1. Re: Cross-References Broken In RoboHelp 10 Output
Jeff_Coatsworth Jan 18, 2013 7:35 AM (in response to ASnyder28)It's a bug that has to do with the length of the path to your FM docs - shorten up the path & you'll see they start to work in RH
2. Re: Cross-References Broken In RoboHelp 10 Output
ASnyder28 Jan 18, 2013 7:55 AM (in response to Jeff_Coatsworth)I have shorten the file name and the heading that the cross-reference points to. It doesn't help. The other cross-references that point to documents in an equally long path work. The only difference is that that the cross-reference is pointing to a separate file that is in the same directory and the other file I am comparing against has a cross reference pointing to content within the same document. Does RoboHelp not support cross-references from one document to another when files are on a network? Copying our whole library locally to shorten paths for publishing isn't an option.
3. Re: Cross-References Broken In RoboHelp 10 Output
Jeff_Coatsworth Jan 18, 2013 8:30 AM (in response to ASnyder28)It does, but the total path length to a xref is limited to around 25 characters or so - I've never played around enough with it to exactly determine the max length. See this thread for more discussion - http://forums.adobe.com/message/5001958#5001958
4. Re: Cross-References Broken In RoboHelp 10 Output
ASnyder28 Jan 18, 2013 9:42 AM (in response to Jeff_Coatsworth)After trying to get the paths short enough, I copied the problematic files to my desktop and build a book in the same folder. Even after that, the same issue exists. The file name is 6 characters long including the .fm extension and the cross reference marker name is three characters. I don't think I can get the file paths much shorter.
5. Re: Cross-References Broken In RoboHelp 10 Output
Jeff_Coatsworth Jan 18, 2013 9:50 AM (in response to ASnyder28)And you updated the book in FM first in the new location before importing? I'd try something really short off the c:\ root directly - your desktop (depending on the version of Windows) is still a long path you know.
6. Re: Cross-References Broken In RoboHelp 10 Output
ASnyder28 Jan 18, 2013 10:38 AM (in response to Jeff_Coatsworth)I am in Windows 7. I moved the book and the files to my c:\ drive root. I updated the book and still have the same issue. It is very strange.
7. Re: Cross-References Broken In RoboHelp 10 Output
Jeff_Coatsworth Jan 18, 2013 10:43 AM (in response to ASnyder28)are some working & others not?
There were reports of a bug that had to do with xrefs that pointed back to earlier positions within the file - references like "See xxx on page yyy" were supposed by the Conversion Settings to end up as "See xxx" would get a mix of ones that were correct & ones that weren't.
8. Re: Cross-References Broken In RoboHelp 10 Output
ASnyder28 Jan 18, 2013 10:46 AM (in response to Jeff_Coatsworth)In the book I am currently working in, I only have one of these troublesome cross-references. We have seen the same issue in other books though. There doesn't seem to be any real common thread between them that I can identify and there doesn't seem to be anything "wrong" with the cross-reference or the related files.
9. Re: Cross-References Broken In RoboHelp 10 Output
ASnyder28 Jan 25, 2013 6:13 AM (in response to ASnyder28)We found that the path lengths did resolve some of our issues. I still have one cross-reference that refuses to behave.
10. Re: Cross-References Broken In RoboHelp 10 Output
ASnyder28 Mar 27, 2013 1:51 PM (in response to ASnyder28)We continue to have issues with cross-references being dead in RoboHelp output. We have placed the FrameMaker files on C: as well as the RoboHelp project. Does anyone have any additional suggestions?
11. Re: Cross-References Broken In RoboHelp 10 Output
Jeff_Coatsworth Mar 27, 2013 2:02 PM (in response to ASnyder28)@Peter - when you get a chance, can you move this one into the FM Integration forum?
@ASnyder28 - The RH project should have already been on C:\ (best practices advises c:\projects\{project_name}\ as a structure). What's the path length to the remaining busted link? There seems to be an invisible limit of under 35 characters (no spaces either) to these things. You may have to relink the xref in FM first before sucking it into a new project.
12. Re: Cross-References Broken In RoboHelp 10 Output
ASnyder28 Mar 28, 2013 6:26 AM (in response to Jeff_Coatsworth)I have been trying everything I can think of to move the files around to resolve the issue. 35 characters is very disappointing. Is this for the file and cross reference or the whole file path? I am not sure how you are going to be able to link from one Framemaker file to another, including a cross-reference name (especially when you can use heading for the cross-reference name) with a limitation like this. We also have a large library with many directories. We utilize single sourcing, so some files are in completely other directories from the file that is cross-referencing to it. From what you are telling me, it sounds like we no longer have the ability to use cross-references from one file to another in our library structure. Are you saying that all cross references basically need to be in the same file to allow cross references to work properly in RoboHelp? We moved from a WebWorks solution and we never had any issues with our links.
