 1223 1058
2013-9-25+0-14-0.265 [error] 1223 1058
2013-9-25+1-14-0.300 [error] 1223 1058
2013-9-25+2-14-0.288 [error] 1223 1058
2013-9-25+3-14-0.291 [error] 1223 1058
2013-9-25+4-14-0.206 [error] 1223 1058
2013-9-25+19-14-0.285 [error] 1223 1058
2013-9-25+20-14-0.288 [error] 1223 1058
2013-9-25+21-14-0.659 [error] 1223 1058
2013-9-25+22-14-0.266 [error] 1223 1058
2013-9-25+23-14-0.275 [error] 1223 1058
2013-9-26+0-14-0.274 [error] 1223 1058
2013-9-26+1-14-0.375 [error] 1223 1058
2013-9-26+2-14-0.417 [error] 1223 1058
2013-9-26+3-14-0.279 [error] 1223 1058
2013-9-26+15-14-0.340 [error] 1223 1058
2013-9-26+16-14-0.291 [error] 1223 1058
2013-9-26+17-14-0.271 [error] 1223 1058
2013-9-26+18-14-0.274 [error] 1223 1058
2013-9-26+19-14-0.277 [error] 1223 1058
2013-9-26+20-57-23.296 [error] 1223 1058
2013-9-26+21-14-0.256 [error] 1223 1058
2013-9-26+22-14-0.362 [error] 1223 1058
2013-9-26+23-14-0.261 [error] 1223 1058
2013-9-27+0-14-0.279 [error] 1223 1058
2013-9-27+1-14-0.270 [error] 1223 1058
2013-9-27+3-14-0.349 [error] 1223 1058
2013-9-27+4-14-0.303 [error] 1223 1058
2013-9-27+16-14-0.284 [error] 1223 1058
2013-9-27+17-14-0.293 [error] 1223 1058
2013-9-27+18-14-0.234 [error] 1223 1058
2013-9-27+19-14-0.246 [error] 1223 1058
2013-9-27+20-14-0.259 [error] 1223 1058
2013-9-27+21-14-0.240 [error] 1223 1058
2013-9-27+22-14-0.293 [error] 1223 1058
2013-9-27+23-14-0.229 [error] 1223 1058
2013-9-28+0-14-0.280 [error] 1223 1058
2013-9-28+1-14-1.764 [error] 1223 1058
2013-9-28+2-14-0.269 [error] 1223 1058
2013-9-28+4-58-51.281 [error] 1223 1058
2013-9-28+20-14-0.308 [error] 1223 1058
2013-9-28+21-14-1.93 [error] 1223 1058
2013-9-28+22-14-0.737 [error] 1223 1058
2013-9-29+18-32-26.622 [error] 1223 1058
2013-9-29+19-14-1.38 [error] 1223 1058
2013-9-29+20-14-0.556 [error] 1223 1058
2013-9-29+21-14-0.606 [error] 1223 1058
2013-9-29+22-14-0.594 [error] 1223 1058
2013-9-29+23-14-0.157 [error] 1223 1058
2013-9-30+0-14-0.456 [error] 1223 1058
2013-9-30+1-14-0.458 [error] 1223 1058
2013-9-30+2-14-1.7 [error] 1223 1058
2013-9-30+18-42-30.154 [error] 1223 1058
2013-9-30+19-14-0.407 [error] 1223 1058
2013-9-30+20-14-0.319 [error] 1223 1058
2013-9-30+21-14-0.275 [error] 1223 1058
2013-9-30+22-14-0.287 [error] 1223 1058
2013-9-30+23-14-0.277 [error] 1223 1058
2013-10-1+0-14-0.336 [error] 1223 1058
2013-10-1+1-14-0.283 [error] 1223 1058
2013-10-1+2-14-0.380 [error] 1223 1058
2013-10-1+3-14-0.254 [error] 1223 1058
2013-10-1+4-14-0.260 [error] 1223 1058
2013-10-1+16-14-0.394 [error] 1223 1058
2013-10-1+17-14-1.458 [error] 1223 1058
2013-10-1+18-14-0.275 [error] 1223 1058
2013-10-1+19-20-32.17 [error] 1223 1058
2013-10-1+20-14-0.312 [error] 1223 1058
2013-10-1+21-14-0.271 [error] 1223 1058
2013-10-1+22-14-0.337 [error] 1223 1058
2013-10-1+23-14-0.268 [error] 1223 1058
2013-10-2+0-29-4.188 [error] 1223 1058
2013-10-2+1-14-0.265 [error] 1223 1058
