I have a help file that was working correctly in Chrome previous to the current release. With the new release, besides the refresh loop problem I've seen reported in this forum, we're having the following issues with the compiled webhelp:
Regarding the refresh loop issue:
When we compile the file and try to view it locally, we see the refresh loop problem already reported, however, when we view the help file when it is called by our app, we don't see the refresh loop problem.
Of course, we have a deadline this week so any help would be greatly appreciated.
When it’s called by your app, it’s not local, is it, I suspect.
I just did a quick test on the 30.0.1599.101 update & it still chokes on local html files.
Correct, when it's called by the app, it is not local. So, I'm not seeing the refresh loop problem when it is called by the app, but I am seeing the drop-down text problem when it is called by the app
Try this:
Open Chrome and go to a web site.
Press F12.
In the extra field, go to the console tag.
Now load the help system and click a dropdown.
Does the console display any errors, warnings, etc?
Greet,
Willam
Hi Willam,
No, I'm getting no errors or warnings.
Kim
Hi William,
Wait, I'm wrong. There is an error:
Uncaught ReferenceError: TextPopup is not defined
Failed to load resource: the server responded with a status of 404 (Not Found).
Thanks for your help,
Kim
"See also" references are also not working. I reported the drop-down issue to Adobe (before I discovered the "see also" wasn't working).