What I don't understand is the marker is in the destination file in the converted RoboHelp files, but the link is completely missing the <a href="#XREF_name ofmarker"> code in the cross-reference link. When I go in and manually link the cross-reference in RoboHelp, it works. This seems like a bug. I think having a 35 character limit on a filepath, filename, and cross-reference name is not going to work for anyone that has any sort of complex directory structure with multiple authors, sharing content and since it isn't a limitation of HTML, I don't see why this functions this way. Manually linking isn’t a reasonable option for us. We have a publishing system that publishes all of our output. We have hundreds of files that are generated automatically.
13. Re: Cross-References Broken In RoboHelp 10 Output
Jeff_Coatsworth Mar 28, 2013 6:49 AM (in response to ASnyder28)Oh I'd say it's a bug all right - the more people complain about it, the better chance it has of being addressed. If you have support, contact Adobe Support and hassle them. If not, file a bug report.
I ran across it in an earlier version of TCS but it took me some time to run down the cause & even then, I haven't identified the invisible limit exactly - I know it's around 35 characters (that's total path and .fm file name length), but it could be less.
Just like you, I've got lots of folder structure to my content - I use the "master book of books" concept to suck in around 60 sub-books into RH (by import; linking in earlier versions would crash). I had always noticed that some of the xrefs that I was sure were present & working in FM were busted in the resulting RH WebHelp output, but didn't have enough time to chase it down. It was when I was looking closely at a page of "what's new" notes that I was writing that I saw some xrefs work & others not all on the same page - that got me digging into the HTML code where I saw the malformed href= links. Tracing it back led me to believe it had to do with some really long paths that I was sort of stuck with until I could move the entire load of them into a shorter path name. Once I did that, they all seemed to clean up.
Another poster with a thread almost identical to this one has sent me their files to play with because shortening the path length didn't fix all the busted xrefs. I still have to play with them to see what's going on.
14. Re: Cross-References Broken In RoboHelp 10 Output
ASnyder28 Mar 28, 2013 6:53 AM (in response to ASnyder28)In addition, I saved two files with a broken cross reference as HTML within Framemaker and brought them into RoboHelp and it appears as though the link was preserved using this method. This makes me not understand the conversion limitation with RoboHelp even more.
15. Re: Cross-References Broken In RoboHelp 10 Output
ASnyder28 Mar 28, 2013 6:56 AM (in response to Jeff_Coatsworth)Thanks for the information. I will file a bug report.
16. Re: Cross-References Broken In RoboHelp 10 Output
ASnyder28 Mar 29, 2013 11:20 AM (in response to ASnyder28)I have continued to troubleshoot this issue. My update is that the issue seems to occur when a text inset precedes a cross-reference that links to another file with the book. I had several paragraphs between the inset and the cross-reference and it still seems to have caused the issue. Hope this can help someone that may encounter this.
17. Re: Cross-References Broken In RoboHelp 10 Output
Jeff_Coatsworth Mar 31, 2013 11:24 AM (in response to ASnyder28)Hmm, that's interesting - I don't use text insets in my projects, so I hadn't run into that, but it's good to know.
18. Re: Cross-References Broken In RoboHelp 10 Output
zandwich Apr 11, 2013 6:58 AM (in response to ASnyder28)Hi,
Try running the RoboHelp update available here:
http://www.adobe.com/support/robohelp/downloads.html
I had issues with cross-references not converting properly in TCS4, and this update fixed the problems.
Alexandra
19. Re: Cross-References Broken In RoboHelp 10 Output
davewilks May 22, 2013 7:47 PM (in response to zandwich)For what its worth, I came across this thread after running into this issue as well. I'm glad I read to the bottom and found @ASnyder28's post about the text insets. I copied my file, converted all of the text insets, and voila! Correctly converted cross references.
I don't really like this solution, but for a help project that needs to be delivered tomorrow, it works.
20. Re: Cross-References Broken In RoboHelp 10 Output
ASnyder28 May 23, 2013 5:35 AM (in response to davewilks)I am glad my post helped. It isn't ideal or pretty, but it is a workaround that will get the files out the door on time. Let's hope for a real fix soon!
21. Re: Cross-References Broken In RoboHelp 10 Output
mattrsullivan Jun 3, 2013 6:41 PM (in response to ASnyder28)To add to the joy of those that got their xrefs fixed with this patch:
I just discovered 2 things:
- My Rh wasn't patched up to 10.0.1
- Solving Thing #1 solved an issue with spot cross-references. I have now regained control of my spot xrefs.
Thx to the Rh team for putting out the patch!
22. Re: Cross-References Broken In RoboHelp 10 Output
A-Bel Oct 23, 2013 6:33 AM (in response to mattrsullivan)We are working with TCS 3.5 and RH 9 and FM 10.
