I am trying to animate a simple 3D position change in Photoshop Extended CS6 (OS 10.7.4)
Here's what I do:
1. I move my object to its starting position.
2. I move the Current Time Indicator ("playhead") to the time I want the position change to start.
3. I click the Time‑Vary stopwatch icon on the Position layer of the timeline, and a keyframe is automatically created, no problem.
4. I move the playhead away from the initial keyframe to the time I want the position change to end.
5. I move my object to its ending position.
At this point, I expect to see the second keyframe be automatically created, as advertised, BUT it is not. What's more, if i move the playhead to "scrub" through the animation, I see no movement. What's happened is the position I set for Keyframe 1 has changed to the position I just moved the object to, which I intended to be Keyframe 2.
--Carol Gunn
Same problem here. I cant seem to get any predictable behaviour from the 3d camera in terms of adding keyframes. Other non-3d layers dont seem to be affected.
