33 Replies Latest reply on Oct 6, 2015 4:20 AM by peterv40396918
    PS CS6 action save for web error
    venkatl
      In Photoshop CS6 actions when we save the image as JPEG through save for web it doesn't work when we run it, instead it runs and saves the image as HTML, i guess some error in it. I tried it again and again but it doesn't remember my save for web settings and saves the images as HTML.
        • 1. Re: PS CS6 action save for web error
          c.pfaffenbichler Level 9
          And if you rename the files afterwards?
          • 2. Re: PS CS6 action save for web error
            venkatl Level 1
            If I rename the HTML extension to JPG then the pictures shows, So I tried again to check what extension its taking and I found the format selected as "Images Only" then also its generating HTML extension for the JPEG images.
            I guess its a bug.
            • 3. Re: PS CS6 action save for web error
              JJMack Most Valuable Participant
              Can you save the Action set and upload it to someplace we can download it and look at the actions something may be recorded badly.
              • 4. Re: PS CS6 action save for web error
                venkatl Level 1
                Hi JJMack
                I have saved the action set at the following URL please download and check.
                https://www.yousendit.com/download/QlVqUWVvNHZubHljZDhUQw
                • 5. Re: PS CS6 action save for web error
                  It a new bug in CS6 though when you recorded the action you saved jpeg images to you desktop and you only entered file names onto the save for web action steps the action recorder recorded name.html.  I replaced you save for web steps on my machine for my desktop and CS6 recorded  name.html.  I then did the same with CS5 though I only entered names CS5 recorded name.jpg.
                  If you expand the export steps tou will see the hard coded file names and extention
                  An action like this will always save the same files it can not be batch because you recorded Path and Names in the save for web steps.  The .html files saved on with CS6 are actually jpeg files and if you rename them hrom name.html to name.jpg you can use them,
                  Set: cropping
                            Action: story sizes
                                      Levels
                                                Preset Kind: Custom
                                                Adjustment: levels adjustment list
                                                levels adjustment
                                                Channel: composite channel
                                                Input: 0, 245
                                                Gamma: 1.14
                                      Image Size
                                                Width: 660 pixels
                                                With Scale Styles
                                                With Constrain Proportions
                                                Interpolation: bicubic automatic
                                      Export
                                                Using: Save for Web
                                                Operation: Save
                                                true
                                                In: C:\Users\venkatr\Desktop\
                                                Custom File Name:  “_660.html”   <----CS6 problem  recording - CS5 records "_660.jpg on my machine
                                                Format: JPEG
                                                Without Interlaced
                                                Quality: 55
                                                Quality Modification Channel Strength: 0
                                                Without Quality Channel Text Layers
                                                Without Quality Channel Vector Layers
                                                With Optimized
                                                Number Of Passes: 3
                                                Blur: 0
                                                Without Embed ICC Profile
                                                With Matte
                                                Matte Color Red: 255
                                                Matte Color Green: 255
                                                Matte Color Blue: 255
                                                Without Save HTML File
                                                With Save Image Files
                                                Slices: All Slices
                                                Color Handling: Convert to sRGB
                                                Metadata: None
                                                Without Output XHTML
                                                With Include Comments
                                                With Always Add Alt Attribute
                                                With Always Quote Attributes
                                                Without Close All Tags
                                                With Include Zero Margins on Body Tag
                                                HTML Tags Case: Lowercase
                                                HTML Attribute Case: Lowercase
                                                HTML Indent: -1
                                                HTML Line Endings: Automatic
                                                <unknown>
                                                Without Generate CSS
                                                Empty Cells: GIF, IMG WH
                                                TD WH: Auto
                                                Vertical Spacer Cells: Auto (Bottom/Right)
                                                Horizontal Spacer Cells: Auto (Bottom/Right)
                                                Slice Name Components: Filename Component list
                                                Filename Component
                                                Filename Component Type: doc. name
                                                Filename Component
                                                Filename Component Type: underscore
                                                Filename Component
                                                Filename Component Type: layer name or slice no.
