0 Replies Latest reply: Oct 22, 2013 1:15 AM by HungryCatMari RSS
    A request or bug report FREContext.
    HungryCatMari Community Member
      I hope FREContext.dispose() can take argments like FREObject.call() in further update.
      Because when I create two instances of FREContext in Air,
      some of resource in java is overridden.
      I want to return id from java to air and when its removes I want to use that id.
      For example,in java,I keep admob-object as class variable when its created.
      When dispose() is called,I need to remove admob-object from activity.
      This is the sample.
      1st created adsdk is overriden by 2nd if I create double-ane instance in Air.
      //    Adding view on Activity
      public class ANEAdfuri_adfurisdk implements FREFunction{
          public FREObject call(FREContext arg0, FREObject[] arg1) {
              root = (ViewGroup) _activity.getWindow().getDecorView();
              // many logics
              int id = xxxx;
              view.setId(id);
              root.addView(view);
              return makeFREObject(Integer.toString(id));
      //    Removing view on Activity
      public class ANEAdfuriExtensionsContext extends FREContext{
          private admob adsdk;
          @Override
          public void dispose(FREObject[] arg1)
              Activity act = super.getActivity();
              String str1 = arg1[0].getAsString();
              int id = Integer.parseInt(str1);
              ViewGroup vg = (ViewGroup)act.getWindow().getDecorView();
              admob tmnp = vg.findViewById(id);
              vg.removeView(tmnp);
