1
Premiere Pro CC Crashing At The Splash Screen - OSX Mavericks
Oct 22, 2013 Oct 22, 2013
Hello,
I'm having difficulty using Premiere Pro CC as it won't allow me to get past the splash screen. I've just updated to OSX Mavericks and apparently Premiere is compatible with Mavericks. However it appears to be crashing at every instance that I load it up, it flashes the splash screen and it crashes, giving me an error report.
I am a new member to these forums, so I apologise if I am asking in the wrong area.
I have the crash report here from Apple.
Message was edited by: Kevin Monahan. Crash log in attached doc. Please don't copy/paste crash logs in forum posts, attach them as separate documents. Thank you.
35.4K
Community Beginner , Oct 27, 2013 Oct 27, 2013
Ok despite almost daily updates from CC having no luck i seem to have SOLVED my crash on startup issue for now
For me at least the fix is to change the system region to ‘United States Computer’ And Pref Language to ‘English'
Oct 23, 2013 Oct 23, 2013
+1. Exactly the same exception code.
I'm afraid I don't understand?
It was just to say I'm having precisely the same issue as you.
I also have a retina 13" Macbook Pro and Premiere runs as sweet as a nut. This crash report is from my iMac.
I'm on a 15" Retina MBP. I've yet to try a reinstall, that's my next action.
Give it a try and let me know if you have any luck.
Any luck?
I have the same problem. Running 2009 imac i7. Tried reinstalling but no joy.
Mid 2010 27" iMac i5.
Isn't there a way we can bump this so someone from Adobe can see it? I have client projects that I need to edit and I am unable to do so because the software won't load.
https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform is where you officially tell Adobe
I'm going to see if a manual install of the patch would clear anything up instead of using the CC application.
Guest
I have the same problem - 2013 MacBook Air 11"  10% of the time it will actually launch, but then crashes shortly after.
Adobe Employee ,
Hi SWDoctor,
Thanks for choosing Adobe forums
Please try to uninstall and reinstall Premiere Pro CC.
and then try to launch.
Sandeep
Advocate ,
And IF that works, I'd recommend folks on Macs do a complete re-install with Mavericks.  That means formatting your HD and reinstalling from scratch.  Apple's OS upgrades are fairly bullet-proof, but they're not 100% so.  Something will always jump up and bite you in the backside when you least expect it.
Going between dot-revisions (10.X.2 to 10.X.3) isn't a problem.  Those are easy patches.  But going whole versions (10.8 to 10.9) is where you'll want to format and re-install.
It hasn't worked for both scenarios. I have reinstalled OSX Mavericks as well as Premiere but to no avail.
Advocate ,
A complete format and re-install?  In other words: nuking everything on your drive?  You're familiar with how to do that with Disk Utility during the installation process, right?  And you created a bootable USB thumb drive to do it?
Yup. Full wipe and it still has issues.
Advocate ,
For what it's worth, I have both a Mac Pro 5,1 and a first-gen Retina Macbook Pro.  Both were nuked from orbit and had Mavericks installed using a thumb drive.  Both run Premiere Pro CC without issue.
I have done a complete reinstall of the software. No luck.
Same issue here on Mavericks. 13A598. Developer. GM 1
However CC Client just pushed a 7.01 update and it is still failing. i.e. crashing on startup (splash graphic only). I have a second machine with a fresh GM2 install of Mavericks that I am waiting to try. Will post result as soon as that is up.
Still doesnt work on Mavericks 13A603 Upgraded. Adobe Premiere Pro CC [2489]
Unfortunately cant do a fresh install of CC Mavericks on this machine at the moment.
Same issue 7.01 still crashes on the splash screen. imac i7 2009.
Adobe Employee ,
Oct 24, 2013 Oct 24, 2013
Thanks for the reports, all, and sorry to hear that you're having this problem. The crash report that SWDoctor posted points to a problem identifying something about the system language settings. Two things from all of you would really help us nail this down, both to come up with a fix and to recommend a workaround until that fix is released.
  1. Post the log file "Premiere Pro Log.txt."
    PPRO does not write this log by default. To prime the pump, go to ~/Library/Preferences/Adobe/Premiere Pro/7.0/logs and create a file by the name of "Premiere Pro Log.txt". It doesn't matter what, if anything is in that initial file because PPRO will write a new one on launch. So just launch the app, and then please post the new log file.
  2. Post screenshots of the main Language&Region dialog from System Preferences. Also click "Advanced" and grab a screenshot of the General tab.
Several of our QEs spent hours yesterday attempting to reproduce this issue to no avail. So we suspect that there's something different about the language settings on the systems where Premiere is crashing.
Thanks for your assistance in helping us nail this down.
Premiere Pro CC crashing on launch with Mavericks. On a 2009 8 core Mac Pro.  CS6 seems to be ok.  Here is the crash long.   I'll try an uninstall and reinstall of CC and let you know later how it goes.
Message was edited by: Kevin Monahan. Please don't copy/paste crash logs to forum posts. Attach them as separate docs. Thanks!