                                                Filename Component
                                                Filename Component Type: none
                                                Filename Component
                                                Filename Component
                                                Without View As Background
                                                Background Image Path:  “”
                                                Background Color Type: Matte
                                                File Name Components: Filename Component list
                                                Filename Component
                                                Filename Component Type: slice name
                                                Filename Component
                                                Filename Component Type: hyphen
                                                Filename Component
                                                Filename Component Type: trigger name
                                                Filename Component
                                                Filename Component
                                                Filename Component Type: rollover state
                                                Filename Component
                                                ...3 More
                                                Without Mac OS 9 Filename Compatibility
                                                With Windows Filename Compatibility
                                                With Unix Filename Compatibility
                                                With Use Images Subfolder
                                                With Copy Background Image when Saving
                                                Images Subfolder Path:  “images”
                                      Select previous history state
                                      Crop
                                                To: rectangle
                                                Top: 111.4 pixels
                                                Left: 142.2 pixels
                                                Bottom: 2342.6 pixels
                                                Right: 3613.1 pixels
                                                Angle: 0°
                                                Without Delete Cropped Pixels
                                                <unknown>
                                                Target Width: 350 pixels
                                                Target Height: 225 pixels
                                                Target Resolution: 0 per inch
                                      Export
                                                Using: Save for Web
                                                Operation: Save
                                                true
                                                Custom File Name:  “_350.html”
                                                Format: JPEG
                                                Without Interlaced
                                                Quality: 55
                                                With Optimized
                                                Number Of Passes: 3
                                                Blur: 0
                                                With Matte
                                                Slices: All Slices
                                                Metadata: None
                                                HTML Indent: -1
                                                <unknown>
                                                TD WH: Auto
                                                Filename Component
                                                Filename Component
                                                Filename Component
                                                Filename Component
                                                Filename Component
                                                Filename Component
                                                Filename Component
                                                Filename Component
                                                Filename Component
                                                Filename Component
                                                Filename Component
                                                Filename Component
                                                ...3 More
                                      Crop
                                                To: rectangle
                                                Top: 0 pixels
                                                Left: 529.1 pixels
                                                Bottom: 2730 pixels
                                                Right: 2869.1 pixels
                                                Angle: 0°
                                                <unknown>
                                                Target Width: 300 pixels
                                                Target Height: 350 pixels
                                      Export
                                                Using: Save for Web
                                                Operation: Save
                                                true
                                                Custom File Name:  “_300.html”
                                                Format: JPEG
                                                Without Interlaced
                                                Quality: 55
                                                With Optimized
                                                Number Of Passes: 3
                                                Blur: 0
                                                With Matte
                                                Slices: All Slices
                                                Metadata: None
                                                HTML Indent: -1
                                                <unknown>
                                                TD WH: Auto
                                                Filename Component
                                                Filename Component
                                                Filename Component
                                                Filename Component
                                                Filename Component
                                                Filename Component
                                                Filename Component
                                                Filename Component
                                                Filename Component
                                                Filename Component
                                                Filename Component
                                                Filename Component
                                                ...3 More
                                      Crop
                                                To: rectangle
                                                Top: 136.5 pixels
                                                Left: 325.7 pixels
                                                Bottom: 2359.2 pixels
                                                Right: 3295.2 pixels
                                                Angle: 0°
                                                <unknown>
                                                Target Width: 167 pixels
                                                Target Height: 125 pixels
                                      Export
                                                Using: Save for Web
                                                Operation: Save