2013-10-2+2-14-0.252 [error] 1223 1058
2013-10-2+3-14-0.271 [error] 1223 1058
2013-10-2+4-56-42.842 [error] 1223 1058
2013-10-2+18-14-0.303 [error] 1223 1058
2013-10-2+19-14-0.284 [error] 1223 1058
2013-10-2+20-14-0.285 [error] 1223 1058
2013-10-2+21-14-0.272 [error] 1223 1058
2013-10-2+22-14-0.274 [error] 1223 1058
2013-10-3+0-0-37.878 [error] 1223 1058
2013-10-3+0-14-0.268 [error] 1223 1058
2013-10-3+1-14-0.271 [error] 1223 1058
2013-10-3+2-14-1.274 [error] 1223 1058
2013-10-3+3-14-0.327 [error] 1223 1058
2013-10-3+15-38-58.608 [error] 1223 1058
2013-10-3+16-14-0.499 [error] 1223 1058
2013-10-3+17-14-0.346 [error] 1223 1058
2013-10-3+18-14-0.271 [error] 1223 1058
2013-10-3+19-14-0.275 [error] 1223 1058
2013-10-3+21-6-13.451 [error] 1223 1058
2013-10-3+21-14-0.288 [error] 1223 1058
2013-10-3+22-14-0.259 [error] 1223 1058
2013-10-3+23-14-0.221 [error] 1223 1058
2013-10-4+0-14-0.276 [error] 1223 1058
2013-10-4+1-14-0.278 [error] 1223 1058
2013-10-4+2-14-0.296 [error] 1223 1058
2013-10-4+3-14-0.267 [error] 1223 1058
2013-10-4+4-58-33.703 [error] 1223 1058
2013-10-4+22-14-0.274 [error] 1223 1058
2013-10-4+23-14-0.277 [error] 1223 1058
2013-10-5+0-14-0.263 [error] 1223 1058
2013-10-5+1-14-0.266 [error] 1223 1058
2013-10-5+2-14-0.268 [error] 1223 1058
2013-10-5+17-0-31.502 [error] 1223 1058
2013-10-5+17-14-0.272 [error] 1223 1058
2013-10-5+18-14-0.839 [error] 1223 1058
2013-10-5+19-14-4.240 [error] 1223 1058
2013-10-5+20-14-0.537 [error] 1223 1058
=O====== M/11.8.800.175 2013-10-05+21-09-39.986 ========
0000 00000010 "C:\Windows\system32\Macromed\Flash\FlashUtil32_11_8_800_175_ActiveX.exe" -refreshIEElevationPolicies
=X====== M/11.8.800.175 2013-10-05+21-09-40.005 ========
=O====== M/11.8.800.175 2013-10-05+21-09-40.033 ========
=X====== M/11.8.800.175 2013-10-05+21-09-40.040 ========
=O====== M/11.8.800.175 2013-10-05+21-09-40.047 ========
=X====== M/11.8.800.175 2013-10-05+21-09-40.055 ========
=O====== M/11.8.800.175 2013-10-05+21-09-36.120 ========
0002 00000013 C:\Windows\system32\Macromed\Flash\Flash32_11_8_800_175.ocx
0003 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_8_800_175_ActiveX.exe
0004 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_8_800_175_ActiveX.dll
0007
0008
0010
0011
0012
0013 00000012
=X====== M/11.8.800.175 2013-10-05+21-09-43.384 ========
2013-10-5+21-14-0.363 [error] 1223 1058
2013-10-5+22-14-0.287 [error] 1223 1058
2013-10-5+23-14-0.294 [error] 1223 1058
2013-10-6+0-14-0.265 [error] 1223 1058
2013-10-6+1-14-0.268 [error] 1223 1058
2013-10-6+4-42-44.831 [error] 1223 1058
2013-10-6+17-25-40.814 [error] 1223 1058
2013-10-6+18-14-0.305 [error] 1223 1058
2013-10-6+19-14-0.277 [error] 1223 1058
2013-10-6+20-14-1.869 [error] 1223 1058
2013-10-6+21-14-0.281 [error] 1223 1058
2013-10-6+22-14-0.299 [error] 1223 1058
2013-10-7+2-52-31.48 [error] 1223 1058
2013-10-7+3-14-0.81 [error] 1223 1058
