The Logs directory nor the flashlog.txt file is not being generated in
/Users/[username]/Library/Preferences/Macromedia/Flash Player/
I have run a debugging session from FB 4.7 and it prints trace statements in the console. I have also run several debug swfs in Chrome and Safari hoping this would generate the file. I used find in terminal to search my entire drive for "flashlog.txt" and various wildcard permutations.
It's been months since I had need to read this file, has something changed with the Flash Player and the log file generation?
Did you setup mm.cfg to log trace statements?
http://livedocs.adobe.com/flex/3/html/help.html?content=logging_04.html
Cheers.
-Aaron
Cheers.
-Aaron
Thanks, after reviewing the instructions again I realized my mistake. I edited an existing file called 'mms.cfg' when I should have created a new one called 'mm.cfg'.
It works now.