                                                true
                                                Custom File Name:  “_167.html”
                                                Format: JPEG
                                                Without Interlaced
                                                Quality: 55
                                                With Optimized
                                                Number Of Passes: 3
                                                Blur: 0
                                                With Matte
                                                Slices: All Slices
                                                Metadata: None
                                                HTML Indent: -1
                                                <unknown>
                                                TD WH: Auto
                                                Filename Component
                                                Filename Component
                                                Filename Component
                                                Filename Component
                                                Filename Component
                                                Filename Component
                                                Filename Component
                                                Filename Component
                                                Filename Component
                                                Filename Component
                                                Filename Component
                                                Filename Component
                                                ...3 More
                                      Crop
                                                To: rectangle
                                                Top: 225.1 pixels
                                                Left: 1318.4 pixels
                                                Bottom: 1858.5 pixels
                                                Right: 3496.2 pixels
                                                Angle: 0°
                                                <unknown>
                                                Target Width: 88 pixels
                                                Target Height: 66 pixels
                                      Export
                                                Using: Save for Web
                                                Operation: Save
                                                true
                                                Custom File Name:  “_88.html”
                                                Format: JPEG
                                                Without Interlaced
                                                Quality: 55
                                                With Optimized
                                                Number Of Passes: 3
                                                Blur: 0
                                                With Matte
                                                Slices: All Slices
                                                Metadata: None
                                                HTML Indent: -1
                                                <unknown>
                                                TD WH: Auto
                                                Filename Component
                                                Filename Component
                                                Filename Component
                                                Filename Component
                                                Filename Component
                                                Filename Component
                                                Filename Component
                                                Filename Component
                                                Filename Component
                                                Filename Component
                                                Filename Component
                                                Filename Component
                                                ...3 More
                                      Close
                                                Saving: no
                  1 person found this helpful
                  • 6. Re: PS CS6 action save for web error
                    venkatl Level 1
                    Thanks a JJMack for your precious time I hope soon I get a update on this to fix this bug, till then I'll manage.
                    • 7. Re: PS CS6 action save for web error
                      dunnmaks Level 1
                      This was reported more than 2 months ago and a Photoshop (Adobe) employee confirmed it as such.
                      http://feedback.photoshop.com/photoshop_family/topics/ps_cs6_actions_recorded_action_expor ts_html_instead_of_jpg
                      This is a HUGE inconvenience and surely needs to be addressed sooner than later.  I have found that importing actions from older versions will work...the only problem is if the machine name/user name/folder path changes it is worthless.
                      Luckily I have PS5.5 installed on my other computers and I use that...however, I just got my new MBP with Retina and won't be able to install 5.5, only the CC6 version.
                      • 8. Re: PS CS6 action save for web error
                        venkatl Level 1
                        thanks dunnmaks
                        saw the post, will keep a track of it hope we found a bug fix soon from Adobe
                        • 9. Re: PS CS6 action save for web error
                          Mike_Sans Level 1
                          I'm having this same issue and falling back on CS5 to batch the actions.
                          • 10. Re: PS CS6 action save for web error
                            chris_gundersen Level 1
                            This still isn't fixed? I have an action that I save as the image as x.jpg and then later in the action it uses x.jpg so I have to be able to make the name a generic name. Grrrrr, another reason I am not that happy that I upgraded to cs6!
                            • 11. Re: PS CS6 action save for web error
                              jonathonwatkins
                              So, when will this be fiexed and how do we batch a 'Save for Web' action? I have a large number of images I'd like to reduce the size of.
                              • 12. Re: PS CS6 action save for web error
                                Adobe does not publish a fix schedule or even commit to fixing problems. I  have submitted bug reports to Adobe that Adobe  has accepted as bugs introduced in CS4. I submitted bug reports on the problems in CS5 and CS6 on them. The best reply I received from Adobe was three or four years ago and it was perhaps they will be fixed is some future release. You can use a copy of CS5 to record the action and it will work in CS6.
                                • 13. Re: PS CS6 action save for web error
                                  dunnmaks Level 1
                                  And remember that only works if you record on the same machine (or same folder structure across machines).
                                  • 14. Re: PS CS6 action save for web error
                                    Also all CS6 recorded Save for web steps do not have the problem.  It depend on how you record Save for web.  Sone recorded steps record .html or .htm instead of .jpg.  Others record no file extension. Only the one that have recorded .htm or .html are a problem.  The ones that do not record the extensions work and the ones that save the wrong files extension actually save a jpeg file with the wrong extension.  Renamming the saved image.html files to image.jpg will fix the files.  Often all one need to do is a wildcard rename *.htm to *.jpg.
