Anyone else having this issue? From After Effects CC. It's never started up, and closes as soon as I try to open it.
We need to know a lot more if we're going to help you. Please provide answers to the questions listed here: "FAQ: What information should I provide when asking a question on this forum?"
I'm also having this same issue. It has never launched for me either and I started trying about 2 months ago and have been updating regularly and checking to see if a fix was applied but it still fails to launch.
C4D Lite can only be opened from within After Effects by creating a new C4D file/ editing an imported one.
Mylenium
It is as Mylenium says.
See the details of Cinema 4D integration with After Effects here:
http://blogs.adobe.com/aftereffects/2013/04/details-of-cinema-4d-integration-with-after-effects.html
Thanks for the help, worked like a charm.
I have the same problem, but I started c4d lite through after effects. The icon appears for one second, but nothing more happens. IMac i7 , 24 Ram, NVIDIA GeForce GTX 680MX. Any hints?
Thanks, Screener
Hi Screener,
Did you choose Layer > New > MAXON CINEMA 4D File?
Kevin
same problem...
www.youtube.com/embed/sD5qt94W9UY
TheR1D,
I watched your video. You are not using the feature correctly. You don't manually apply the Cineware effect to a layer. You import a .c4d file, and the Cineware effect is applied automatically when you create a layer based on that footage item.
There are resources that show how to use this feature at the link that I provided above:
Todd_Korpiva, Thanks, it works.
I tried what you just told but i have a messge error when i try to show to project in cinema 4d
What is the exact text of your error message?
omg thank you so much that worked! it was so helpful!
I was having the same problem - uninstalled After Effects, reinstalled, same thing. Thanks for the replies, it works now.
Honestly, whose idea was it that you could only run Cinema straight through After Effects? If I have a freaking program on my computer I should be able to open it on its own.
I am having the same issue with Cinema 4d. The icon bounces like it is going to open then stops and goes dormant.
Aaaah, got it. I can now open it from AE. I now know it is not a stand alone product.
I have a question to build on that. If you finish working on a C4D file and close AE and Cinema 4d lite, can you re-open and manipulate the c4d image at a later time within cinema 4d? I havent cracked this puzzle yet.
If you open the After Effects file, you should be able to continue working in C4D Lite on the project, yes.
Can you elaborate more on what you're trying to do and how it's not working for you?
Well I am following the instructions for correctly using it and it still fails to load. I can get it to import an exist c4d Project, but I still get the CINEMA 4D Lite quit unexpectedly error.
Mac 10.12.5
AE 15.1.1 (Build 12)
I have tried both Software only and OpenCL rendering