The problem is the same.
We have two projects with missing Cross references in Robohelp after importing from Framemaker.
The cross references worked fine until I started to work with text insets.
We want to use text insets intensively in the future. As a modular system. This is very important for us.
Crossreferences are essential for online help systems, two. What to do?
What we need is an update for Robohelp 9 that fixes this problem.
Hope, there is someone with good news
23. Re: Cross-References Broken In RoboHelp 10 Output
Jeff_Coatsworth Oct 23, 2013 6:40 AM (in response to A-Bel)Don’t hold your breath – you need to upgrade to TCS 4 because with a new version coming 2014, they’re not doing much fixing in any but the prior release.
24. Re: Cross-References Broken In RoboHelp 10 Output
A-Bel Nov 4, 2013 3:20 AM (in response to Jeff_Coatsworth)Thanks for your reply!
Well, we bought the TCS in November 2012.
For our small company this was a big step foward, but also high expenses.
An update is my worst case: 1.300 € for each licence for one bug fix.
So, there is no angel of mercy with a patch for RH 9. Is there any way to address
my request to Adobe?
25. Re: Cross-References Broken In RoboHelp 10 Output
ASnyder28 Nov 4, 2013 5:29 AM (in response to A-Bel)I suggest submitting a bug report: https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform
I have done this for this issue for my versions of RoboHelp and FrameMaker. I would be specific about the financial impact upgrading so soon would have on your organization and reference this forum string. Good luck and I hope it gets fixed!
26. Re: Cross-References Broken In RoboHelp 10 Output
ASnyder28 Nov 4, 2013 5:32 AM (in response to A-Bel)Also, I have TCS 4 and the issue we are having hasn't been fixed yet. Upgrading won't fix it at this point if you are experiencing the same issue I am
27. Re: Cross-References Broken In RoboHelp 10 Output
A-Bel Nov 4, 2013 8:20 AM (in response to ASnyder28)Thank you for your support.
The bug report for RH is done. But I can't refer to it. Perhaps Adobe is going to send me a link or a reference number...
The RH patch 10.0.1 isn´t the fix? That's what I understand from MattRSullivans response.
I remain a bit puzzled
28. Re: Cross-References Broken In RoboHelp 10 Output
ASnyder28 Nov 4, 2013 9:54 AM (in response to A-Bel)I just applied the patch for 10 and ran help in a project that has the issue. I do not see any change in my output. I still have broken cross references. I have been in contact with Adobe and from my understanding the issue involving insets and cross references that I describe above has not been fixed. The patch may address other issues with cross references, but not our specific issue. Hope this is helpful.
29. Re: Cross-References Broken In RoboHelp 10 Output
mattrsullivan Nov 4, 2013 12:22 PM (in response to A-Bel)Actually, the patch resolved my issues.
It sounds as if there's an issue with xrefs within text insets, which doesn't apply to me. However, I tend to design around such limitations...living to fight another day!
Lobby for the increased functionality at adobe.com/go/wish (already done, I think) and then hurry up and wait to see if it makes it into the next version!
30. Re: Cross-References Broken In RoboHelp 10 Output
A-Bel Nov 5, 2013 12:35 AM (in response to mattrsullivan)Seems to be not that simple. We will test it with the TCS 4 trial version. As we have a 2nd cross reference problem in another project without text insets, but with the same behaviour (all external cross refs unresolved after import/ link) there might be a 50% success.
31. Re: Cross-References Broken In RoboHelp 10 Output
Curious 1 May 8, 2014 7:21 AM (in response to ASnyder28)I think I may be having the same issue. I'm using Technical Communications version 3. I have a huge FM book composed of many books - over 3,000 pages if it were printed. I'm linking to the FM file in RoboHelp (RH). No broken xrefs in FM, but when I go to RH, there are odd xrefs or missing ones. I keep updating both FM and RH without any success. So, I generated a list of cross-reference markers in FM.
This is what I think is causing this. Even though you're supposed to be able to link to the FM file and if all is ok with the FM book (no errors, no broken xrefs), everything should chug along in RH. But, NO, it doesn't. When I put in cross-references in FM, I do them by the paragraph. But then you can also see the actual marker text, which doesn't always agree with the heading text. This is what RH uses. So, if you're having these issues, check the marker text to make sure it matches the paragraph text.
Below is an example where I had updated the heading, but the marker didn't match. FM didn't care and didn't report a broken cross-reference. RH just displayed the xref heading but it wasn't a link. Very frustrating. I'm looking for a way to get the xref markers to match the paragraph headings.