                                    • 15. Re: PS CS6 action save for web error
                                      jonathonwatkins Level 1
                                      CS6 certainly does have a problem. After reading this I re-created my action in CS5 and it works perfectly. I.e. have file open, create action & start recording. Select ‘Save for web & devices’, input settings, navigate to sub folder in file directory, click save, click close, click stop action. Then go to ‘Automate, Batch’, select the new action, select the relevant source folder (leaving destination blank), click OK. Result = all files in source folder are processed and placed in the folder specified in the action folder.
                                      When I do the exact thing in CS6 I get “Adobe Save for Web error” ‘Could not complete this operation. The system cannot find the file specified’.
                                      Glad I kept a copy of CS5 installed.
                                      On a separate note, is there a way to record the action so that the files will always go into a subfolder of whichever directory they are in?
                                      • 16. Re: PS CS6 action save for web error
                                        Usually when you record a save if you do not change the default offered like path and file name the path and file name will not be recorded in the action step like save as where all you change is the file type pull down where you set the type.  Like you do when processing a layered psd file and saving files like jpeg, gif and png.  If you don't change file type the original file is updated.  When these action steps are played the current document path and name will be used unless there is destination folder specified in a dialog like automate batch or script image processor they will override the default path. When path location and file name are not recorded into actions save step the save will be to the current documents location with the current document's file name.   Any recorded Path and or File name will override the current document path and name and Batch and scripts can override recorded location and names.
                                        • 17. Re: PS CS6 action save for web error
                                          I take the point, but I would prefer not to overwire the existing files. (I.e. if nothing is changed that's what will happen surely?).
                                          • 18. Re: PS CS6 action save for web error
                                            If you add a layer to a jpeg document a save would want to save a psd and with a psd file you usually want to save the psd file as well as other image file formats that is why batch and image processors exist you have much better control over output.
                                            The image processors scripts I have looked will not overlay any existing file it would add an serial suffix to the file name if the output file it wanted to save exists.
                                            • 19. Re: PS CS6 action save for web error
                                              bedroomlab Level 1
                                              I have a solution that works for Windows. I create a .bat file in the same directory as all the html file to rename all the .html files to .png
                                              Here's how to do it, it's really simple.
                                              Create a new text file in any old text editor. Add this one line:
                                              (Change .png to .jpg if you want jpgs)
                                              Save it as something like "renameHTMLtoPNG.bat".
                                              Run your Photoshop batch job to dump all the .html files into the same folder. Make sure this .bat is in the same folder as the .html files, then click on it to run it, and it'll rename everything to the correct extension.
                                              • 20. Re: PS CS6 action save for web error
                                                Lagosta052
                                                We found a way to trick photoshop. Since you're trying to export a single image, you will have to create the following steps on your action:
                                                - Create Slice - Create a slice with the full size of your image;
                                                - Set Slice - Set the name of the slice, have in mind it will be the name of your image;
                                                - Edit canvas size - That's the tricky part, you'll have to increase your canvas so that photoshop will consider your slice on the export process;
                                                - Save for Web - Now just go on normally in this step, just remember to select All User Slices;
                                                - Edit canvas size - Go back to the original size of your image;
                                                - Delete the slices - Under View menu -> Clear all slices.
                                                I couldn't figure why photoshop would not consider a single slice that matches the image size, so we had to do this get around.
                                                Hope it works for you.
                                                • 21. Re: PS CS6 action save for web error
                                                  Noel Carboni Level 8
                                                  Since the problem is that the wrong file extension is being stored in the action...
                                                  Has anyone tried saving an action set as a .atn file, hacking into a saved .atn file and changing the characters .html to .png (or whatever's desired)?  Use a null character (00) to blank out the L.  Then load the hacked .atn file back into Photoshop.
                                                  If you don't know how to do this, post a copy of an action file online and I will be happy to give it a try.
                                                  -Noel
                                                  • 22. Re: PS CS6 action save for web error
                                                    Very easy to do.  X created a set of tools scripting tools for Photoshop. In the Xtools package there are many supplied utility scripts.  Two of them could be used to do what you want.
