All,
I've seen a couple of other posts about this topic, but answers do not really seem to solve the entire problem.
I just updated my project from RH9 to RH10. Now EVERY numbered (and bulleted) list in the program has extra space between lines - only in design mode, not when previewed or published. I found a post that suggested editing the CSS directly which I did try - but it does not automatically update existing lists. If I create a new list now, all is right with the world - but my hundreds and hundreds of existing topics look like crap in design mode.
Any ideas of what I can do? BTW - My RH 9 project with the unedited CSS still looks great.
Chris
What does your CSS and the HTML of the lists look like?
Perhaps it's something in the CSS, perhaps in the HTML. If it's in the HTML, a script can probably take care of it.
Greet,
Willam
William,
Thanks for the response. I admit to being a little out of my league with this stuff.
This is the CSS text:
P {
font-family: Verdana;
font-size: 8pt;
margin-top: 14pt;
margin-bottom: 14pt;
LI.P {
font-size: 8.0pt;
This is the HTML:
<li><p><span style="font-size: 8.0pt; font-family: Verdana, sans-serif;
mso-fareast-font-family: 'Times New Roman'; mso-bidi-font-family: 'Times New Roman';">C</span><span
line-height: normal;">lick the</span> <span style="font-weight: bold;">Account
Manager</span> <span style="font-size: 8.0pt; font-family: Verdana, sans-serif;
line-height: normal;">button in the
Main group of the program's sidebar to access Account Manager.</span></p></li>
<li><p style="margin-top: 14.0pt; margin-right: 0in;
margin-bottom: 14.0pt; margin-left: 0in; line-height: normal;"><span
mso-fareast-font-family: 'Times New Roman'; mso-bidi-font-family: 'Times New Roman';">Find
the account for which you wish to assign default discount
rates.<b><i><br />
Can you add the following code to the CSS and see what happens:
LI P {
margin-top: 0;
margin-bottom: 0;
Greet,
Willam
William,
I added the code as you suggested to the CSS, and it still has an extra space. However, I've noticed something about the paragraph styles that might be playing a part here.
These lists in topics I converted from RH9 all have paragraph styles of "Normal". Now, when I create a topic in "Normal" style in either RH9 or RH10, it looks like this (in both versions):
Now, if I highlight this and add numbers and keep it as "Normal" style, it looks like this in RH9:
but it looks like this in RH10:
Yes, if I just make a new list numbered it changes the style to "(None)" - but for some reason every topic in RH9 has "Normal" attached to its numbered lists. I have no idea how that happened.
So, you're thinking - just go in and remove top and bottom margins from the "Normal" style - but, unfortunately that will mess up other normal text throughout the project. Is there any way to change "Normal" margins ONLY if they're in numbered lists? And do you have any guess as to why a "Normal" numbered list would look different in RH10 than it does in RH9?
Thanks again for any thoughts.
Chris
The CSS for removing the margins in a list was the CSS I suggested earlier. Try this: add !important before the semicolon in the CSS definition. Does that help?
Greet,
Willam