This is the heading: EContent in the PAC Patron Account
and this is the marker text: 28254:Heading 3: 3M eBooks in the PAC Patron Account - Items Out 768
32. Re: Cross-References Broken In RoboHelp 10 Output
Jeff_Coatsworth May 8, 2014 8:28 AM (in response to Curious 1)@Curious 1 - There may be two things at play here – one is the length of your paths and filenames of your FM content – there’s an invisible limit of around 35 characters that causes RH to drop xrefs from FM if the combined path & filename is too long. The other is that there’s a bug if you have FM content in the form of xref, text inset, more xrefs – the ones before the text inset will “convert” fine, the ones after are busted. Also have a look at your Conversion Settings – how are you telling RH to treat your FM xrefs?
33. Re: Cross-References Broken In RoboHelp 10 Output
Curious 1 May 8, 2014 8:48 AM (in response to Jeff_Coatsworth)I know what's happening though it took me forever to figure it out. In FM if you go to View, Markers and see the list of cross-reference markers - not the xref pod but the marker pod - it shows the actual marker text. So, apparently RoboHelp was using this instead of the paragraph heading. When I put in the cross-references, I select the paragraph style, then update the marker - FM is all set, no broken xrefs. But, alas, RoboHelp (with a .chm output) uses the marker text or actually probably the marker number. So, it put in xrefs randomly - but it wasn't random, just extremely annoying (if you're supposed to be able to link to the FM document that says all the xrefs are fine). The interesting thing is this didn't happen with Web Help output. But, I have to create this huge, unwieldy .chm - customers need it.
I was posting to try to help spare someone else this time-consuming, time-wasting activity. Because I assume most writers would rather write than track down these problems with tools. I actually like FrameMaker, but RoboHelp is not user-friendly. So now, back to running this thing for the zillionth time. I'm on a deadline and the only writer working on this. Good luck in your endeavors.
34. Re: Cross-References Broken In RoboHelp 10 Output
Jeff_Coatsworth May 8, 2014 9:02 AM (in response to Curious 1)You can tweak what text gets used in RH in your Conversion Settings – that’s why I was asking. For example, I’ve got a FM xref format that does “heading text on page yy”, but in the Conversion Settings, I change that from “[Source]” to “<$paratext>” to use that paratext building block instead.
35. Re: Cross-References Broken In RoboHelp 10 Output
Curious 1 May 8, 2014 9:53 AM (in response to Jeff_Coatsworth)Yep, I know. That's what I use in the conversion settings to take out page numbers and convert the Heading in Title format so it doesn't say, See xxxx in the Administration Guide. That doesn't do anything to the actual marker text, which isn't revealed anywhere. But, if it doesn't know what marker ID to use, it puts in odd things. Like I showed in the example, the heading once said ebooks, but since then it's been changed to eContent. The heading was changed fine, which worked with FM, but RoboHelp must use the marker text and couldn't match it up to the new heading. That's the crux of the issue - I've tracked it down finally. So I thought I'd share in case someone else has that problem. Now if there were a way to say update all my cross-reference markers to use the existing headings, now that would be something!
36. Re: Cross-References Broken In RoboHelp 10 Output
Arnis Gubins May 8, 2014 10:23 AM (in response to Curious 1)Thanks for pointing out this subtle difference in behaviours between FM and RH.
It would be even better if the FM and RH programmers talked to each other, so that snafu's like this don't happen in the first place...
37. Re: Cross-References Broken In RoboHelp 10 Output
Curious 1 May 8, 2014 10:30 AM (in response to Arnis Gubins)Thanks! I'm getting a bit shrill myself - ran the Help at 3:15 a.m. and had started at about 6: a.m., trying this and that. Part of the problem is the FM files have been around forever. I started working at the company 14 years ago. And we just started using RoboHelp last year. I know compiled Help that's installed with the Windows application is old technology. But, I'm still expected to produce the file - oh with nice context-sensitive Help too - and do it all alone. I'm tempted to throw up my hands and say we can serve up Web Help because that works quite well. But change is difficult, especially when initiated by a writer.
38. Re: Cross-References Broken In RoboHelp 10 Output
Jeff_Coatsworth May 8, 2014 10:35 AM (in response to Curious 1)I realize I know why this has never been an issue with my FM to RH project – I don’t do the linking method – I just import fresh each time. The “out of synch” heading vs. marker text is completely ignored in that case. You always get whatever the heading text says.
39. Re: Cross-References Broken In RoboHelp 10 Output
Curious 1 May 8, 2014 10:41 AM (in response to Jeff_Coatsworth)Wow! That's very helpful. Maybe I should try importing instead of linking. I've already re-created the project several times, but I'm wondering if it would run more quickly. It takes so long now - to chug through and update all the files and then generated the .chm. It's painful. And, I can't work on any other FM files. I am working from home while I'm doing this. I'm up against it because there's a big general release of the software on the 15th. Thanks for the tip. I may try importing. I also need to convince my company that people are used to going to a web page for Help. I don't know about workform-level Help though. I guess that's the next thing to investigate if I'm not in the madhouse from working on this project.