                                                    The script names are ActionFileToXML and ActionFileFromXML.  So if you record an action the has a save for web step that when when you expand the step you set the the save file name is .html not .jpg like this one.
                                                    Save the Action Set into an .atn file and run ActionFileToXML the edit the XML file and change the .html" to .jpg save the XML file and run  ActionFileFromXML. The delete the action set in the Actions palette and load the updated .atn file. Expand the save for web steps to check that the steps not shows .jpg..
                                                    • 23. Re: PS CS6 action save for web error
                                                      Even better, since XML is editable with a simple text editor.  Thanks for that info, JJ.
                                                      -Noel
                                                      • 24. Re: PS CS6 action save for web error
                                                        jackbat
                                                        Does anyone else find it odd that we are discussing hacks and workarounds for something that worked flawlessly in a previous version of the software.  If they haven't fixed this in a year, I cannot imagine that they are very interested in doing so in the future.  How can Adobe not care about such an important basic function of the software.
                                                        • 25. Re: PS CS6 action save for web error
                                                          It not odd to disgust bugs at all and Adobe addressed the bug in CC.  However they did not fix CS6 which is  typical Adobe behavior.  Here is save for web recorded in CC the file extension is once again jpg and not the html that get recorded in CS6.
                                                          Save for web recorded in cs6
                                                          • 26. Re: PS CS6 action save for web error
                                                            I always like your steel arrows, JJ.
                                                            -Noel
                                                            • 27. Re: PS CS6 action save for web error
                                                              jackbat Level 1
                                                              OK, I am a believer in giving credit where credit is due.  I recieved two updates to CS6 this week and low and behold, one of the fixes was actions for export.  Well done Adobe.
                                                              • 28. Re: PS CS6 action save for web error
        Strange My CS6 is up to date and when I record a save for web as jpg and change the default fname  what gets saved is a jpeg file however what get recorded in the action is FileName.HTML and when the action is plated though a jpeg file is save its name is FileName.html.
        • 29. Re: PS CS6 action save for web error
        jackbat Level 1
        My only difference is I am not changing the default file name, so it is saving them sequentially as "untitled-1.jpg" which is what is has done in versions past.
        I am just happy it is saving jpgs again.  I have been using CS 5 since I made this post 6 days ago and tried it on a whim when the update happened.
        Think I will keep 5 around for a while though.
        • 30. Re: PS CS6 action save for web error
        Yes if you do not change the default file name offered no file name information is recorded in the action step and CS6 works correctly. The problem in cs6 has always been if you change the default offered .htm gets recorded not .jpg.  Its been fixes in cc.
        • 31. Re: PS CS6 action save for web error
        jackbat Level 1
        jj, it may have been working for you, but it didn't start working for me until I got an update a couple of days ago.  We do a lot of site management where customers send in articles in Word.  We Copy the images into photoshop to manipulate as they are usually huge, then we use an action to save them all of at once.  We have been doing this for years and it stopped working in CS 6.
        A typical web update will have over 100 images, so the difference between doiing them one at a time and simply hitting the action a few times is HUGE!
        This process saved us too much time to continue to use 6 without it so I am particularly grateful that they fixed it.
        I haven't tried using it while renaming the image as it would simply save all of the images over each other and that would defeat out purpose.
        • 32. Re: PS CS6 action save for web error
        ian.heaton Level 1
        As mentioned previously, In instances where the original files name has been changed at export is when the Custom File Name line will be added e.g., JJMack's screenshots above. I have found to fix the action, i simply open or use a file already open > Double-click the Export step in the action which will run that step and save the file as it's original name. This will strip off the Custom File Name.
        • 33. Re: PS CS6 action save for web error
        peterv40396918
        There is a simple work around for this (simpler than the thing with slices).
        1) Duplicate the image and give it the name of the file you want (excluding the extension).
        2) Do the save for web, but do not change the file name.
        3) Close the image (without saving).
        This way the action will not overrule the file name with a .html name.