2013-10-7+4-14-0.68 [error] 1223 1058
2013-10-7+16-29-47.320 [error] 1223 1058
2013-10-7+17-14-0.289 [error] 1223 1058
2013-10-7+18-14-0.287 [error] 1223 1058
2013-10-7+19-14-0.249 [error] 1223 1058
2013-10-7+20-14-0.331 [error] 1223 1058
2013-10-7+21-14-0.265 [error] 1223 1058
2013-10-7+22-14-0.266 [error] 1223 1058
2013-10-7+23-14-0.278 [error] 1223 1058
2013-10-8+0-14-0.267 [error] 1223 1058
2013-10-8+1-14-0.273 [error] 1223 1058
2013-10-8+16-34-54.544 [error] 1223 1058
2013-10-8+17-14-0.415 [error] 1223 1058
2013-10-8+18-14-0.382 [error] 1223 1058
2013-10-8+19-14-0.245 [error] 1223 1058
2013-10-8+22-25-49.804 [error] 1223 1058
2013-10-8+23-14-0.208 [error] 1223 1058
2013-10-9+0-14-0.314 [error] 1223 1058
2013-10-9+1-14-0.426 [error] 1223 1058
2013-10-9+2-14-0.263 [error] 1223 1058
2013-10-9+3-14-0.234 [error] 1223 1058
2013-10-9+4-14-0.242 [error] 1223 1058
2013-10-9+15-14-0.285 [error] 1223 1058
2013-10-9+16-14-0.247 [error] 1223 1058
2013-10-9+17-14-0.271 [error] 1223 1058
2013-10-9+18-14-0.196 [error] 1223 1058
2013-10-9+19-14-0.245 [error] 1223 1058
2013-10-9+22-20-2.406 [error] 1223 1058
2013-10-9+23-14-0.174 [error] 1223 1058
2013-10-10+0-14-0.233 [error] 1223 1058
2013-10-10+1-14-0.237 [error] 1223 1058
2013-10-10+2-14-2.236 [error] 1223 1058
2013-10-10+3-14-0.304 [error] 1223 1058
2013-10-10+4-26-25.170 [error] 1223 1058
=O====== M/11.8.800.175 2013-10-10+04-39-21.016 ========
0000 00000010 "C:\Windows\system32\Macromed\Flash\FlashUtil32_11_8_800_175_ActiveX.exe" -maintain activex
0001
=X====== M/11.8.800.175 2013-10-10+04-39-32.685 ========
2013-10-10+4-39-45.992 [error] 1226 1062
=O====== M/11.8.800.175 2013-10-10+04-39-40.782 ========
0001
0002 00000018
0003
0004
0005 00000018
0006
0007
0008
0009
0010
0011
0012
0013
0014
0015
0016
0017
0018
0019
0020
0021
0022
0023 00000012
=X====== M/11.8.800.175 2013-10-10+04-39-48.909 ========
=O====== M/11.9.900.117 2013-10-10+04-42-55.180 ========
0000 00000010 "C:\Windows\system32\Macromed\Flash\FlashUtil32_11_9_900_117_ActiveX.exe" -refreshIEElevationPolicies
=X====== M/11.9.900.117 2013-10-10+04-42-55.202 ========
=O====== M/11.9.900.117 2013-10-10+04-42-55.194 ========
=X====== M/11.9.900.117 2013-10-10+04-42-55.206 ========
=O====== M/11.9.900.117 2013-10-10+04-42-53.913 ========
0000 00000010 "C:\Users\nellem\AppData\Local\Adobe\AIH.37995c13545288fd47f7ec6e5eb0e1c62c12939b\install_flash_player_ax.exe" -install -iv 8 -au 1
0001
0002
0003 00000020 C:\Windows\system32\FlashPlayerCPLApp.cpl
0004
0005 00000013 C:\Windows\system32\Macromed\Flash\Flash32_11_9_900_117.ocx
0006 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_9_900_117_ActiveX.exe
0007 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_9_900_117_ActiveX.dll
0010 00000021 C:\Windows\system32\Macromed\Flash\FlashPlayerUpdateService.exe
0011 00000012
=X====== M/11.9.900.117 2013-10-10+04-42-55.976 ========
