Hi all,
I have roamed these forums for some time now but I can't find the answer to my question, hopefully someone can help me !
In LiveCycle Designer, I'm preparing a static form. I opened a PDF which functions as a background image and now I want to add text fields. So far so good .
Now, when I save the file, it allows people to edit. Great ! However... In some cases the text typed in the form is bigger than the field assigned for it. I know there is a setting that allows the text to resize depending on what the user has typed. ( so, it always stays inside the boundry box of the text field ). I'm working in LiveCycle Designer, obviously on PC. I already checked the object field options ( figuring that the "limit lengt to visible area setting would do the trick ) but I can't find the solution here.
If someone has any pointers for me where or how I can do this, I would be very thankful !
Solved! Go to Solution.
Total Likes
On the font palette tab, select "Currently editing Value properties ..." and not editing both and then in the font size enter 0. This will tell the field to auto-size the field font in the given field area.
Total Likes
Total Likes
My god, I would have never found that ! Thanks so much !
Total Likes
Did not work for me. It just made my font really small. My editing options are greyed out.
Total Likes
This method will sometimes work but occassionally it just makes the font very small. How do I view the script to see where the auto resizing is getting turned off?
Total Likes
