1. Re: Digital Color Meter....
Trevor.Dennis Oct 16, 2013 8:47 PM (in response to naturesbestside)Window > Info or F8
2. Re: Digital Color Meter....
Chris Cox Oct 16, 2013 10:38 PM (in response to naturesbestside)That's an OS utility, it has nothing to do with Photoshop.
It's also misleading if you try to use it with color managed applications.
3. Re: Digital Color Meter....
naturesbestside Oct 17, 2013 1:28 PM (in response to Chris Cox)Chris,
Your answer doesn't seem to correlate to my question.
I open the application in the OS utilities to assist in color management but found out that it also supplies x and y coordinates under my cursor. Where has this feature disappeared to?
That's my question.
Thanx,
Jim.....
4. Re: Digital Color Meter....
Chris Cox Oct 17, 2013 1:30 PM (in response to naturesbestside)Your question has nothing to do with Photoshop.
You're talking about an OS utility - which changes at Apple's whim.
And that utility misleads on color mangement, because it only sees pixel values on the display, not in the document - so it is useless on color managed applications.
5. Re: Digital Color Meter....
SaturnV Oct 17, 2013 2:07 PM (in response to naturesbestside)naturesbestside wrote:
In addition to this information, the window also displays dynamically the x and y pixel coordinates of my cursor..... good for measuring pixel dimensions of an object. This feature has now disappeared. I've upgraded to Mountain Lion...
DigitalColor Meter is an Apple utility that's installed with OS X, so this forum really isn't the best place to ask questions about it. However, I just played with it for a minute and I think I have your answer.
In DigitalColor Meter, choose View > Show Mouse Location. This displays the X and Y coordinates.
Why did it change? The upgrade to Mountain Lion probably didn't preserve your settings from the older version. Again, any changes to the behavior of DigitalColor Meter were all caused by Apple and affected an Apple-provided utility, so the Apple Discussion Forums are probably the best place if you need to know more about it.
6. Re: Digital Color Meter....
naturesbestside Oct 17, 2013 8:42 PM (in response to Chris Cox)Chris,
Thanx for setting me straight. I should have taken this to an Apple Forum.
Your comment regarding the OS utility mislead with color management..... thanx for pointing this out to me.
Jim.....
7. Re: Digital Color Meter....
naturesbestside Oct 17, 2013 8:50 PM (in response to SaturnV)Conrad,
Yes, appreciate you for pointing out my error in using this forum for my question. Not appropriate, for sure.
But, I certainly do thank you for giving me the answer to my question !!
It was right in front of my face a couple of times...... where was I !
Thanx again,
Jim.....
8. Re: Digital Color Meter....
thedigitaldog Jun 19, 2014 12:02 PM (in response to Chris Cox)Chris Cox wrote:
Coming back to this late (sorry), can I assume then that this utility is useless for the task this person says he's using it for?
When was the last time you checked the color of your monitor for accuracy? Checking your monitor helps you to know if the colors display accurately and Mac has a built in color meter! As seen on Creative Live, Will Crockett shows you how to check your monitor using the built in Digital Color Meter application in your Mac. Get your Mac ready to follow along as you are taken step by step on how to check your monitor for color accuracy using the built in color meter!
I can't see how this utility has any ability to aid here or 'understand' what's emitted from the display. There's also this disconnect I don't understand. See the following, it's an sRGB doc set for R0/G255/B0, Photoshop as Chis reports shows the correct values. The DigitalColor Meter shows very, very odd values.
