In Robohelp 10 Webhelp when I open the Styles pane the cursor jumps about between the style of the currently selected paragraph and Normal. It's almost impossible to select and double-click on a style to apply it.
Not something I have seen reported. Is the operating system one that is supported?
I'm running Windows XP (service pack 3) under Parallels 6. I never had a problem with Robohelp 6 in this environment.
A lot has changed since Rh6 but whether or not that is the issue, I cannot say.
Anyone else seeing this using Parallels 6?
The problem does not appear when I load a sample project supplied with Robohelp 10. Hence, I presume, it is related to the fact that it occurs in my project which was created in Robohelp 6 and then opened in Robohelp 10.
Any suggestions as to what could be done to correct the problem? Note: I have applied the CSS style sheet from my own project to the Sample project and it operates correctly.
Try deleting CPD file and reopening project.
Thanks. That fixed the Jumping Styles pane.
LOL, we normally know the CPD to mean "Cache Project Database". In this case it seems to mean "Calms Project Down".
Happy Friday! Rick
Yes. The fact that one file transfer works and another does not. Have you
tried latest which was done with 2010?