=O====== M/11.9.900.117 2013-10-10+15-30-29.452 ========
0000 00000010 "C:\Users\nellem\Downloads\uninstall_flash_player.exe" -force
0001
0002
0003
0004
0005
0006
0007
0008
0009
0010
0011
0012
0013
0014
0015
0016
0017
0018
0019
0020
0021
0022
0023
0024
0025
0026
0027
0028
0029
0030 00000020 C:\Windows\system32\FlashPlayerCPLApp.cpl
0031
0032
0033
0034
0035
0036
0037
0038
0039
0040
0041
0042
=X====== M/11.9.900.117 2013-10-10+15-30-38.235 ========
=O====== M/11.8.800.175 2013-10-11+00-55-09.002 ========
=X====== M/11.8.800.175 2013-10-11+00-55-09.407 ========
=O====== M/11.8.800.175 2013-10-11+00-55-09.438 ========
=X====== M/11.8.800.175 2013-10-11+00-55-09.454 ========
=O====== M/11.8.800.175 2013-10-11+00-55-07.364 ========
0000 00000010 "C:\Users\nellem\AppData\Local\Temp\InstallAX_11_8_800_175.exe" -install -msi
0001
0002
0003
0005
0006 00000013 C:\Windows\system32\Macromed\Flash\Flash32_11_8_800_175.ocx
0007 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_8_800_175_ActiveX.exe
0008 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_8_800_175_ActiveX.dll
0011 00000021 C:\Windows\system32\Macromed\Flash\FlashPlayerUpdateService.exe
0012 00000012
=X====== M/11.8.800.175 2013-10-11+00-55-16.505 ========
2013-10-11+0-56-31.537 [error] 1226 1062
2013-10-11+0-56-33.206 [error] 1226 1062
2013-10-11+0-56-34.860 [error] 1226 1062
2013-10-11+0-56-37.761 [error] 1226 1062
=O====== M/11.8.800.175 2013-10-11+01-00-37.809 ========
0000 00000010 "C:\Users\nellem\Downloads\fp_11.8.800.175_archive\fp_11.8.800.175_archive\11_8_r800_175_debug\flashplayer11_8r800_175_winax_debug.exe"
0002
0003 00000013 C:\Windows\system32\Macromed\Flash\Flash32_11_8_800_175.ocx
0004 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_8_800_175_ActiveX.exe
0005 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_8_800_175_ActiveX.dll
0006 00000023 C:\Windows\system32\Macromed\Flash\activex.vch
0007 00000019 C:\Windows\system32\FlashPlayerCPLApp.cpl
0008
0009
0010
=X====== M/11.8.800.175 2013-10-11+01-00-52.068 ========
You need to perform a clean install: http://forums.adobe.com/thread/928315
Thank you. A clean install and permitting Google Chrome to install under the enterprise version of Win 7 32 bit resulted in Google Chrome having the plug-in on this computer but IE does NOT! On my other computer running Win 7 professional 32 bit, allowing Chrome to install worked and the plug-in for IE also worked. Both versions of IE are 10, same update (KB2879017). I presume this is really a Microsoft problem?
Chrome uses its own proprietary Flash Player Plugin ("PepperFlash"). It doesn't update through Adobe but rather through updating Chrome.
IE uses the ActiveX plugin here: Flash Player for ActiveX (Internet Explorer)
IF necessary, you can download and run the uninstaller to remove any other Flash Player plugins beforehand.
