Changing table column widths
Oct 17, 2013 Oct 17, 2013
In Robohelp 10 when trying to resize a table column by dragging its boundary, often Robohelp crashes. I never had this problem with Robohelp 6.
547
Oct 18, 2013 Oct 18, 2013
Not a known issue. Try in one of the sample projects. Click Open on the RoboHelp Starter page and then click Samples in the ribbon on the left.
That will tell us whether it is a project issue or an installation issue. Having just seen your other post, I am inclined to the latter.
@petergrainge
Oct 19, 2013 Oct 19, 2013
I opened a Sample project. Then I imported into it an HTML topic (one that was causing Robohelp to crash when I try to resize a column by dragging its boundary). Carrying out the equivalent 'column-dragging' operation does not cause a crash.
Incidentally, I sometimes get an 'Out of memory' dialog when working in the same problem project. I haven't yet verified whether 'sample' projects are likely to crash.
Oct 21, 2013 Oct 21, 2013
I am wondering if you have imported an output topic. That can give out of memory problems and may be behind the crashing.
The usual clue is one or more red squares in the project.
@petergrainge
I have not, to my knowledge, ever imported an output topic. However, just to make sure, I have been through all my topics and have not found any 'red squares'.
On the other hand, it seems that both the crashing column width adjustment syndrome, and the 'St. Vitus dance' in the Styles pane are related to a corrupted CPD file. On several occasions I have deleted the CPD file and then opened my project. After working on the project successfully for a while (including column width adjustments), suddenly something goes awry and the problems start: styles pane problem, inability to switch from one topic to another etc. Starting again with a new CPD file seems to be the only solution.
Maybe change your settings to always delete the CPD file when the project is opened?
Thanks. That will help. I'll keep you posted when the next corruption occurs.
RoboHelp Documentation
Download Adobe RoboHelp
